8800gts/gtx Tech Demos!!
(_)_)
Rush Of Panic - Mchl :)
Programas que Demonstram o potêncial das Placas da Serie 8x :)
NVIDIA GeForce 8800 technology demo's available for Download
We can now distribute NVIDIA's GeForce 8800 tech-demo's for you guys as NVIDIA gave the green light.
NVIDIA Demo: Froggy
Froggy is a bit high strung and loves nothing more than a deep-tissue massage for relaxation. Feel free to pull, slap, poke, prod and otherwise comfort him. You can even pull his eyelids if you think it'll help. (These massage techniques are not recommended for offline amphibians.)
http://downloads.guru3d.com/download.php?det=1538
NVIDIA Demo: Adrianne
The Adrianne demo uses complex shading and deformation techniques typically reserved for offline-rendered animation. GeForce 8800's unified shader architecture makes this possible by dynamically balancing any combination of vertex, geometry and pixel shading for maximum hardware acceleration. This same unified shader architecture works with all OpenGL, DirectX 9, and DirectX 10 titles.
http://downloads.guru3d.com/download.php?det=1540
NVIDIA Demo: Box of Smoke
While we work on trapping an actual genie in a bottle, here's the next best thing - a box full of smoke. This demo not only shows the graphics horsepower of the GeForce 8800, but the computational horsepower as well. As you move the smoke generator within the box, the computational fluid dynamics simulation is being processed in real time on the GPU. Yes, all the Navier-Stokes eqations associated with the smoke movent are being evaluated on the GPU!
http://downloads.guru3d.com/download.php?det=1539
FONTE: GURU3D.COM
Vou baixar o demo da fumacinha e depois da mina, tô curioso pra ver esse lance de processamento de física
Legal o topico :yes:
Fiquei com uma dúvida... os demos foram rodados em DX9 correto, portanto os efeitos que possuem são reproduzíveis em outras VGA's com suporte a DX9.0c :D ou rolou uma emulação de DX10 neles :confused:
Se elas tem suporte a DX10, acredito que foi em DX10 pq rodariam a dx9 ?
Interessante... desinstalando... hehehehe
naum gostei da pele da mulher ali, ta muito fraca, muito plastica akela textura
Até que é legal!!! Mas vga se testa em games não em animações super realisticas que não podem ser jogadas!
No video da Gamespot sobre a 8800GTX perguntaram como os demos rodavam. Que eu me lembre o carinha da nVidia falou que os demos usam OPENGL.
Com OPENGL eles podem usar as extensões que seriam comparáveis ao DX10, fazendo com que os demos funcionem no Windows XP.
E todos nós sabemos que DX10 não será implementado no Windows XP. E esses demos usam recursos comparáveis ao DX10.
Logo, os demos foram feitos em OpenGL... :)
fui
