filipeutzig | jw disse:
Não, ai você esta errado, ambas são nForce 2 Ultra 400 e tem Dual-Channel...
A diferença entre elas esta no SouthBridge a AN7 tem o MCP-T e a NF7 tem o MCP...
A AN7 tem SoundStorm, S-ATA, FireWire e umas outras coisas que não interferem no desempenho do PC, mas dependendo do uso são uteis, ja a NF7 não tem SoundStorm, S-ATA, FireWire...
tirei isso do site da abit
The NF7-S series models ( não aos modelos NF7-S2 )
Features
AGP 8X
AGP 3.0 8X spec supports high performance graphics processing at a peak bandwidth of 2.1 GB/s.
Serial ATA 150
Serial ATA is an evolutionary replacement for the Parallel ATA storage interface. This new high-speed interface burst data transfer rate up to 150 Mbytes/sec and more flexible power tolerances, cables can be smaller and more efficient
Dual DDR 400
Dual DDR combines the power of DDR400 with two 64-bit independent memory controllers, the 128-bit memory controller integrated on chip provides up to 6.4 GB/sec bandwidth for system memory, and gives you highest performance and cost-effective platform.
5bit FID (Frequency ID)
By ABIT 5-bits FID Override technology, users can get variety of CPU over-clocking sets.
ABIT CPU H.T.P (Hardware Thermal Protection)
ABIT CPU H.T.P. uses pure hardware detection, which not like others use software detection to prevent CPU overheating. ABIT CPU H.T.P provides more reliable result for customers’investment.
ABIT SoftMenu™
The overclocking function includes CPU frequency, Vcore, multiplier, chipset & DDR voltage and AGP VDDQ voltage adjustment available to maximize your system performance.
SoundStorm™ Technology
Real-time Dolby Digital 5.1 audio encoding delivering up to 256 simultaneous audio streams
6-Channel Audio and Optical S/PDIF Out
Lets you enjoy 6-channel audio without having to buy advanced sound cards.
