Como faz mensalmente, a AMD acaba de disponibilizar a versão 9.9 do driver Catalyst.
Para baixar, acesse:
http://game.amd.com/us-en/drivers_catalyst.aspx
Não divulgaram melhorias em games, as notas da revisão indicam apenas correções de erros.
Correções
Todas as plataformas
- Catalyst Control Center - Basic now responds properly after exiting Quick Adjust Video Settings
- Edge enhancement and de-noise sliders in Catalyst Control Center no longer lags or appears out of sync with mouse movement
- Launching Hotkeys Manager in Catalyst Control Center no longer causes an unhandled exception error
- The "Desktop Rotation" page in Catalyst Control Center no longer shows additional information for the second display when the secondary adapter is connected
- HDMI is now detected properly as DTV (HDMI) instead of DTV (DVI) when the HDMI display is hotplugged for the first time
- Catalyst Control Center no longer displays error message when specific HDMI displays are hot unplugged and hotplugged back
Windows 7
- Intermittent failures no longer occur with MediaShow Espresso once a transcoding process has been completed
Vista
- Running OpenGL applications in windowed mode on extended desktop no longer causes the secondary display to go blank for some ASICs
- Task switching between the desktop and a game in progress no longer has a visible delay (7-10 seconds)
- Enabling Screen Space Ambient Occlusion option in "Rid**** 2 Dark Athena" no longer causes the game to fail under Multi-GPU configurations
- Catalyst Control Center no longer shows both HDMI displays as DVI when they are connected via HDMI port and to DVI port via HDMI-DVI dongle
- Windows Aero Glass Effects now works properly during HD Blu-ray playback
Windows XP
- Resuming video playback after S1 sleep no longer causes HDMI audio to disappear
- Changes to AVIVO Basic color settings are now retained after Catalyst Control Center is re-opened
- AVIVO Basic color setting changes can now be applied during HD DVD playback on specific ASICs on XP Media Center Edition
Correções
Windows 7
Vista
Windows XP
