Nova atualização do Ccleaner.
Versão: v2.14.763
Link: http://www.ccleaner.com/download/downloading
Ótimo programa, vale a pena atualizar.
Principalmente se você tem uma versão mais antiga.
Version History
v2.14.763
- Fixed minor bug in Firefox 2 cookies support.
v2.14.750
- Added support for Windows 7.
- Improved Google Chrome support (build 0.4).
- Opera cookie management added.
- Improved Recycle Bin cleaning.
- Added a warning when cleaning Google Chrome and it's running.
- Search Autocomplete cleaning now XP only.
- Improve file association Registry Cleaning.
- Fixed bug with context menus and excessive CPU usage.
- Fixed GUI colors on high contrast themes.
- Minor GUI bugs fixed.
- Minor performance improvements.
v2.13.720
- Added support for Firefox 3.1.
- Added right-click cleaning and analysis for individual items in the tree.
- Added icons to tree parent items.
- Added cleaning for Windows Error Reporting files.
- Added Include/Exclude list editing.
- Improved TypeLib registry cleaning.
- Fixed Index.dat bug that could cause a crash.
- Fixed bug with INI warning messages.
- Internal architecture improvements.
- Fixed minor GUI errors.
v2.12.660
- Improved Google Chrome support.
v2.12.651
- Added Google Chrome support.
- Improved cleaning security checks.
- Improved recursive cleaning functions.
- Fixed bug in INI FileKey evaluation routine.
- Updated INI file processing engine.
- Improved system info checks for modern CPUs.
- Various language and translation improvements.
- Minor GUI tweaks.
v2.11.636
- Optimized startup and closing of application.
- Improved Registry cleaning on 64-bit OS.
- Improved memory usage on Windows Vista.
- Added System Tray icon status.
- Internal refactoring of code for efficiency.
- Improved Uninstall Tool accuracy with MSI installers.
- Fixed bug in Uninstall Tool on 64-bit OS.
- Fixed bug in INI file folder recursion.
- Fixed bug in INI file OS detection.
- Added Live Messenger cleaning for .SQM files.
- Added Vietnamese translation.
- Minor tweaks and improvements.
v2.10.618
- Added Type Library cleaning to Registry Cleaner.
- Improved File Extension scanning in Registry Cleaner.
- Added /SHUTDOWN command-line parameter to shutdown the computer
after cleaning. Only works with /AUTO.
- Added Shutdown option to system tray menu.
- Added support for Vista common dialogs.
- Fixed bug in Uninstaller Tool where some items were hidden.
- Fixed multi-monitor issue with dialogs.
- Fixed incompatibility with Windows Search 4.0.
- Added seconds to filename when saving .REG files.
- Improved RegEdit location navigation.
- Improved Google Earth cleaning and detection.
- Memory usage optimizations.
- Minor bug fixes.
v2.09.600
- Added full support for Internet Explorer 8.0 beta.
- Improved Opera 9.5 support to fix cache cleaning.
- Improved interface for Startup tool.
- Changed memory management routines to reduce footprint.
- Fixed rare 64-bit performance issues.
- Added splitter bar to interface.
- Fixed repaint issues with certain themes.
- Fixed Spybot cleaning detection.
- Internal code optimizations.
- Updated installer engine to fix icon bug.
- Minor GUI tweaks.
Versão: v2.14.763
Version History
v2.14.763
v2.14.750
v2.13.720
v2.12.660
v2.12.651
- Minor GUI tweaks.
v2.11.636
v2.10.618
- Minor bug fixes.
v2.09.600
- Minor GUI tweaks.
