CCleaner v2.00.491 Beta 2
- Added support for Firefox HttpOnly cookies.
- Fixed symbolic languages not displaying correctly.
- Added translation of new v2.0 features into other languages.
- Fixed bug in Hotfix Uninstaller cleaning that left empty folders.
- Fixed bug in Temporary Files cleaning that left empty folders.
- Installer now supports parameters like /L=1033 for language selection.
- New installer routines to prevent false positives by antivirus programs.
- Cookies list in Options now refreshes correctly.
- Fixed bug in automatic update checker.
- Improved Options-Exclude Registry key entry format.
- Fixed empty message box in Uninstaller Tool.
- Improved IE7 history cleaning when IE is open.
- Minor tweaks and fixes.
Features of CCleaner 2.0:
Complete rebuild in C++
With the requirements for a portable version, 64-bit compatibility and Windows Vista increasing against the limitations of the old architecture. We decided to rebuild the entire CCleaner application in highly optimized C++.
Faster analyzing and cleaning
Each scanning process was rewritten from scratch and fully optimized. The result being a noticeable speed increase in all areas.
Portable
CCleaner can now run from a USB thumbdrive and be installed/run on a computer without a complicated setup process.
Compact
The rewrite removed all external file dependencies, so the main EXE is now half the size of the original program and support files.
Redesigned User Interface
The original CCleaner user interface was looking a little dated, so the GUI was redesigned with a modern look, but without sacrificing speed or usability. New icons were created for the interface and the main program icon was updated with a more modern style.
Exclusions
It is now possible to specify files, folders and registry keys to ignore from the cleaning process.
Loads of little tweaks
Too numerous to mention them all separately, we've tried to improve CCleaner in all areas.
Download:
- CCleaner.com
Portable
Compact
Exclusions
Download:
- CCleaner.com
