Seguinte, to com pc aqui da empresa que todos ou dia ele cria arquivos no bloco de notas e salva altomaticamente na area de trabalho.....
muitos
mas nao consigo saber de onde vem e tal, ou melhor como teminar com isso q q ta acontecendo
abaixo o um dos arquivos
muitos
# An unexpected error has been detected by Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x40f02b2a, pid=1896, tid=2508
# Java VM: Java HotSpot(TM) Client VM (11.0-b16 mixed mode, sharing windows-x86)
# Problematic frame:
# C [mshtml.dll+0x182b2a]
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x0b21f800): JavaThread "Thread-2" [_thread_in_native, id=2508, stack(0x10440000,0x10540000)]
siginfo: ExceptionCode=0xc0000005, reading address 0x00000138
Registers:
EAX=0x00000000, EBX=0x00000000, ECX=0x00000032, EDX=0x28040ab8
ESP=0x1053f734, EBP=0x1053f74c, ESI=0x0aa92890, EDI=0x7c8097e0
EIP=0x40f02b2a, EFLAGS=0x00010246
Top of Stack: (sp=0x1053f734)
0x1053f734: 00000000 0aa92890 28039668 40e3c88d
0x1053f744: 0aa92890 00000000 1053f760 40e3552c
0x1053f754: 0aa92890 0b21f800 11d48ca8 1053f770
0x1053f764: 40f37700 0aa92890 28039668 1053f7bc
0x1053f774: 6d412fad 11d48ca8 0bbd9cf1 0b21f914
0x1053f784: 1053f7c4 11d48ca8 00000000 00000007
0x1053f794: 270d14c0 2709a8a0 1053f79c 00000000
0x1053f7a4: 1053f7d0 28040ab8 00000000 28039668
Instructions: (pc=0x40f02b2a)
0x40f02b1a: dc 8c 08 41 8b 3d 10 13 d8 40 8b f1 ff d7 33 db
0x40f02b2a: 39 98 38 01 00 00 74 1f ff 35 dc 8c 08 41 ff d7
Stack: [0x10440000,0x10540000], sp=0x1053f734, free space=1021k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C [mshtml.dll+0xb552c]
C [mshtml.dll+0x1b7700]
C [jp2iexp.dll+0x2fad]
j sun.plugin2.main.server.IExplorerPlugin.javaScriptReleaseObject(Lsun/plugin2/liveconnect/BrowserSideObjectV+4
j sun.plugin2.main.server.LiveConnectSupport$PerPluginInfo.releaseAllObjects()V+34
j sun.plugin2.main.server.LiveConnectSupport.shutdown(I)V+42
j sun.plugin2.main.server.JVMInstance.unregisterApplet(I)V+63
j sun.plugin2.main.server.JVMInstance.dispose()V+67
j sun.plugin2.main.server.JVMInstance.access$2600(Lsun/plugin2/main/server/JVMInstanceV+1
j sun.plugin2.main.server.JVMInstance$Listener.jvmExited(Lsun/plugin2/jvm/JVMLauncherV+86
j sun.plugin2.jvm.JVMLauncher.fireJVMExited()V+31
j sun.plugin2.jvm.JVMLauncher.access$300(Lsun/plugin2/jvm/JVMLauncherV+1
j sun.plugin2.jvm.JVMLauncher$JVMWatcher.run()V+50
j java.lang.Thread.run()V+11
v ~StubRoutines::call_stub
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j sun.plugin2.main.server.IExplorerPlugin.iUnknownRelease(J)V+0
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x0b188800 JavaThread "Thread-3" [_thread_in_native, id=3268, stack(0x11540000,0x11640000)]
0x0e5d8800 JavaThread "JRE 1.6.0.11 Heartbeat Thread" [_thread_blocked, id=3372, stack(0x0e4d0000,0x0e5d0000)]
=>0x0b21f800 JavaThread "Thread-2" [_thread_in_native, id=2508, stack(0x10440000,0x10540000)]
0x0b216400 JavaThread "traceMsgQueueThread" daemon [_thread_blocked, id=4032, stack(0x0e3d0000,0x0e4d0000)]
0x0b1a5400 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=3208, stack(0x0e1d0000,0x0e2d0000)]
0x0b19ec00 JavaThread "CompilerThread0" daemon [_thread_blocked, id=3244, stack(0x0e0d0000,0x0e1d0000)]
0x0b19d400 JavaThread "Attach Listener" daemon [_thread_blocked, id=3292, stack(0x0dfd0000,0x0e0d0000)]
0x0b19c400 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=2344, stack(0x0ded0000,0x0dfd0000)]
0x0b197400 JavaThread "Finalizer" daemon [_thread_blocked, id=1168, stack(0x0ddd0000,0x0ded0000)]
0x0b192800 JavaThread "Reference Handler" daemon [_thread_blocked, id=3640, stack(0x0dcd0000,0x0ddd0000)]
0x0367a400 JavaThread "main" [_thread_in_native, id=1336, stack(0x021a0000,0x022a0000)]
Other Threads:
0x0b191000 VMThread [stack: 0x0dbd0000,0x0dcd0000] [id=3316]
0x0b1b8c00 WatcherThread [stack: 0x0e2d0000,0x0e3d0000] [id=4080]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 960K, used 713K [0x27030000, 0x27130000, 0x27160000)
eden space 896K, 72% used [0x27030000, 0x270d25a8, 0x27110000)
from space 64K, 100% used [0x27120000, 0x27130000, 0x27130000)
to space 64K, 0% used [0x27110000, 0x27110000, 0x27120000)
tenured generation total 4096K, used 256K [0x27160000, 0x27560000, 0x28030000)
the space 4096K, 6% used [0x27160000, 0x271a00b8, 0x271a0200, 0x27560000)
compacting perm gen total 12288K, used 1363K [0x28030000, 0x28c30000, 0x2c030000)
the space 12288K, 11% used [0x28030000, 0x28184c10, 0x28184e00, 0x28c30000)
ro space 8192K, 63% used [0x2c030000, 0x2c543ae8, 0x2c543c00, 0x2c830000)
rw space 12288K, 53% used [0x2c830000, 0x2ce983f8, 0x2ce98400, 0x2d430000)
Dynamic libraries:
0x00400000 - 0x0049c000 C:\Arquivos de programas\Internet Explorer\iexplore.exe
0x7c900000 - 0x7c9b6000 C:\WINDOWS\system32\ntdll.dll
0x7c800000 - 0x7c900000 C:\WINDOWS\system32\kernel32.dll
0x77f50000 - 0x77ffb000 C:\WINDOWS\system32\ADVAPI32.dll
0x77db0000 - 0x77e42000 C:\WINDOWS\system32\RPCRT4.dll
0x77f20000 - 0x77f31000 C:\WINDOWS\system32\Secur32.dll
0x77e50000 - 0x77e99000 C:\WINDOWS\system32\GDI32.dll
0x7e360000 - 0x7e3f1000 C:\WINDOWS\system32\USER32.dll
0x77bf0000 - 0x77c48000 C:\WINDOWS\system32\msvcrt.dll
0x77ea0000 - 0x77f16000 C:\WINDOWS\system32\SHLWAPI.dll
0x7c9c0000 - 0x7d1de000 C:\WINDOWS\system32\SHELL32.dll
0x774c0000 - 0x775fd000 C:\WINDOWS\system32\ole32.dll
0x43f90000 - 0x440b7000 C:\WINDOWS\system32\urlmon.dll
0x77100000 - 0x7718b000 C:\WINDOWS\system32\OLEAUT32.dll
0x43100000 - 0x43145000 C:\WINDOWS\system32\iertutil.dll
0x77be0000 - 0x77be8000 C:\WINDOWS\system32\VERSION.dll
0x76360000 - 0x7637d000 C:\WINDOWS\system32\IMM32.DLL
0x773b0000 - 0x774b3000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83\comctl32.dll
0x5d510000 - 0x5d5aa000 C:\WINDOWS\system32\comctl32.dll
0x10000000 - 0x1002e000 C:\WINDOWS\system32\SnAgOS.TMP
0x43380000 - 0x43450000 C:\WINDOWS\system32\WININET.dll
0x00990000 - 0x00999000 C:\WINDOWS\system32\Normaliz.dll
0x00bc0000 - 0x00bd7000 C:\WINDOWS\system32\Sngw.dll
0x010c0000 - 0x010fb000 C:\WINDOWS\system32\SnAgWB.DLL
0x77900000 - 0x779f5000 C:\WINDOWS\system32\SETUPAPI.dll
0x74aa0000 - 0x74aa7000 C:\WINDOWS\system32\CFGMGR32.dll
0x68e00000 - 0x68e09000 C:\WINDOWS\system32\hid.dll
0x43700000 - 0x43ccd000 C:\WINDOWS\system32\IEFRAME.dll
0x76bd0000 - 0x76bdb000 C:\WINDOWS\system32\PSAPI.DLL
0x5b1c0000 - 0x5b1f8000 C:\WINDOWS\system32\UxTheme.dll
0x746e0000 - 0x7472c000 C:\WINDOWS\system32\MSCTF.dll
0x01290000 - 0x01370000 C:\ARQUIV~1\GBPLUGIN\gbieh.dll
0x010a0000 - 0x010b6000 C:\Arquivos de programas\Hauri\ViRobot Desktop 5.5\AntiSpam\HProcHK.dll
0x01580000 - 0x01850000 C:\WINDOWS\system32\xpsp2res.dll
0x75290000 - 0x752be000 C:\WINDOWS\system32\msctfime.ime
0x5dff0000 - 0x5e01f000 C:\WINDOWS\system32\IEUI.dll
0x76350000 - 0x76355000 C:\WINDOWS\system32\MSIMG32.dll
0x4eb60000 - 0x4ed06000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_6595b64144ccf1df_1.0.2600.5581_x-ww_dfbc4fc4\gdiplus.dll
0x47060000 - 0x47081000 C:\WINDOWS\system32\xmllite.dll
0x77b20000 - 0x77b42000 C:\WINDOWS\system32\apphelp.dll
0x76fb0000 - 0x7702f000 C:\WINDOWS\system32\CLBCATQ.DLL
0x77030000 - 0x770fd000 C:\WINDOWS\system32\COMRes.dll
0x746b0000 - 0x746da000 C:\WINDOWS\system32\msimtf.dll
0x77a00000 - 0x77a55000 C:\WINDOWS\System32\cscui.dll
0x765d0000 - 0x765ed000 C:\WINDOWS\System32\CSCDLL.dll
0x61930000 - 0x6197a000 C:\Arquivos de programas\Internet Explorer\IEPROXY.DLL
0x7e690000 - 0x7e740000 C:\WINDOWS\system32\SXS.DLL
0x75d70000 - 0x75e01000 C:\WINDOWS\system32\MLANG.dll
0x71a70000 - 0x71a87000 C:\WINDOWS\system32\ws2_32.dll
0x71a60000 - 0x71a68000 C:\WINDOWS\system32\WS2HELP.dll
0x03520000 - 0x0352e000 C:\Arquivos de programas\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
0x7c340000 - 0x7c396000 C:\WINDOWS\system32\MSVCR71.dll
0x03680000 - 0x036b7000 C:\Arquivos de programas\Scpad\scpsssh2.dll
0x036d0000 - 0x0372f000 C:\Arquivos de programas\Scpad\scpMIB.dll
0x03860000 - 0x03869000 C:\Arquivos de programas\Scpad\sshib.dll
0x6d740000 - 0x6d78d000 C:\Arquivos de programas\Java\jre1.6.0_11\bin\ssv.dll
0x03990000 - 0x03a66000 C:\Arquivos de programas\GbPlugin\gbiehabn.dll
0x6d440000 - 0x6d44b000 C:\Arquivos de programas\Java\jre1.6.0_11\bin\jp2ssv.dll
0x6dab0000 - 0x6dac2000 C:\Arquivos de programas\Java\jre1.6.0_11\lib\deploy\jqs\ie\jqs_plugin.dll
0x71a10000 - 0x71a50000 C:\WINDOWS\system32\mswsock.dll
0x60b30000 - 0x60b88000 C:\WINDOWS\system32\hnetcfg.dll
0x71a50000 - 0x71a58000 C:\WINDOWS\System32\wshtcpip.dll
0x03a70000 - 0x03b2e000 C:\Arquivos de programas\Hauri\ViRobot Desktop 5.5\Service\hWebMan.dll
0x72fb0000 - 0x72fd6000 C:\WINDOWS\system32\WINSPOOL.DRV
0x76ec0000 - 0x76efc000 C:\WINDOWS\system32\RASAPI32.dll
0x76e70000 - 0x76e82000 C:\WINDOWS\system32\rasman.dll
0x5bcb0000 - 0x5bd05000 C:\WINDOWS\system32\NETAPI32.dll
0x76e90000 - 0x76ebf000 C:\WINDOWS\system32\TAPI32.dll
0x76e60000 - 0x76e6e000 C:\WINDOWS\system32\rtutils.dll
0x76b20000 - 0x76b4e000 C:\WINDOWS\system32\WINMM.dll
0x5d1d0000 - 0x5d1d7000 C:\WINDOWS\system32\serwvdrv.dll
0x5b4f0000 - 0x5b4f7000 C:\WINDOWS\system32\umdmxfrm.dll
0x769a0000 - 0x76a55000 C:\WINDOWS\system32\USERENV.dll
0x77c50000 - 0x77c74000 C:\WINDOWS\system32\msv1_0.dll
0x76d40000 - 0x76d59000 C:\WINDOWS\system32\iphlpapi.dll
0x68000000 - 0x68036000 C:\WINDOWS\system32\rsaenh.dll
0x72280000 - 0x72285000 C:\WINDOWS\system32\sensapi.dll
0x76fa0000 - 0x76fa6000 C:\WINDOWS\system32\rasadhlp.dll
0x76f00000 - 0x76f27000 C:\WINDOWS\system32\DNSAPI.dll
0x76f90000 - 0x76f98000 C:\WINDOWS\System32\winrnr.dll
0x76f40000 - 0x76f6d000 C:\WINDOWS\system32\WLDAP32.dll
0x71d10000 - 0x71d2b000 C:\WINDOWS\system32\ACTXPRXY.DLL
0x04210000 - 0x04222000 C:\WINDOWS\system32\SnEngine.DLL
0x76be0000 - 0x76c0e000 C:\WINDOWS\system32\credui.dll
0x5e540000 - 0x5e54d000 C:\WINDOWS\system32\pstorec.dll
0x76b00000 - 0x76b11000 C:\WINDOWS\system32\ATL.DLL
0x77a60000 - 0x77af6000 C:\WINDOWS\system32\CRYPT32.dll
0x77b00000 - 0x77b12000 C:\WINDOWS\system32\MSASN1.dll
0x75f50000 - 0x7604d000 C:\WINDOWS\system32\browseui.dll
0x71f50000 - 0x71f54000 C:\WINDOWS\system32\security.dll
0x40d80000 - 0x410f4000 C:\WINDOWS\system32\mshtml.dll
0x042f0000 - 0x04319000 C:\WINDOWS\system32\msls31.dll
0x42e50000 - 0x42eb0000 C:\WINDOWS\system32\ieapfltr.dll
0x76c10000 - 0x76c3e000 C:\WINDOWS\system32\WINTRUST.dll
0x76c70000 - 0x76c98000 C:\WINDOWS\system32\IMAGEHLP.dll
0x77670000 - 0x77691000 C:\WINDOWS\system32\NTMARTA.DLL
0x71bc0000 - 0x71bd3000 C:\WINDOWS\system32\SAMLIB.dll
0x75c20000 - 0x75c9d000 C:\WINDOWS\system32\jscript.dll
0x74c40000 - 0x74c6c000 C:\WINDOWS\system32\OLEACC.DLL
0x76050000 - 0x760b5000 C:\WINDOWS\system32\MSVCP60.dll
0x42830000 - 0x42869000 C:\WINDOWS\system32\Dxtrans.dll
0x6d990000 - 0x6d99a000 C:\WINDOWS\system32\ddrawex.dll
0x73710000 - 0x7375b000 C:\WINDOWS\system32\DDRAW.dll
0x73b70000 - 0x73b76000 C:\WINDOWS\system32\DCIMAN32.dll
0x42720000 - 0x42777000 C:\WINDOWS\system32\Dxtmsft.dll
0x1b000000 - 0x1b00c000 C:\WINDOWS\system32\ImgUtil.dll
0x42540000 - 0x4254e000 C:\WINDOWS\system32\pngfilt.dll
0x07e50000 - 0x082d8000 C:\WINDOWS\system32\Macromed\Flash\Flash10b.ocx
0x76380000 - 0x763c8000 C:\WINDOWS\system32\COMDLG32.dll
0x73ae0000 - 0x73af5000 C:\WINDOWS\system32\mscms.dll
0x72cd0000 - 0x72cd9000 C:\WINDOWS\system32\wdmaud.drv
0x72cc0000 - 0x72cc8000 C:\WINDOWS\system32\msacm32.drv
0x77bc0000 - 0x77bd5000 C:\WINDOWS\system32\MSACM32.dll
0x77bb0000 - 0x77bb7000 C:\WINDOWS\system32\midimap.dll
0x767d0000 - 0x767f7000 C:\WINDOWS\system32\schannel.dll
0x58760000 - 0x58792000 C:\WINDOWS\system32\iepeers.dll
0x74940000 - 0x74a54000 C:\WINDOWS\system32\msxml3.dll
0x68100000 - 0x68126000 C:\WINDOWS\system32\dssenh.dll
0x765b0000 - 0x765c3000 C:\WINDOWS\system32\cryptnet.dll
0x4d5a0000 - 0x4d5f9000 C:\WINDOWS\system32\WINHTTP.dll
0x74d50000 - 0x74dbb000 C:\WINDOWS\system32\USP10.dll
0x732b0000 - 0x73319000 C:\WINDOWS\system32\vbscript.dll
0x76800000 - 0x76815000 C:\WINDOWS\system32\HLINK.DLL
0x43300000 - 0x43377000 C:\WINDOWS\system32\mshtmled.dll
0x6d410000 - 0x6d42c000 C:\Arquivos de programas\Java\jre1.6.0_11\bin\jp2iexp.dll
0x71a90000 - 0x71a9a000 C:\WINDOWS\system32\wsock32.dll
0x0b970000 - 0x0bbc6000 C:\ARQUIV~1\Java\JRE16~1.0_1\bin\client\jvm.dll
0x6d280000 - 0x6d288000 C:\ARQUIV~1\Java\JRE16~1.0_1\bin\hpi.dll
VM Arguments:
jvm_args: -Xbootclasspath/a:C:\ARQUIV~1\Java\JRE16~1.0_1\lib\deploy.jar;C:\ARQUIV~1\Java\JRE16~1.0_1\lib\javaws.jar;C:\ARQUIV~1\Java\JRE16~1.0_1\lib\plugin.jar -Xmx16m -Djava.awt.headless=true -Dkernel.background.download=false -Dkernel.download.dialog=false -XX:MaxDirectMemorySize=64m
java_command: <unknown>
Launcher Type: generic
Environment Variables:
PATH=C:\Arquivos de programas\Internet Explorer;;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
USERNAME=paulo
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 15 Model 4 Stepping 9, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows XP Build 2600 Service Pack 3
CPU:total 1 (1 cores per cpu, 1 threads per core) family 15 model 4 stepping 9, cmov, cx8, fxsr, mmx, sse, sse2, sse3
Memory: 4k page, physical 981424k(331420k free), swap 2369040k(1593244k free)
vm_info: Java HotSpot(TM) Client VM (11.0-b16) for windows-x86 JRE (1.6.0_11-b03), built on Nov 10 2008 02:15:12 by "java_re" with MS VC++ 7.1
time: Thu Jun 25 09:27:57 2009
elapsed time: 3764 seconds
Registers:
Other Threads:
Heap
Dynamic libraries:
VM Arguments:
USERNAME=paulo
OS=Windows_NT
