ivanildoj
Usuário Registrado
Eu vou comprar um HD externo e estava dando uma olhada nesses modelos de gavetas para HD, e gostaria de saber se alguém de vc ja usou eles, se elas são boas, e tem algum outro modelo que tenha as mesmas funções desses dois modelos, ou seja com HDD PLAYER?????
a primeira
Caracteristicas:
HDD type: Support 3.5 inchi IDE HDD (not included) storage capacity up to 500G
HDD file system: FAT 32, NTFS
Support Music/photo slide show and .lrc MP3 lyric diaplay
Subtitle support: smi srt sub txt psb ass ssa
Support file copy,rename,delete
Support multi lanuage and multi power
Video outputs: composite (RCA); VGA ;S-Video;AV
Audio outputs: stereo 2-ch (RCA)
Fan cooler inside and LCD display
Remote control and panel button control
TV type: NTSC, PAL
Video formats: DVD, MPEG1-4 / DivX / XviD / VCD ,DIVX3.X-5.X
Audio format: MP3
Photo format: JPEG ,BMP,GIF
File formats AVI, ASF, VOB, DAT, MP4, MPG
One button backup
Power supply AC 100~240V AC in; 5.5/2A 12VA DC OUT
Dimensions: 206 x 116x 40mm
Gross weight:1.6kg
OS: Windows 98/98SE/2000/ME/XP, Mac, Linux
PC interface: 480Mbps USB 2.0 high-speed (USB1.1 backwards compatible)
a segunda
ESPECIFICAÇOES:
Features of
Audio signal
Output
Frequency response
20Hz-22Hz
S/N ratio
>=90dB (1kHz 0dB)
Dynamic range
>=80 dB (1kHz 0dB)
THD
0.04%
Audio distortion
Lower than test level
Crosstalk
>=80 dB (1kHz 0dB)
Hard disk
3.5 inch , 500Gb
Remote control system
Infrared pulse ,DC3v, button battery
Description
Detailed instruction
Power supply
DC 12V/2A5V/2A
Power consumption
<=800mA
Video system
AUTO/NTSC/PAL
Dimension
200*113*35mm
Weight
376g
Playable program
MPEG4, DVD, SVCD, VCD,JPEG, MP3 CD-DA
Video output
1Vp-p +/- 0.1 (750ohm)
Audio output
2.0Vrms +/- 0.3V
a primeira
Caracteristicas:
TV type: NTSC, PAL
Audio format: MP3
One button backup
Gross weight:1.6kg
a segunda
ESPECIFICAÇOES:
Features of
Audio signal
Output
Frequency response
20Hz-22Hz
S/N ratio
>=90dB (1kHz 0dB)
Dynamic range
>=80 dB (1kHz 0dB)
THD
0.04%
Audio distortion
Crosstalk
>=80 dB (1kHz 0dB)
Hard disk
3.5 inch , 500Gb
Description
Power supply
DC 12V/2A5V/2A
Power consumption
<=800mA
Video system
AUTO/NTSC/PAL
Dimension
200*113*35mm
Weight
376g
Playable program
Video output
Audio output
2.0Vrms +/- 0.3V
