[TÓPICO OFICIAL] Instalação e Configuração de Emuladores de jogos.
Sou entusiasta do Final Burn e possuo, acredito que, a melhor coleção do mundo sobre o emulador, são roms absurdamente raras, anos garimpando arquivos.
vou deixar listado meus fullsets, todos 100% completos de verdade, se alguém quiser alguma rom em específico, só falar
Final Burn Alpha 0.2.50 - 170 sets
Final Burn Alpha 0.2.60 - 178 sets
Final Burn Alpha 0.2.94 - 235 sets
Final Burn Alpha 0.2.96.68 - 766 sets
Final Burn Alpha 0.2.96.72 - 871 sets
Final Burn Alpha 0.2.96.74 - 1048 sets
Final Burn Alpha 0.2.96.75 - 1090 sets
Final Burn Alpha 0.2.96.77 - 1156 sets
Final Burn Alpha 0.2.96.86 - 1526 sets
Final Burn Alpha 0.2.96.96 - 1650 sets
Final Burn Alpha 0.2.97.02 - 1902 sets
Final Burn Alpha 0.2.97.05 - 2302 sets
Final Burn Alpha 0.2.97.08 - 2888 sets
Final Burn Alpha 0.2.97.10 - 3252 sets
Final Burn Alpha 0.2.97.12 - 4915 sets
Final Burn Alpha 0.2.97.17 - 5036 sets
Final Burn Alpha 0.2.97.21 - 5496 sets
Final Burn Alpha 0.2.97.24 - 5540 sets
Final Burn Alpha 0.2.97.27 - 5699 sets
Final Burn Alpha 0.2.97.29 - 5833 sets
Final Burn Alpha 0.2.97.31 - 6047 sets
Final Burn Alpha 0.2.97.33 - 6617 sets
Final Burn Alpha 0.2.97.35 - 8190 sets
Final Burn Alpha 0.2.97.37 - 8450 sets
Final Burn Alpha 0.2.97.39 - 9934 sets
Final Burn Alpha 0.2.97.42 - 10490 sets
Final Burn Alpha 0.2.97.43 - 10920 sets
Final Burn Alpha 0.2.97.44 - 11725 sets
Final Burn Neo A 0.2.97.44 - 12022 sets
Final Burn Neo B 0.2.97.44 - 13835 sets
Final Burn Neo 1.0.0.00 - 14989 sets
Final Burn Neo A 1.0.0.01 - 15541 sets
Final Burn Neo B 1.0.0.01 - 15991 sets
Final Burn Neo 1.0.0.02 - 16615 sets
Final Burn Neo A 1.0.0.03 - 17492 sets
Final Burn Neo B 1.0.0.03 - 18153 sets
Final Burn Neo C 1.0.0.03 - 18552 sets (WIP)
Final Burn Evolution 3.04 - 825 sets
Final Burn Plus 0.2.97.41 - 7567 sets
Final Burn Shuffle 0.2.97.06 - 2116 sets
Final Burn Shuffle 0.2.97.08 - 2552 sets
Final Burn Shuffle 2.2.5 2012 - 3039 sets (CreamyMami)
Final Burn Shuffle 2.4.0 2016 - 3710 sets (CreamyMami)
Final Burn Shuffle 2.4.0 2021 - 5676 sets (CreamyMami)
Final Burn Shuffle 2.4.0 2022 - 6100 sets (CreamyMami)
Final Burn Shuffle 2.3.0 2012 - 5749 sets (KOF2112)
Final Burn Shuffle 2.4.0 2016 - 6437 sets (KOF2112)
Final Burn Shuffle 2.4.0 2020 - 8306 sets (KOF2112)
Final Burn Shuffle 2.4.0 2022 - 9554 sets (KOF2112)
Caraca irmao, que fissura eh essa pelo Final Burn!
Pq nao usa o romset mais atual apenas?
Ouve algum jogo retirado nessas atualizacoes?
Pq o mais atual não significa que possui todos os jogos, inclusive alguns jogos só rodam em apenas 1 única versão do emulador e mais nenhum outro, tem 1 jogo de megadrive assim
outro exemplo se vc quiser rodar Killer Instinct de Arcade no Neo por hora não dá, exceto na versão debug, não indicada pra usuários comuns, e no Alpha, mais antigo vc consegue
outra diferença são versões de roms diferentes de um mesmo jogo, num emulador roda versão X que possue muitas diferenças pra rom Y que roda em outro emulador, essas mudanças podem ser pra melhor ou pra pior dependendo do jogo, pra algumas pessoas isso faz diferença.
e o Shuffle é um Fork diferenciado com elementos de outros emuladores e tem vários hacks e determinadas variantes exclusivas, especialmente do mercado asiático, que por sua vez tbm não tem no Alpha e no Neo, esse Fork está ativo e em desenvolvimento até hoje.
Por fim quem não quer ter tudo e só os jogos principais ou limitar os sistemas pode optar por versões mais antigas, que ainda rodam em qualquer windows atual normalmente e são absurdamente mais leves, pra quem tem um PC velho é uma ótima opção.
Qdo ocorrem retiradas eh pq o jogo nao esta 100% emulado corretamente, o que nao impede que joguemos de alguma forma e nos divirta tb.
Eu como quero a emulacao a mais perfeita possivel e tenho maquina pra isso, uso a ultima versao mesmo com algumas privacoes...porem a situacao eh valida pra maquinas mais antigas (ou raspiberry, no meu caso...uso mame 2003 plus).
De qualquer forma, eh uma colecao invejavel...
Sim, o jogo pode não estar emulado 100%, caso do Killer Instinct, mas não é nada grave que impeça a pessoa de se divertir como vc disse
acontece tbm, que hoje, os devs principais estão mais bitolados com a qualidade da rom e até do dump, e qualquer coisa remove o jogo temporariamente, na verdade eles sempre tem centenas de novas roms a espera de suporte
só que tem vários outros motivos tbm, alguns jogos como homebrews (vendidas ou não) acaba dando umas tretas com "licença" entre os criadores, eu acompanho alguns fóruns e isso trava até o lançamento de novas builds, os caras mandam roms pros devs pra dar suporte e pra ter como só eles sozinhos jogarem fora do hardware físico, mas não querem que os jogos vazem na internet ou que mais alguém jogue....
isso causa algumas remoções no meio do processo
quanto ao que vc disse sobre emulação perfeita, discordo em parte, então vc deve evitar as builds mais atuais, mesmo elas sendo mais recentes e tendo centenas de jogos a mais, não são as mais estáveis ou com menos bugs
o branch atual do Final Burn Neo ainda é uma versão beta e as vezes quase um alpha dependendo da build, aparecem bugs bizarros, build nova tem toda semana pra não dizer todo dia
se vc realmente quer qualidade deve optar pela última versão final oficial, no caso o Final Burn Neo 1.0.0.02, normalmente a que indico para amigos, e não usar o mais atual por mais tentador que seja ter 2 mil jogos a mais, o Shuffle é um eterno beta desde a primeira versão, mas ninguém liga pra isso
só por curiosidade, o Shuffle usa partes do mame plus e tbm de outros emus.
Boa tarde tudo bem? Estou com problema no meu emuelec 3.5 o controle dele foi desconfigurado, quando ligo a minha tvbox ele inicia a tela e aparece essa notificação generic parallel port device 0/0 nao configurado. E não consigo fazer nada, consegue me ajudar?
Alguém aí conhece sobre emuladores de N64 e SNES para Android? Estou procurando por algum, mas existem tantos que eu to meio perdido
Tenta um teclado usb
Snes9x EX+ e Mupen64Plus FZ
Vão colocar emuladores de Switch ou como essa parte do fórum é de Retro não rola? Só achei que um tópico unificado como esse é uma boa fonte de conhecimento.
Estou tendo problemas em acertar o controle do PS4 no PC, usando o Project64.
O que acontece:
O botão Z do controle do N64 geralmente alinhamos ele no L2/ LT, pois entao eu configurei mas o mesmo tanto no L2 como no R2, ele aparece mapeado corretamente mas no jogo, nao funciona, porem se configuro pro L1/R1 ou algum outro botão vai de boas.
Tenho minha duvida que os 2 são gatilhos e no DS4Windows não achei como deixar no emulador os dois botoes como binários(clique somente).
Se uso o controle SF30 da 8Bitdo nao tenho esse problema.
Tô precisando de uns temas bonitos para ADVmenu plus para mame, mega drive e nintendo Nes. Alguém tem?
Uma ótima opção para voltar a jogar emuladores no XS.
Pessoal, sou bem newbie em emulação. Um amigo me indicou uma front end pra pc chamada pra Coinops pra pc e achei sensacional. Já vem tudo montadinho, com as roms e uma interface incrível.
Vocês indicam alguma coisa assim pra Android?
Pessoal o 5600g + 3050 não esta dando conta no Xemu.
Testei o Panzer Dragoon Orta e não está segurando 60fps. mesmo em 1x
Não sei se os drops ocorrem no original.
O emulador tem a opção dos shaders cache parecida do Yuzu.
Até rejoguei a primeira fase, mas os drops continuam .
Outra coisa que não mostra a API dele (vulkan/OPGL).
Pessoal,
Estou com um optiplex 3060 para fazer um pczinho retro. Jogamos fds na casa de um amigo naqueles game stick que vai na hdmi e a patroa curtiu.
O hardware é ok, i5 de 8ª e 12gb de ram, a gpu é a integrada. Acredito que me atenda no que quero (ps1 pra baixo, talvez algo de ps2).
Ainda vale a pena usar o Retroarch? Ou ir pra um Batocera ou recalbox?
O pc será dedicado a isso basicamente, ssd pro sistema e um hd de 1tb pros jogos.
Pessoal,
Rapaz, está com um equipamento que roda tudo, eu acho que usando e configurando, qualquer emulador para se dedicar, ficará show.
Pessoal, alguém já usaram aqueles conversores de hdmi para AV genéricos?
Seria Ligar na tv tubo e ajustar a resolução do emu, por exemplo snes para a resolução original.
Será que funciona?
Pessoal, quais pastas/arquivos do Yuzu e Ryujins que são os savefiles dos jogos?
Vou precisar fazer backup pois irei formatar meu PC..
Prezados Amigos, por favor preciso de ajuda para montar um PC o mais barato possível e que dê conta de emular bem o Nintendo switch, principamente os jogos do mario, como o odyssey. Para criança autista que é fissurada em Mário Bros E está perdendo a visão, para ela aproveitar e Jogar enquanto ainda é possível. A barra está pesada, muitos gastos com saúde, não consigo comprar nunca um Nintendo switch, quanto mais os jogos. O veneno já está nas veias, meu irmão deixou um emprestado com Mario odyssey 4 anos atrás do uns 5 meses, meu pequeno jogava sempre, daí veio a.minha sobrinha chegar ao mundo e meu irmão vendeu o Nintendo switch e não há UM SÓ dia Desde então em que eu não ouça Mario odyssey isto ou aquilo. Em plena pandemia consegui pegar um Wii usado e... não surtiu bem o mesmo efeito, até que enganouum pouco, mas, quebrou. Ajudem-me por favor. Grato mesmo!
Vou aproveitar o vasto conhecimento do @Sonymaster e consultá-lo. Sabe algum emulador de SNES ou NES que funcione controle Wireless? Queria jogar no conforto da minha cama, mas tá difícil ficar no limite de um cabo de 1m >:C
Vou aproveitar o vasto conhecimento do @Sonymaster e consultá-lo. Sabe algum emulador de SNES ou NES que funcione controle Wireless? Queria jogar no conforto da minha cada, mas tá difícil ficar no limite de um cabo de 1m >:C
Se o windows detecta, qualquer emulador deve rodar.
Soh configurar o emu e jogar.
Rapaz, eu sempre jogo com controle de cabo. Ainda mais esses simples estilo SNES USB, usando o ClassicBoy no app Android para Smart TV.
Mas é exatamente isso, eu uso o Ipega em celular com o mesmo aplicativo ClassicBoy e jogo de boa.
Mobile não xD Me refiro a emuladores de PC mesmo, esqueci de mencionar :V
Para ser sincero faz muito tempo que não uso emulador no PC, na verdade, os que tenho guardados, são antigos ainda, específico para cada console. Não tipo um multi como retroarch. Depois de consoles chineses que tem aos montes e app Mobile e Smart TV.
Nem liguei muito para parte do PC.
O PC reconhecendo o controle, qualquer emulador vai identificar, até porque ele não vai saber se é sem fio ou não, só que existe um controle conectado.
Eu jogo usando o controle do Xbox one sem fio.
