Alguem conhece ou tem esse monitor? Gostaria de opniões a respeito dele...
Essas são as especificações dele...
Screen Size 22.0"
Resolution 1680 x 1050 (WSXGA+)
Pixel Pitch 0.282
Brightness 300 cd/m2
Contrast Ratio 700:1
Response Time 5ms (2+3) ms
Display Area 473.76 x 296.1(mm)
Display Color 16.7 million
Viewing Angle 170/160 (CR>=10)
Input Signals D-Sub/DVI-D
Horizontal Frequency (KHz) 30 - 82
Vertical Frequency (Hz) 56 - 76
Video Bandwidth (MHZ) 25 - 165
Color Temperature Reddish/Normal/Bluish + user mode
Power Consumption 49W (max)
Power Supply Built-in
Product Color Silver-Black/Black-Black
Features Vesa Wall Mounting (100 x 100 mm)
i-Key
Kensington Lock
Adjustments Tilt -2/22
Dimensions (WxHxD) 422.45x518.26x169.57mm
Weight 5.8 kg
Accessories VGA and DVI cable (depend on region)
Emission Standard TCO03
Screen Size 22.0"
Pixel Pitch 0.282
i-Key
Kensington Lock
Weight 5.8 kg
