a minha net fica caindo toda hora o modem e um sb5100 e ele da um log de erro sempre depois. da pra usar uns 2 minutos o suficiente pra abrir uma pagina na internet e depois ele cai de vez, resetando e apagando as luzes, e entao demora mais um pouco e volta ao normal, mas ai so da pra usar por mais um tempo, e o ciclo vicioso continua ... o log de erro na config dele foi essa: oq sera q pode estar causando o problema??
2009-02-16 19:37:24 4-Error E206.0 Improper Configuration File CVC Format
2009-02-16 19:37:22 3-Critical D003.0 DHCP WARNING - Non-critical field invalid in response.
2009-02-16 19:37:10 3-Critical R004.0 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 timeout
2009-02-16 19:36:24 4-Error E206.0 Improper Configuration File CVC Format
2009-02-16 19:36:23 3-Critical D003.0 DHCP WARNING - Non-critical field invalid in response.
2009-02-16 19:36:11 3-Critical R004.0 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 timeout
2009-02-16 19:35:24 4-Error E206.0 Improper Configuration File CVC Format
2009-02-16 19:35:22 3-Critical D003.0 DHCP WARNING - Non-critical field invalid in response.
2009-02-16 19:35:10 3-Critical R004.0 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 timeout
2009-02-16 19:34:06 4-Error E206.0 Improper Configuration File CVC Format
2009-02-16 19:34:04 3-Critical D003.0 DHCP WARNING - Non-critical field invalid in response.
2009-02-16 19:33:51 3-Critical R004.0 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 timeout
2009-02-16 19:33:05 4-Error E206.0 Improper Configuration File CVC Format
1970-01-01 00:00:52 3-Critical D003.0 DHCP WARNING - Non-critical field invalid in response.
1970-01-01 00:00:43 3-Critical R002.0 No Ranging Response received - T3 time-out
1970-01-01 00:00:32 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
1970-01-01 00:00:32 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
1970-01-01 00:00:30 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
1970-01-01 00:00:30 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
1970-01-01 00:00:26 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
1970-01-01 00:00:26 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
1970-01-01 00:00:23 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
1970-01-01 00:00:23 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
1970-01-01 00:00:03 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
1970-01-01 00:00:03 3-Critical T001.0 SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
1970-01-01 00:00:01 3-Critical T002.0 SYNC Timing Synchronization failure - Failed to acquire FEC framing
