Moto X Style XT1542
![moto_xpure_featureexpanded_dualsim.jpg](http://www.motorola.com.br/sites/default/files/styles/tiles_template_1_-_desktop_1x/public/library/storage/products/moto-x-style/desktop/br/moto_xpure_featureexpanded_dualsim.jpg?itok=SRt-BOZ7×tamp=1440684632)
![moto_xstyle_featexp_splashguard_1_d.jpg](http://www.motorola.com.br/sites/default/files/styles/tiles_template_1_-_desktop_1x/public/library/storage/products/moto-x-style/desktop/global/moto_xstyle_featexp_splashguard_1_d.jpg?itok=35CdoZUk×tamp=1440430224)
![moto_xstyle_featexp_entertainment_1_d.jpg](http://www.motorola.com.br/sites/default/files/styles/tiles_template_1_-_desktop_1x/public/library/storage/products/moto-x-style/desktop/global/moto_xstyle_featexp_entertainment_1_d.jpg?itok=_R074IWF×tamp=1440430224)
![moto_xstyle_featexp_design_3_d.jpg](http://www.motorola.com.br/sites/default/files/styles/tiles_template_6_-_desktop_1x/public/library/storage/products/moto-x-style/desktop/global/moto_xstyle_featexp_design_3_d.jpg?itok=jyaGjE-j×tamp=1440430224)
![moto_xstyle_featexp_experience_1_d.jpg](http://www.motorola.com.br/sites/default/files/styles/tiles_template_6_-_desktop_1x/public/library/storage/products/moto-x-style/desktop/br/moto_xstyle_featexp_experience_1_d.jpg?itok=ziEoiEbz×tamp=1440684632)
Sistema Operacional
Android™ 5.1.1, Lollipop
Processador
Sistema de computação móvel Motorola que inclui um processador hexa-core Qualcomm® Snapdragon™ 808 de 1,8 GHz (Dual-core 1.8 GHz + Quad-core 1.4 GHz), GPU Adreno 418 @ 600Mhz, processador de linguagem natural e processador de computação contextual
Memória (RAM)
3GB LPDDR3
Armazenamento (ROM)
32 GB
Suporte a cartão micro SD (até 128 GB)
Dimensões
Altura: 153,9 mm
Largura: 76,2 mm
Espessura (curva): 6,1 a 11,06 mm
Peso
179g
Tela
LCD IPS TFT de 5.7”
Quad HD (1440x2560) de 1440p
520 ppi
Corning® Gorilla® Glass 3
Bateria
Bateria que dura o dia todo (3000 mAh) Carregamento TurboPower™ 25
Repelente à água*
P2i – revestimento repelente a respingos d’água
Redes
LTE cat. 4 (até 150Mbps)
WCDMA
GSM/EDGE
Bandas
GSM/GPRS/EDGE (850, 900, 1800, 1900 MHz)
UMTS/HSPA+ (850, 900, 1700, 1900, 2100 MHz)
4G LTE (2, 3, 4, 5, 7, 17, 28)
Câmera Traseira
21 MP
Abertura de f/2,0
Foco automático de detecção de fase (PDAF)
Processamento de loop fechado
Flash duplo com equilíbrio de cores (CCT) Câmera instantânea
Zoom digital de 4X
Disparo contínuo
Modo noturno
Auto HDR
Panorama
Arraste para definir foco e exposição
Estabilização de vídeo
Vídeo em HD de 1080p (60 fps)
Vídeo de 4K (30 fps)
Vídeo em slow motion
Vídeo HDR (1080p e 4K)
Câmera Frontal
5 MP
Abertura de f/2,0
Lente com ângulo amplo de 87°
Modo noturno
Flash
Cartão SIM
Dual-Chip inteligente
Nano SIM
Conectividade
Micro USB, conector do fone de ouvido de 3,5 mm
Tecnologia Bluetooth®
Bluetooth versão 4.1 LE
Wi-Fi
802.11a/g/b/n/ac + MIMO
Viva - Voz
Alto-falantes estéreo frontais com Smartboost
Captura de vídeo
1080p (60 fps); 4K (30 fps)
NFC
Sim
Serviços de Localização
GPS
GLONASS
Modelos básicos
Preto com acabamento metálico cinza escuro
Branco com acabamento metálico dourado
Branco e bambu com acabamento metálico prata
Acabamento traseiro
Escolha entre uma das 12 cores disponíveis no Moto Maker.
Detalhes
Escolha entre 7 tons metálicos para o acabamento da câmera, disponível no Moto Maker.
O kit acompanha: um Bumper, Carregador TurboPower™ 25, Fone de ouvido, manual e logicamente o aparelho.
NÃO ACOMPANHA CABO DE DADOS
Preço Sugerido: R$2.499,00
Review Tudo Celular
Review Eu Testei
Agora você pode deixar o seu aparelho com a sua cara utilizando o Moto Maker
Para Detalhes da Compra ou do Pedido: 11 4003-8859 Segunda a Sábado das 8 às 20hs
Para Suporte Técnico de Produtos ou Reparo
Capitais e Regiões Metropolitanas
40021244
Segunda a Sexta das 8 às 21hs e aos Sábados das 08 às 18hs
Para outras localidades
08007731244
Dúvidas e sugestões serão sempre bem-vindos, se acharem promoção a vista ou a prazo, compartilhe conosco.
