Aqui nao apareceu ainda este update de 1,5 Gb, estou na experimental...Cara, muito legal isso. Podia se implementar isso para "caçar" npc´s na superficie dos planetas tambem.
editando: saiu os detalhes do 1.13
Hello!
We've released another patch across both PC and PS4 which is available to download on both platforms now! Read on for full patch notes:
Fixed a bug that would make the player character small.
Space battles will now vary in size more and players should see bigger battles.
Fixed the instantaneous death loop that could occur in survival mode if you saved with 1 health and no hazard protection. You will still be on the verge of death when you load in, but it won't happen instantaneously.
[PC] Fix for steam controller not being able to warp.
[PC] Removed up, down, left, right as quick menu navigation keys to allow left handed players to move while using the quick menu.
[PC] Page Up and Page down can now be used to navigate up and down in the quick menu. Removed duplicated planets from discoveries menu.
Fixed an issue with redeeming promo ships in survival, which would result in the ship being spawned above the ground.
Fix for missing ruins underwater which could cause missions to point to nothing.
Various audio tweaks and fixes:
- Added ladder climbing sounds.
- Fixed base building prop sounds not playing when placed inside a Freighter.
- Added sound effect for calling Freighters.
- Added sound effect when using communication stations.
- Fixed an issue which could affect ambient sound in Freighters.
- Changed the sound effect when using the Terminus Teleporter.
Ae sim, es
Eu sei que voce é um "cão vigilante" agora.
Sem querer, entrando em uma batalha no espaço eu acertei as naves erradas...KKKKKKKKKKKKKKk..e fiquei ja de wanted...mas nem tentei enfrentar...fui no cargueiro na hora e pousei e ai o nivel de perseguição foi pro "espaço"!!!
Editando: E pondo um video para dar uma melhorada no visual do topico.
Ae sim, este video que deveria estar na loja da Steam.
