Opinião, melhor Notebook!
reeves
Galera ajuda aí,qual desse dois abaixos é melhor custoxbenefício?
Acer Aspire AS3613WLMi Notebook PC - $805,00 (Dólar)
Processor: Celeron M 370; Memory: 512MB DDRII; Hard Drive: 80GB; Optical: DVD-Dual; LCD: 15.4"ACB; Graphics: Intel GMA 900; Wirelss: 802.11 bg; Battery: 4 cell; Windows XP Professional
Enjoy great computing value where you want it, when you want it, without sacrificing the features you want. The slim and light Acer Aspire 3610 comes with the hottest notebook options brilliant widescreen displays, enhanced processing power, DVD-Dual double-layer burning capability, Acer InviLink 802.11b/g wireless capabilityand much more all at a value-class price.
Specifications:
Processor Brand: Intel
Processor Class: Celeron M Processor 1.5GHz
Memory Type: DDR2 512MB
Memory Speed: DDR2 400
MemorySlots (Total): 2
Capacity: 80GB
Optical Drive Type: DVDRW
Graphics Description: Integrated Graphics
Intel 910GML integrated 3D graphics
Integrated Modem; Integrated LAN; Integrated Wireless LAN
Interface Type: Acer InviLink 802.11b/g wireless LAN;
RJ-11 Phone Connector; RJ-45 Ethernet Connector
Display Type: WXGA TFT LCD with Crystal Bright Technology
Viewable Screen Size: 15.4"
Width: 14.3" x Height: 1.3" x Depth:10.8"
Weight: 6.1 lbs
ou
NB TOS TECRA A8-EZ8311 1.6/512/60/COMBO - $825,00 (Dólar)
Highlights
Tecra A8 notebook computers are designed to be high-end desktop replacements with the added benefit of mobility and durability. All Tecra A8 notebook computers feature brilliant 15.4-inch widescreen LCD displays and TV-out capabilities, integrated 802.11a/g wireless connectivity, and 512MB of DDR2 memory architecture. They also come equipped with fingerprint readers for added security. Specifications
Product Description Toshiba Tecra A8-EZ8311 - Celeron M 420 1.6 GHz - 15.4" TFT
Dimensions (WxDxH) 14.5 in x 10.6 in x 1.5 in
Weight 6.4 lbs
System Type Notebook
Built-in Devices Stereo speakers, wireless LAN antenna
Processor Intel Celeron M 420 1.6 GHz
Cache Memory 1 MB - L2 cache
RAM 512 MB DDR II SDRAM - 533 MHz - PC2-4200
Card Reader Yes
Hard Drive 60 GB - Serial ATA-150 - 5400 rpm
Optical Storage CD-RW / DVD-ROM combo
Display 15.4" TFT active matrix 1280 x 800 ( WXGA )
Graphics Controller ATI Radeon Xpress 200M
Audio Output Sound card
Telecom Fax / modem
Networking Network adapter - Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
Input Device Keyboard, touchpad
Power AC 120/230 V ( 50/60 Hz )
Run Time (Up To) 4.1 hour(s)
Operating System Microsoft Windows XP Professional
Manufacturer Warranty 1 year warranty
Caso vcs conheçam outro na mesma faixa de preço, deixem sau opinião!!!
Mr.Kernell32
O Toshiba é o melhor, devido a condição da memória (barramento 533), chipset vídeo ATI Xpress 200M, que é melhor que o Intel GMA900, e óbvio, o processador.
A única vantagem do Acer é o gravador DVDrw e capacidade de HD, porém como você não disse qual tipo de atividade exercerá com o equipamento, estou supondo que o gravador de DVD é desnecessário. Apesar de que você possa usar um gravador externo de DVD e trocar o HD, enquanto que as outras peças como Vídeo e barramento não serem efetivados upgrade.
Outro ponto que não mencionei é a questão do leitor de digitais, que no Toshiba já está incluído, o que lhe dará uma segurança maior contra intrusos no acesso aos dados - de forma física - à sua máquina.
Gargula
Gamer since 1994!
Com certeza Toshiba :yes:
reeves
Galera esse Toshiba eu poderei fazer upgrade futuramente por um gravador de DVD interno?
Outra dúvida, ele tem tecnoligia 64Bits, com a chegada do VISTA poderei fazer uso nele futuramente?
reeves
????????? :cry:
Uria
- 888
interno?? não..
poderá usar o vista sim.. mas primeiro precisará colocar mais memoria.. vista, pelo que me lembro, necessita de ao menos 768 de ram.. =p
Billy Gun
São boas máquinas... mas vou dizer... pesquise melhor, eu li em algum lugar, acho que foi no baboo, que estes notebooks com Pentium M nao serao capazes de fazer o Aero Glass do Windows Vista Funcionar, li que os que usam Turion possuem placa de video melhor, procure pesquisar um pouco sobre isso.
Pesquise sobre isso no forum sobre o windows vista no site do baboo
Os Celeron M, trabalham em 64bits? acho que não em... pesquise isso, os turion trabalham também em 64 bits.
E veja que tem notes com turion X2 (os 2 últimos) com preços bons...
http://www.newegg.com/Product/Product.asp?Item=N82E16834115255
http://www.newegg.com/Product/Product.asp?Item=N82E16834147200
http://www.newegg.com/Product/Product.asp?Item=N82E16834147185
http://www.newegg.com/Product/Product.asp?Item=N82E16834115257
http://www.newegg.com/Product/Product.asp?Item=N82E16834147198
http://www.newegg.com/Product/Product.asp?Item=N82E16834115250
Rogola
fera?
Para o Vista vai precisar de mais memória, o Celeron não é 64 bits.
E a VGA do Toshiba é muito melhor que a do Acer.
Eu iria de toshiba.
