o pior que nao existe placa mid ate 250,00 so de 350 eu vi essas aqui e achei com muitos recursos queria a opnião de vcs
GigaByte GA-970A-UD3 (rev.3.0) - BOX Valor 365,00
Avalie! Placa mãe para Socket AM3+: Suporta processadores AMD (AM3+) série FX e AMD (AM3) série Phenom II / Athlon II, Hyper Transport Bus: 4800 MT/s, chipset: North Bridge: AMD 970, South Bridge: AMD SB950, memória: 4x 240pin (Dual Channel) DDR3 2000(O.C.), 1866, 1600, 1333, 1066 (até 32GB),Expansion Slots : 2x PCI Express 2.0 x16 (2º slot running at x4) - Support AMD CrossFireX, 3x PCI Express x1, 2x PCI, Storage: 6x SATA 6Gb/s support RAID 0, 1, 5, 10 and JBOD, Portas USB: 14x USB 2.0 (8 no painel traseiro, 6 internas), 4x USB 3.0 (2 no painel traseiro, 2 internas), Audio: VIA VT2021 7.1 HD Audio codec (suporta S/PDIF Out), LAN: 1 x Realtek GbE LAN chips (10/100/1000 Mbit).
GigaByte GA-970A-D3 (rev.3.0) - BOX Valor 365,00
Avalie! Placa mãe para Socket AM3+: Suporta processadores AMD (AM3+) série FX e AMD (AM3) série Phenom II / Athlon II, Hyper Transport Bus: 4800 MT/s, chipset: North Bridge: AMD 970, South Bridge: AMD SB950, memória: 4x 240pin (Dual Channel) DDR3 2000(O.C.), 1866, 1600, 1333, 1066 (até 32GB),Expansion Slots : 2x PCI Express 2.0 x16 (2º slot running at x4) - Support AMD CrossFireX, 3x PCI Express x1, 2x PCI, Storage: 6x SATA 6Gb/s support RAID 0, 1, 5, 10 and JBOD, Portas USB: 14x USB 2.0 (8 no painel traseiro, 6 nos conectores internos), 2x USB 3.0 (painel traseiro), Audio: VIA VT2021 7.1 HD Audio codec (suporta S/PDIF Out), LAN: 1 x Realtek Gigabit LAN chip (10/100/1000 Mbit)
Asus M5A97 LE R2.0 - BOX valor 390,00
Avalie! Placa mãe para Socket AM3+; Supports FX/ Phenom II/ Athlon II/ Sempron 100 Series Processors; Supports AM3+ 32 nm CPU; Supports CPU up to 8 cores; Supports CPU up to140W; Supports AMD Cool ´n´ Quiet Technology, Chipset: North Bridge AMD 970 & South Bridge SB950, Memory: 4x DDR3-2133(O.C.)/1866/1600/1333/1066 DIMM Slots, Dual Channel, ECC/Non-ECC, Un-buffered, Max Capacity of 32GB, Slots: 1x PCI-Express 2.0 x16 Slot, 1x PCI-Express 2.0 x16 Slot (runs at x4), 2x PCI-Express 2.0 x1 Slots, 2x PCI Slots, Multi-Graphics: Supports AMD Quad CrossFireX Technology, SATA: 6x SATA3 Ports, Support RAID 0, 1, 5, 10, Audio: Realtek ALC887 8-Channel High Definition Audio CODEC, LAN: Realtek 8111F Gigabit Ethernet Controller, Ports: 12x USB 2.0/1.1 Ports (6 rear, 6 at mid-board), 2x USB 3.0/2.0
Ate faço um esforço muito grande se valer apena mesmo pegar umas dessas e queria saber se tem muita diferença esse negocio de rev.
por exemplo a giga udd3 tem revisão 1.3(essa eu poderia pagar parcelado 1 ano de garantia 380,00) e 3.0(3 meses de garantia e mais barato 360,00)
tem alguma de 300 aonde com essas caracteristicas? desculpe me por me alongar demais e que faz uma decada que nao compro pc um pouco acima de low end.
Nesse valor não teria placa compativel com o que precisa mesmo, placas com SATA 6Gb e USB 3.0 estão na base dos 300 reais, e não existem placas com DDR2 AM3+ porque os processadores AM3+ só tem suporta a DDR3.
