Placa Mae SOYO????
Mcbjpario
Alguem tem o manual dessa placa mae SY-6BA+IV 66/100MHz FSB Slot 1 Based Intel 440BX ATX Motherboard???
duvida!!!
Eu tenho 1 processador celerom ( Soquete 370 ) de 600Mhz,sera q funciona nessa placa-mãe???
Bom esta aqui :
SY-6BA+IV Specifications
Processor
Supports the following processors
100 MHz FSB Pentium III Processors 450/500/550/600/650/700/750/800/850 MHz
100MHz FSB Pentium II 350/400/450 MHz
66MHz FSB Pentium II 233/266/300/333 MHz
66MHz FSB Celeron Processors 266~300 MHz
66MHz FSB Celeron Processors 300A~533 MHz with integrated 128KB full speed L2 cache
