http://4players.de/4players.php/down...oad/46386.html
http://www.pesleague.com/index.php?p...ficiel_pes2008
http://www.gamershell.com/download_21146.shtml
http://www.pcgames.de/aid,614367/Dow...r_2008_ist_da/
http://www.pcaction.de/?article_id=614352
PES 2008 Skill Moves List
Heel Dash
Not everyone has it, C.Ronaldo and Henry got it for sure.
R1+90 Degrees direction while running or trapping ball.
Explanation:
http://youtube.com/watch?v=9zKHMHkJjcs
Nutmeg
While standing with R2, Press Back+R2 and Forward+R2 quickly.
Diving
L1+L2+R1
Shirt Pull
R1+X
Look Up Cross
L1+R1 Then O
Crossing Stance
L1 then R1 x3
Drag Ball Stepover
L1+R1 Then L1 2x
Drag Ball Into Stepover Dash
L1+R1 Then 2x L1+R1
Sidestep Stepover
Do a sidestep up/or/down+R2 then quickly press L1 x2
Go Around The Ball
While running hold L1 then tap quickly R1 x2
Old moves still work (Elastico, Matthews feint, vfeint, 360, lift ball)
Links Para Monitor Wide
1280x1024
http://rapidshare.com/files/58614720...x1024.rar.html
1440x900
http://rapidshare.com/files/58609196...0x900.rar.html
Patch dos 10 Minutos
1 run pes2008demo.exe
2 when you are in formation settings before match,alt+tab run this program and select your favourite time
3 click the second button(right button) to apply(the left button
is used to display the current game time)
it is made by a Chinese programmer - Yock, I just found it 5 mins ago!
here it is :
http://dl.yocksky.com/PES/PES2008_Time_Patch.rar
http://files.filefront.com/PES2008+T.../fileinfo.html
fonte: evo-web
Como adicionar a bola da Nike:
Baixe o arquivo que contém a bola:
http://www.gamingaccess.com/index.php?news_id=8741
How to Install :
a-Open AFS Explorer. Get it from here : http://downloads.gamingaccess.com/in...p?file_id=4282
b-Go to menu FILE - IMPORT AFS File
c-In the dialog window go to last combo box and select ALL FILES
d-From your PES 2008 img folder open cv_1.img (backup it first)
e-Answer NO to questions and the file will be opened.
f-Now right click on unnamed_7.bin and select import and then import unnamed_7.bin included in this rar.
Novas luvas
http://www.gamingaccess.com/index.php?news_id=8754
Mesmo esquema das bolas, só que dessa vez, o arquivo a ser importado é cv_0.img
KIT SERVER PRO 2008
http://rapidshare.com/files/59614042/kitserver-700a.zip
Kitserver 7 for the PES2008 PC DEMO October 1, 2007
Version 7.0.0a
FEATURES
- Enable up to 4 controllers
- Select quality levels which PES doesn't want you to choose
INSTALLATION
As in Kitserver 6, you have to unpack the archive to your PES installation
folder and run the setup.exe. What is new is that you can now also select your
settings.exe. This is necessary because some changes are only possible in that
file. simply select these both files (they should already be preselected) and
click "Install". If you choose that you don't want to use Kitserver any longer,
run setup.exe again and click "Remove". You can also install/remove Kitserver
only for one exe by setting the other one to "no action".
HOW TO USE
After installing Kitserver, you are asked if you want to enable all quality
levels. In PES2008, Konami doesn't allow you to choose a high quality level if
the game thinks your PC isn't good enough for that. If you click on "Yes", that
check is removed and you can try if they are right with their assumption.
Apart from that you can now choose 4 controllers in the "Controller" tab. That
means you can configure your gamepads here and later play with them. Note that
by default the keyboard is controller #1. If you setup your gamepad as first
controller, you can't play against someone using the keyboard and your gamepad.
For that, you shouldn't setup a gamepad as first controller but always as #2, #3
or #4. However you can't use your gamepad in the main menu then, that works only
with the first controller.
Have a lot of fun,
Robbie
