If your resolution is unsupported in the graphics options:
This is a very common issue with those using less common resolutions. The most common one I see people having issues with is 1366x768, so I will use that as an example. You can replace that with whatever your desired resolution may be.
METHOD 1:
1) Open the console with ~ or F3 (ö for European keyboards)
2) Type in the following:
setres 1366x768
3) Press enter.
METHOD 2:
1) Navigate to your DOCUMENTS folder and find:
Documents\My Games\RedOrchestra2\ROGame\Config
2) Open the ROEngine.ini file with notepad.
3) Ctrl+F for 'ResX' and 'ResY'.
4) Change the values for ResX and ResY to match your monitor's resolution.
5) Save the changes made to the file.
Tá em inglês mas dá pra ter noção de como fazer![]()
Valeu vou testar aqui e posto se resolveu quando chegar em casa
