Resolução Máxima da vga da mobo Asus A8V-VM Ultra ??
MiKoTe
Bom a pergunta do topico ja diz tudo,
qual a resolução maxima q vou conseguir com a vga on board da mobo A8V-VM Ultra ???
pergunto isto pq tenho um lcd de 20.1 q a resolução nativa é de 1680x1050
será q chega até isso ???
valeu galera!!
Genuine Windows XP is authentic Windows software that is properly licensed and legally installed.Learn more about the special benefits reserved for genuine Windows customers by visiting www.microsoft.com/Genuine CPU Socket 939 for AMD Athlon 64FX / Athlon 64 X2 / Athlon 64
- AMD64 architecture enables simultaneous 32- and 64-bit computing
AMD Cool 'n' Quiet Technology
Chipset NVIDIA GeForce 6150 + nForce 430
Front Side Bus 2000 / 1600 MT/s
Memory 4 x 184-pin DIMM Sockets support max. 4GB
DDR400/DDR333/DDR266 ECC/ non-ECC,un-buffered memory
Dual Channel Architecture
VGA Integrated GeForce 6 GPU
High Definition Video Processing, max. resolution 1920 x 1440 for RGB display
Dual VGA output: DVI-D and RGB (*DVI-D can not be converted to output RGB signal to CRT.)
Expansion Slots 1 x PCI Express x16
1 x PCI Express x1
2 x PCI
Storage/RAID 4 x Serial ATA I/II 3Gb/s: : RAID 0, RAID 1, RAID 0+1,RAID 5
2 x UltraDMA 133/100/66/33
NVIDIA MediaShield storage management technology
LAN Integrated Gbit MAC with Marvell 88E1111 external PHY
- NVIDIA ActiveArmor Firewall for secure networking
Audio High Definition Audio, ADI AD1986A 5.1channel CODEC
Support Jack-Sensing and S/PDIF out interface
IEEE 1394 VIA 6037 IEEE 1394 controller, supports 2x1394 ports
USB 8 USB2.0 ports
Special Features ASUS Q-Fan
ASUS C.P.R.(CPU Parameter Recall)
ASUS EZ Flash*
ASUS CrashFreeBIOS2*
ASUS MyLogo2
SFS (Stepless Frequency Selection) from 200MHz to 240MHz at 1MHz increment
(*EZ Flash & CrashFreeBIOS2 only support VGA/RGB output, but does not support VGA/DVI-D output.)
Back Panel I/O Ports 1 x VGA/DVI out
1 x VGA/RGB out
4 x USB
1 x IEEE 1394
1 x 5.1 channel Audio I/O
1 x RJ45
1 x PS/2 Mouse
1 x PS/2 Keyboard
1 x Parallel
Internal I/O Connectors 2 x USB 2.0 connector supports additional 4 USB 2.0 ports 1 x IEEE 1394 connector 1 x TV out connector 1 x S/PDIF output connector Front panel audio connector CPU Fan / Chassis Fan connectors Chassis Intrusion connector CD audio-in connector 24-pin ATX power connector 4-pin ATX 12V Power connector 1 x COM connector
Support CD Drivers
ASUS PC Probe II
ASUS LiveUpdate Utility
AMD Cool ' n' Quiet Utility
Anti-virus software (OEM version)
Accessories 1 x Ultra DMA 133/100/66 cable
2 x SATA cable
2 x SATA power cable
1 x IDE cable
1 x FDD cable
1 x I/O Shield
User’s manual
BIOS 4Mb Flash ROM, AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.3, ACPI 2.0
Form Factor uATX Form Factor, 9.6”x 9.6”(24.5cm x 24.5cm)
