Rodar Linux no Xbox 360
willianm
El Ratón
Free60: X.org Driver and a new 'Full' Gentoo LiveCD for Xbox360
>> More development from free60 ... they released X.org xenon drivers and Cpasjuste, who already released a Gentoo 'Minimal' Xenon LiveCD (87MB) a few days ago, now released a Xenon modified ISO based on the 'full' BETA Gentoo LiveCD (608MB):
No April Fools' Day joke. We have released a preliminary X.org driver and Cpasjuste has built a new LiveCD which makes use of it. Unfortunately, support for Samsung drives and sound drivers are still missing.
From the gentoo-livecd-xenon-beta readme:
This is a liveCD for Linux on the Xbox 360. It is based on the experimental gentoo liveCD that can be found here.
It has a few changes to boot on the Xbox 360 (codename xenon).
Currently, Samsung drives aren't supported, there is no sound driver, and you should use vga output for better results.
This liveCD is build with the new xenosfb driver so it have a full gnome desktop. It also contains the powerpc64 toolchain for developers.
How does it work ?
Burn gentoo-livecd-xenon-beta.iso.
Upload the cdreader binary via serial, or use the new king kong patcher with built-in readcd code, this will open the dvd tray.
Put the gentoo-livecd-xenon-beta CD in the drive.
cdreader will automatically start the xell bootloader located at lba 0x20 on this cd and boot the Linux Kernel.
Note: Like with all homebrew/linux stuff on Xbox360 atm you'll need Xbox360 kernel 4532/4548, a burned King Kong Xbox360 game with patched shaders and a Xbox360 DVD-ROM drive (Hitachi-LG only for the LiveCD if you use Xorloser's new 'no-serial-cable' shaders) with modified firmware.
Official Site: www.free60.org
Download X.org drivers: here
Download Xenon Gentoo LiveCD Beta (608MB): here
Discuss this news item on our forums: forums.xbox-scene.com
Fonte: http://www.xbox-scene.com/
Vou testar hj mesmo!!!!
EDIT: AHHHHHH! droga... eu atualizei meu VG, dai ele ta com a versão 4552 do kernel. E esse HomeBrew só roda nas versões 4532 ou 4548.
Quem tiver uma dessas duas versões não atualizem por enquanto. Testem ae esse HomeBrew e vê se roda algum emulador.
1º de Abriu jah passou não?
Vai saber né...
Se funfa avisa e posta umas SS ai pro pessoal ver :)
Parece que é verdade sim. A própria Xbox-Scene criou um quote dizendo que não é brincadeira:
Vai saber né...
Se for verdade essa notícia, acho que esta semana já sai uns videos no youtube. Ah e uma coisa... Isso não é uma novidade. Essa notícia se refere a uma atualização que saiu recentemente.
Um vídeo que eu encontrei na internet foi este:
Esse método do video é o anterior, onde o cara precisava ligar o xbox 360 via serial com o pc.
Esse novo bug a principio explora uma falha que já foi bem difundida, entretanto já foi corrigida pelas atualizações da M$, então somente quem tiver Xbox 360 sem ser atualizado vai funcionar.
Ele funciona da mesma forma que o PSP. Eles pegam um jogo que possui um bug, exploram esse bug para inserir o código de um programa na memória do VG e quando a pessoa entra no jogo esse código é executado.
Para saber a versão do seu kernel:
You need an Xbox with a kernel version of 4532 or 4548. You can check your kernel version in "System -> Console Settings -> System Info". The line at the bottom contains your kernel version in the format K:2.0.nnnn.0, where nnnn is your four digit kernel version.
