Servidores de DNS e Filtros de Internet
Com Quad9 tive perda de pacotes também, tanto na Vivo quanto na Claro.
Aqui em Porto Alegre o DNS da CloudFlare parece estar aqui na rede da Claro de POA mesmo:
Código:
root@router:~# ping 1.1.1.1
PING 1.1.1.1 (1.1.1.1): 56 data bytes
64 bytes from 1.1.1.1: seq=0 ttl=60 time=1.990 ms
64 bytes from 1.1.1.1: seq=1 ttl=60 time=1.492 ms
64 bytes from 1.1.1.1: seq=2 ttl=60 time=1.828 ms
64 bytes from 1.1.1.1: seq=3 ttl=60 time=1.589 ms
64 bytes from 1.1.1.1: seq=4 ttl=60 time=1.606 ms
^C
--- 1.1.1.1 ping statistics ---
5 packets transmitted, 5 packets received, 0% packet loss
round-trip min/avg/max = 1.492/1.701/1.990 ms
root@router:~#
Claro fibra ainda usa o IP 1.1.1.1 na rede interna? Dê um mtr ou traceroute pra confirmar.
Parece estar tudo OK (ou seja, 1.1.1.1 parece mesmo CloudFlare dentro da rede da Claro aqui em POA):
Código:
opi5:~$ traceroute -I 1.1.1.1
traceroute to 1.1.1.1 (1.1.1.1), 30 hops max, 60 byte packets
 1  router.home (192.168.1.1)  0.974 ms  0.917 ms  0.965 ms
 2  c925a801.virtua.com.br (201.37.168.1)  2.530 ms  2.516 ms  2.501 ms
 3  c915e52d.virtua.com.br (201.21.229.45)  3.670 ms  3.656 ms  3.467 ms
 4  c915c004.virtua.com.br (201.21.192.4)  3.411 ms  3.400 ms  3.387 ms
 5  c915d3da.virtua.com.br (201.21.211.218)  3.374 ms  3.359 ms  3.346 ms
 6  one.one.one.one (1.1.1.1)  2.357 ms  1.824 ms  1.798 ms
opi5:~$ ping 1.1.1.1
PING 1.1.1.1 (1.1.1.1) 56(84) bytes of data.
64 bytes from 1.1.1.1: icmp_seq=1 ttl=59 time=2.62 ms
64 bytes from 1.1.1.1: icmp_seq=2 ttl=59 time=2.21 ms
64 bytes from 1.1.1.1: icmp_seq=3 ttl=59 time=2.33 ms
64 bytes from 1.1.1.1: icmp_seq=4 ttl=59 time=2.28 ms
^C
4 packets transmitted, 4 received, 0% packet loss, time 3005ms
rtt min/avg/max/mdev = 2.210/2.360/2.620/0.156 ms
opi5:~$ nslookup www.google.com 1.1.1.1
Server:        1.1.1.1
Address:    1.1.1.1#53
Non-authoritative answer:
Address: 172.217.173.228
Address: 2800:3f0:4002:80e::2004
opi5:~$ ping security.cloudflare-dns.com
PING security.cloudflare-dns.com (1.0.0.2) 56(84) bytes of data.
64 bytes from 1.0.0.2 (1.0.0.2): icmp_seq=1 ttl=59 time=1.60 ms
64 bytes from 1.0.0.2 (1.0.0.2): icmp_seq=2 ttl=59 time=1.81 ms
64 bytes from 1.0.0.2 (1.0.0.2): icmp_seq=3 ttl=59 time=1.67 ms
64 bytes from 1.0.0.2 (1.0.0.2): icmp_seq=4 ttl=59 time=1.96 ms
64 bytes from 1.0.0.2 (1.0.0.2): icmp_seq=5 ttl=59 time=1.74 ms
--- security.cloudflare-dns.com ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4003ms
rtt min/avg/max/mdev = 1.601/1.754/1.957/0.122 ms
^C
opi5:~$ traceroute -I security.cloudflare-dns.com
traceroute to security.cloudflare-dns.com (1.0.0.2), 30 hops max, 60 byte packets
 1  router.home (192.168.1.1)  1.106 ms  1.080 ms  1.183 ms
 2  c925a801.virtua.com.br (201.37.168.1)  2.946 ms  2.933 ms  3.864 ms
 3  c915e52d.virtua.com.br (201.21.229.45)  3.635 ms  3.622 ms  3.610 ms
 4  c915c004.virtua.com.br (201.21.192.4)  2.863 ms  2.850 ms  2.839 ms
 5  c915d3da.virtua.com.br (201.21.211.218)  2.812 ms  3.531 ms  3.886 ms
 6  1.0.0.2 (1.0.0.2)  2.778 ms *  1.901 ms
opi5:~$ nslookup www.google.com security.cloudflare-dns.com
Server:        security.cloudflare-dns.com
Address:    1.0.0.2#53
Address: 142.251.133.36
Address: 2800:3f0:4002:809::2004
opi5:~$
Segue ping dos principais servidores de DNS na minha conexão TIM Ultrafibra (ex-TIM Live) aqui em São Paulo - capital:
O que eu uso é o AdGuard sem personalização.
Vc está em São Paulo, certo? Daqui de POA para qquer IP em SP já adciona uns ~15-18ms. Então um bom DNS tem um ping de 20-30ms por aqui:
Na Vivo eu usava o CleanBrowsing, mas na Claro a rota para o mesmo está levando para os EUA, e estava usando o CloudFlare até começar a dar problema frequente de SERVFAIL (notar que eu usava o servidor da Cloudflare com filtro de malware via DoH - https://security.cloudflare-dns.com/dns-query, e é esse servidor que começou a retornar SERVFAIL com certa frequência, não o 1.1.1.1).
Pessoal, é possível descobrir se os servidores dns da operadora possui proteções doh/dot/quic? Hoje vi algo curioso na minha internet, vou esperar a data de vencimento pra ver a confusão rolar, pois acho que a mob fez merda, mas vou esperar.
Testando os dns do post do @_dsouza_, tenho média de ~50ms pra cima, com saltos no traceroute deles, as vezes apenas o do google pinga 100% no traceroute, resumindo, tá um horror. O melhor na minha conexão era o nextdns, mas ele está um dos piores hoje, apenas o dns ipv6 primário que consigo algo menor que 15ms.
Como minha internet tava uma merda hoje, resolvi testar e vi que não tava pegando nem 300mb dos 600mb contratados, isso tanto em download ou upload, se bem que no upload está correto, pois é 50% do download. Resolvi resetar o ac68u, pois aconteceu algo parecido uma vez e era o roteador que tinha bugado, e foi isso mesmo. Só que agora a velocidade tá maior que a contratada, o melhor é o ping:
No momento, estou usando o dns da própria mob telecom, e tá muito bom, sempre abaixo de 10ms, tanto o primário e secundário ipv4/ipv6. Sei que dns de operadora nunca tem proteções decentes, mas estou cansado de ficar testando servidor dns de terceiros e ficar dando problema. Minha dúvida é se ficar usando o da operadora eu estaria muito desprotegido. Será que daria certo usar a proteção doh/dot do controld, por exemplo, junto com os dns da própria mob?
No asuswrt é possível configurar isso, esse firmware da muitas possibilidades de configuração, mas não acho que a mob tenha isso, o que vcs acham?
cara a real é a seguinte doh e dot, na pratica foram criados justamente pra agentes maliciosos não ferrarem com as consultas de dns entre vc e o servidor.
o problema com a operadora é a seguinte, eles são os donos do servidor e da rede, na pratica doh e dot pra eles não faz sentido nem um em disponibilizar.
o maior problema com dns que ocorre com dns das operadoras, é que eles podem ao bel prazer deles se o dono do dominio não fazer utilização de dnssec, alterar resultados da consulta e fazer logs de consultas realizadas por clientes.
a real é que se a gente quer um servidor dns 100% seguro, só subindo um BIND ou MSDNS, configurar corretamente o dnssec, e só realizar consultas nos root servers dns.
pq nem esses 1.1.1.1, 8.8.8.8 e etc podem ser considerados seguros, ou tu acha que a google não faz um logs de consulta de dns que a gente acessa e faz data mining para "melhorar" os serviços deles :limo:
a o principal servidor dns não interfere em velocidade da conexão.
dns nada mais do que é um tradutor de texto pra numero, ele não interfere na qualidade da sua conexão que esta sendo entregue.
Procura no Google por teste top. É um site do nic.br que avalia os servidores dns. A vivo por exemplo nao tem dnssec
Entendi, então vou continuar usando dns de terceiros, o pouco que ajudar proteger a privacidade tá valendo. Servidores bind/msdns são muito acima do meu conhecimento, infelizmente não rola, é como se vc estivesse falando em grego para mim. Acho que continuarei no opendns, foi o que desempenha melhor com o meu provedor, pelo menos até o nextdns voltar a funcionar melhor.
Fiz o teste, deu 100% nas opções, mostrou algumas informações, por exemplo:
1. Mostrou que a mob tem dnssec e ipv6 ativos
2. Também informa que a mob não possui nome reverso, não sei o que seria isso
3. Diz que estou usando extensões de privacidade para ipv6, isso seria as configurações de segurança do roteador ou do provedor?
4. Também referente a ipv6, diz que não uso slaac, isso é bom ou ruim?
No mais, acho que foi apenas isso de informações diferentes que foi informado no teste, que dizer que se caso eu desejasse usar o dns da própria operadora seria seguro? Nesse teste, mostrou apenas um erro no servidor dns da mob, que seria qname minimisation, isso seria alguma brecha de segurança para o servidor deles?
para contribuir com o topico,
a lista dos servidores DNS ANYCAST que a Claro utiliza na rede fixa para os clientes dela, vou ficar devendo os ipv6 pq a dona claro desativou o v6 aqui na região depois de ter pego um fogo no DC da embratel aqui em BH:
181.213.132.2
181.213.132.3
181.213.132.4
181.213.132.5
181.213.132.6
181.213.132.7
181.213.132.8
181.213.132.9
um site bom para testar se a cadeia de requisições dns esta com dnssec devidamente configurada e tudo funcionando:
e sim, é teste com o dns server da claro na rede fixa.
e um blog post da cloudflare bem simplificado de como funciona o dnssec: https://www.cloudflare.com/pt-br/dns/dnssec/how-dnssec-works/
e a principal contribuição, este site aqui: https://www.dnsleaktest.com/
o teste extensivo dele consegue detectar e reportar quais servidores dns realmente estão respondendo as requisições para o dispositivo.
notem que com estes servidores dns anycast, quem responde verdadeiramente os pedidos de dns pra gente não é o endereço configurado, mas sim uma porrada de servidores diferentes com seus endereços de ip únicos.
com isto que estes endereços tem alta disponibilidade para responderem a pedidos de dns, não é aquela coisa centralizada arcaica que as operadoras utilizavam anteriormente que dava um pau num unico servidor e todos os clientes ficavam com problema na conexão(rolava muito disso com a Telefônica SP e com a NET antigamente).
Um site que uso há bastante tempo e é confiável para teste se existe "DNS leak" (ou seja, se o provedor ou alguém no caminho está "sequestrando" as consultas DNS) é esse abaixo. É simples mas sempre funcionou bem, recomendo:
Com DoH acho difícil qquer interceptação, pois o mesmo usa HTTPS, que possui certificado digital e não tem como o ISP forjar o mesmo (via man-in-the-middle).
EDITADO: acabei de ver que o @dudu1505 já tinha mencionado esse site, desculpem a duplicação.
EDITADO 2: recomendo a leitura desse artigo abaixo para diferenciação de DNSSEC vs DoH/DoT (são soluções para propósitos diferentes):
DNSSEC only ensures the authenticity of the DNS responses and data integrity but does not ensure privacy. Protocols like DNS over HTTPS (DoH) or DNS over TLS (DoT) provide end-to-end encryption, therefore guaranteeing data confidentiality. In other words, your DNS traffic now benefits from the same end-to-end encryption as your web traffic to and from HTTPS sites.
Fiz este teste e deu esse resultado. Aqui uso o DNS 1.1.1.1
Está OK?
:hmm2:
O resultado mostrou outro DNS.
Datapacket aparece pra mim quando uso o adguard.
Edit: com adguard apareceu esse:
169.150.220.198dns.adguard-dns.com.Datacamp Limited
Achei o culpado (desativei para testar):
