Mais sobre o Patch e soluções para Bugs.
http://www.gamebanshee.com/news/103022-the-witcher-2-v11-patch-coming-soon-technical-faq.html
The Witcher 2 Patch 1.1 Next Week, Technical FAQ
CD Projekt RED, the developer of The Witcher 2: Assassins of Kings, announces that patch 1.1 is nearing completion and will be available shortly. It will address a number of issues reported by players such as keymapping, inverting the mouse, sudden crashes, problems with activation, difficulties with the game`s DLC, and more.
The company has also compiled a list of actions that may help in certain circumstances:
Difficulties with activation code
There have been quite a few instances that involved entering the number zero (0); you should use the capital letter “o” (O). Also there have been cases where the number one (1), the lower-case letter “el” (l) and the capital letter “eye” (I) have been mixed up. Please try all possible permutations.
CRC Errors when installing the game
1)Please make sure that any antivirus software is disabled during the installation process.
2)It's possible that your DVD drive is not compatible with DVD9 standard. Please manually copy the files to your HDD and try to install the game from there, with antivirus software disabled.
3)If this doesn't work, please try and install the game on another machine - also trying to copy the files manually and disabling any antivirus software.
4)If the above does not help and the DVD disc is in fact damaged, please ask for a refund at the store where bought the game. If this is not satisfactory, please contact us at help2start@thewitcher.com
Game doesn’t start, goes back to launcher
Please try the following possible solutions:
1)Turn all settings to Application-Controlled in the Catalyst Control Center.
2)Disable the second GPU from Crossfire configurations until ATI officially adds support for The Witcher 2 in Catalyst drivers.
3)Try running the game in windowed mode.
4)Run the game with horizontal resolution no higher than than 1920, and set the desktop to the same resolution as the game.
5)Ensure that the game was installed with administrator privileges - Windows UAC settings set to minimum or setup.exe from DVD opened with privileges.
Also: Go to User Account Control Settings.
Type in UAC, or go to the System and Security applet.
Click on the "Change User Account Control Settings" link.
(You can also type in this command from the Run menu: C:\Windows\System32\UserAccountControlSettings.exe)
To turn off UAC, move the slider to the Never Notify position, and then click OK. If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
Poor performance on a high-end GPU
Please install the latest drivers for your graphic card, and for nVidia cards, uninstall 3D Vision.
If you are experiencing low efficiency, please make sure you have disabled UberSampling in the game's graphic configuration in the Launcher. If you have an nVidia graphics card, please update your driver to the 275.27 beta as of May 17th.
As for ATI users:
1)Install latest drivers ATI Hotfix.
2)DIsable anisothropic filter, antialiasing and adaptive antialiasing and Catalyst A.I.; this can be done in the CCC panel.
4)For dual cards linked into crossfire, turn off one of the cards or use the Dirt 2 profile.
AMD/ATI plans to release hotfix drivers dedicated to The Witcher 2. They will resolve problems with game's efficiency for crossfire users. This information will appear on: http://support.amd.com/us/Pages/Catalyst-Hotfixes.aspx"
Game Director Adam Badowski commented the launch of the game. "While we did our best to avoid complications for our players, it`s clear that on the complex PC platform, we need to go the extra mile to ensure that everything works flawlessly. We are aware of the issues. And there`s one very important promise I can make today. Next week`s patch will solve the majority of them, including those involving activation and DLC. For now, I can also recommend the many walkarounds available on our tech support page, and promise that a much more complete solution will arrive next week. And of course, we kindly ask anyone having problems to accept our sincere apology."
CD Projekt RED also confirmed that a special e-mail address has been set up to provide help as quickly as possible to those who bought the game, but cannot get it to run. Anyone in this position can write to help2start@thewitcher.com . Support staff will reply as soon as possible.
The Witcher 2 is selling faster than the company expected – a couple hundred thousand users have already activated it. The vast differences in hardware and software configurations among this huge number of users has brought to light some previously unknown technical issues. CD Projekt RED assures its fans that it will support the game with all available resources and promptly remove all known issues.
