Não é uma super promoção mas é um dos melhores preços que já vi para o que é provavelmente um dos melhores se não o melhor smartphone com preço menor que R$1000,00
https://www.walmart.com.br/motorola...ource=internal_emkt_reg&utm_medium=regcp3a3vv
NETWORK Technology GSM / CDMA / HSPA / EVDO / LTE
LAUNCH Announced 2017, February
Status Available. Released 2017, April
BODY Dimensions 150.2 x 74 x 7.7 mm (5.91 x 2.91 x 0.30 in)
Weight 155 g (5.47 oz)
Build Front glass, aluminum body
SIM Single SIM (Nano-SIM) or Dual SIM (Nano-SIM, dual stand-by)
- Splash and dust resistant
DISPLAY Type IPS LCD capacitive touchscreen, 16M colors
Size 5.2 inches, 74.5 cm2 (~67.1% screen-to-body ratio)
Resolution 1080 x 1920 pixels, 16:9 ratio (~424 ppi density)
Multitouch Yes
Protection Corning Gorilla Glass 3
PLATFORM OS Android 7.0 (Nougat), upgradable to Android 8.0 (Oreo)
Chipset Qualcomm MSM8953 Snapdragon 625
CPU Octa-core 2.0 GHz Cortex-A53
GPU Adreno 506
MEMORY Card slot microSD, up to 256 GB
Internal 32, 2GB RAM;
CAMERA Primary 12 MP (f/1.7, Dual Pixel PDAF), phase detection autofocus, dual-LED dual-tone flash
Features Geo-tagging, touch focus, face detection, panorama, auto-HDR
Video [email protected]
Secondary 5 MP, f/2.2
SOUND Alert types Vibration; MP3, WAV ringtones
Loudspeaker Yes
3.5mm jack Yes
- Active noise cancellation with dedicated mic
COMMS WLAN Wi-Fi 802.11 a/b/g/n, dual-band, WiFi Direct, hotspot
Bluetooth 4.2, A2DP, LE, EDR, aptX
GPS Yes, with A-GPS, GLONASS
NFC Yes (market dependent)
Radio FM radio
USB microUSB 2.0, USB Host
FEATURES Sensors Fingerprint (front-mounted), accelerometer, gyro, proximity, compass (USA model only)
Messaging SMS(threaded view), MMS, Email, Push Email, IM
Browser HTML5
Java No
- Fast battery charging
- MP3/AAC+/WAV/Flac player
- MP4/H.264 player
- Photo/video editor
- Document viewer
BATTERY Non-removable Li-Ion 3000 mAh battery
Multitouch Yes
GPU Adreno 506
Loudspeaker Yes
3.5mm jack Yes
Radio FM radio
Browser HTML5
Java No
- MP4/H.264 player
- Document viewer
