Saiu uma nova versão do melhor compactador de arquivos.
WinRAR 3.71 - 21 September 2007
http://www.rarsoft.com
http://www.rarsoft.com/rar/wrar371br.exe (Brasil)
http://www.rarsoft.com/rar/wrar371.exe (US)
WinRAR - What's new in the latest version
Version 3.71
1. Archive names in rar.log error log file always include
the full path.
2. WinRAR tray icon is compatible with high DPI display modes.
3. If you modified a file in archive with encrypted names using
an external editor, WinRAR will not ask for archive password again
when prompting to update a file. It will use a password which
you entered when opening an archive,
4. Bugs fixed:
a) switch -tl and "Set archive time to latest file time" option
could fail in previous version. Sometimes they set archive time
to current system time instead of latest file time;
b) if -ag switch mask contained archive number, month and minute
characters, WinRAR placed 'I' character instead of minute value
into generated archive name for archive numbers exceeding 1;
c) high ASCII names in ISO files using ISO 9660 format without
Joliet format extension were displayed incorrectly;
d) WinRAR could crash when decompressing some of corrupt RAR archives;
e) if "Turn PC off when done" option was set in "Convert archives"
command, WinRAR turned PC off after converting the first archive
in selected group instead of after converting the entire group;
f) if user specified a non-existent destination path in SFX archive
in Vista, SFX could enter into infinite "create new SFX window"
loop;
g) WinRAR could fail to unpack an individual file from subfolder
of ACE archive using the drag and drop.
Version 3.71
the full path.
4. Bugs fixed:
loop;
