DD2 por exemplo eram 5000 ARPS.(keys steam)sabia disso n, vai muitos arps pra pegar um jogo? sao ativados via steam?
E os jogos melhores geralmente tem ser nivel alto (TIER5 por ex).
to precisando de parça, bora?Rapaz comprei o game.
1080ti+4790k+16Gb DDR3 2400
Rodando liso no médio em 1080p +70fps.
achei que ia passar raiva mas rodou lindamente.
joguei com alguém aqui do fórum, mas nao lembro o nome dele aqui, o cara saiu matando geral numa facilidade
Essa arma só é boa com bots, é um lixão nos insetos com um monte de hunters pulando pra todo lado.na hora q libera o scorcher o jogo vira mt mais facil
contra insetos ela tb eh boa, so n eh a melhorEssa arma só é boa com bots, é um lixão nos insetos com um monte de hunters pulando pra todo lado.
Perfeição pra mim é Scythe + pistola de granadas.
Novo Warbond
New Helldivers 2 Warbond brings trap-laying weaponry, arctic-themed armor, and more May 9
Polar Patriots also comes packed with new emotes, capes, and sidearms.blog.playstation.com
_____________________
Patch
HELLDIVERS™ 2 - Patch 1.000.301 - Steam News
Auspicious day all Helldivers out there. Small patch rolling out before the weekend! Overview For this patch, we have addressed some crashes as well as performance improvements following the decline from the last patch: Performance improvements Crash fixes Fixes Fix for a crash that could occur...store.steampowered.com
Patch 1.000.301
Overview
Fixes
- Performance improvements
- Crash fixes
Known Issues [Unchanged since patch 1.000.300]
- Fix for a crash that could occur during the post mission end screen
- Fix for crash which could occur when destroying automaton tanks.
These are issues that were either introduced by this patch and are being worked on, or are from a previous version and have not yet been fixed.
- Damage-over-time effects may only apply when dealt by the host. We expect to have this fixed in the next patch.
- Reinforcement may not be available for some players who join a game in progress.
- Helldiver may be unable to stand up from crouching when surrounded by enemies.
- Game may crash if the host leaves while dead and rejoins the same play session.
- Game may crash if the player changes the text language while on a mission.
- Various issues involving friend invites and cross-play:
- Friend Request cannot be accepted when the requesting player changed their username before the request was accepted.
- Cross-platform friend invites might not show up in the Friend Requests tab.
- Players cannot unfriend players befriended via friend code.
- Players cannot unblock players that were not in their Friends list beforehand.
- Players may experience delays in Medals and Super Credits payouts.
- Enemies that bleed out do not progress Personal Orders and Eradicate missions.
- Scopes on some weapons such as the Anti-Materiel Rifle are slightly misaligned.
- Arc weapons sometimes behave inconsistently and sometimes misfire.
- Spear’s targeting is inconsistent, making it hard to lock-on to larger enemies.
- Stratagem beam might attach itself to an enemy but it will deploy to its original location.
- Explosions do not break your limbs (except for when you fly into a rock).
- Area around Automaton Detector Tower makes blue stratagems such as the Hellbomb bounce and be repelled when trying to call them down close to the tower.
- Planet liberation reaches 100% at the end of every Defend mission.
Até hoje não entendi a direção do walking barrage
Meu to-go é railcannon strike, eagle airstrike e aquele orbital burst ou algo assim. Esse último se bem jogado apaga 99% dos pequenos de uma bug breach
Quase juntando 1k SC, pensando se pego o warbond da senator ou espero pelo novo. Queria uma arminha pica pra testar a build de escudo nos bots
Não tem ordem, é tudo meio aleatório.alguém tem um vídeo explicando as ordens que devo fazer as missões?
ontem fiz uma de quase 30 minutos com uns gringos e foi muito top.
muito obrigado pela explicação.Não tem ordem, é tudo meio aleatório.
Tipo, tem as missões Prioridade que é a comunidade como um todo que tem que executar. Geralmente é liberar certos planetas (simplesmente fazer qualquer missão dentro do planeta).
Só tem que se ligar que, para contabilizar seus "Esforços pela Democracia" você tem que completar Operações. Cada Operação (aquela com um símbolo e uma área amarela no globo) são compostas por 2 ou 3 Missões.
Você também só libera o próximo nível de dificuldade completando uma Operação inteira.
Outra coisa, geralmente quando você dá um QuickSearch e o jogo te joga em qualquer servidor, você completa uma missão e geralmente o host desfaz o lobby, aí você perde esse avanço em uma Operação.
Se você criar um lobby (simplesmente iniciar uma Operação na sua nave), aguarda um pouco por ali que o pessoal deve começar a entrar. Nesse caso, uma vez que você completa uma Missão, já seleciona a Missão seguinte da mesma Operação, para você ter uma continuidade dentro da sua campanha.
E se você entrar sozinho, primeira coisa que você faz é lançar um sinalizador de SOS, para o pessoal poder dar Join na sua sessão.
Dentro de cada Missão você tem seus objetivos principais, que podem ser visualizadas no mapa, e alguns objetivos secundários, que você "esbarra" ou consegue visualizar no mapa uma vez que você acessa uma antena no mapa que mostra tudo, incluindo os recursos (nem toda missão tem dessas).
Lembro que quando instalei o jogo no PC eu já precisei linkar a conta da PSN. Pelo visto não foi pra todos, ou não era obrigatório. Mas já deixei linkado desde o começo.Vi que vai ser obrigado a linkar a uma conta playstation.
Minha conta PS padrão do meu email pessoal é americana. Será que eu teria algum problema? A conta é antiga, eu nem tenho PS
Ou seis acham que seria melhor criar outra conta outro email e endereço BR?
Idem, baixei o game terça-feira e também precisei linkar.Lembro que quando instalei o jogo no PC eu já precisei linkar a conta da PSN. Pelo visto não foi pra todos, ou não era obrigatório. Mas já deixei linkado desde o começo.
Era obrigatório mas foi suspenso por motivos técnicos mas a obrigação está lá desde o início da pré-vendaLembro que quando instalei o jogo no PC eu já precisei linkar a conta da PSN. Pelo visto não foi pra todos, ou não era obrigatório. Mas já deixei linkado desde o começo.
Parece que essa obrigatoriedade do PSN ta derrubando os reviews da Steam, ja ta quase Neutro em questões horas
Aqui tbm é conta americana, sei que no destiny não teve problema issoVi que vai ser obrigado a linkar a uma conta playstation.
