AMD Catalyst 12.4 Oficial
CCR
1995 Civic VTi Eg6
Windows 7 e Vista - X86: http://www2.ati.com/drivers/12-4_vista_win7_32_dd_ccc.exe
Windows 7 e Vista - X64: http://www2.ati.com/drivers/12-4_vista_win7_64_dd_ccc.exe
Windows Xp X86 : http://www2.ati.com/drivers/12-4_xp32_dd_ccc.exe
NEW FEATURES
Windows XP support for the AMD Radeon HD 7900 Series, AMD Radeon HD 7800, and AMD Radeon HD 7700 Series
In addition to Windows 7 and Windows Vista support, Catalyst 12.4 now also introduces Windows XP (64-bit/32-bit) support for the AMD Radeon HD 7900, AMD Radeon HD 7800, and AMD Radeon HD 7700 Series
Super Sampling Anti-Aliasing: Level of Detail (LOD) Image Quality enhancements
Supported on the AMD Radeon HD 7900, AMD Radeon HD 7800, and AMD Radeon HD 7700 Series
LOD Image quality enhancements have been improved when enabling Super Sample Anti-Aliasing and Adaptive Anti-Aliasing through the AMD Catalyst™ Control Center for DirectX® 10 and DirectX® 11 applications.
Applications must support in game Anti-Aliasing for the feature to work (Forced on Anti-Aliasing through the Catalyst Control Center is not supported for DirectX 10 and DirectX 11 applications)
Morphological Anti-Aliasing (MLAA): Significant performance enhancements
Supported on the AMD Radeon HD 7900, AMD Radeon HD 7800, AMD Radeon HD 7700 Series, AMD Radeon HD 6000 Series, and AMD Radeon HD 5000 Series
MLAA now operates up to 80% faster than previous versions
Texture filtering quality improvements
Improvements have been made to the texture filtering algorithm (for both DirectX9 and DirectX10/DirectX11 applications) to increase the quality of rendered textures, with no impact to performance
RESOLVED ISSUES
Resolved Issues for the Windows 7 Operating System
This section provides information on resolved known issues in this release of the AMD Catalyst 12.4 software suite for Windows 7. These include:
Elder Scrolls: Skyrim: no longer hangs on single GPU configurations when used with AMD Catalyst 12.3 CAP1 and later CAP releases
Elder Scolls: Skyrim: flickering square corruption is no longer observed.
Rage: Vsync is no longer disabled after task switching.
Enemy Territory: Quake Wars: no longer crashes when launched in High Performance Mode.
Stalker – Call of Pripyat: flickering is no longer observed in trees with specific Catalyst Control Center settings.
Tom Clancy HAWX 2: no longer crashes on game launch.
Windows Media Center: no longer crashes when run in Eyefinity mode and High Performance mode settings.
AMD Steady Video: an error message is no longer displayed when enabling AMD Steady Video for the Microsoft Internet Explorer 9.0 plugin.
Duplicating displays no longer generates random corruption.
Tearing is no longer observed on the third screen in 3x1 and 1x3 Eyefinity configurations.
A system crash is no longer experienced when enabling Crossfire in a 4 display configuration.
The advanced video quality settings are now correctly displayed in the Catalyst Control Center.
Mais: AMD Catalyst
Divirtam-se.
Deverás interessante.
Mas acabou o suporte as HD4xxx e anteriores ? :hmm:
Baixando aqui.Andei tendo uns problemas com vídeos do youtube vamos ver se resolve xD.
Não acabou Soulfly, eles agora são segregados serão lançados trimestralmente, enquanto os da séris 5000 e adiante mensalmente, a AMD afirmou que na séries 4000 e abaixo não há mais nada o que refinar,então os drivers apenas darão compatibilidade a novos programas e algumas correções de bugs.
Dei uma olhada no site e o 12.4 também tem pra elas e anteriores, então o esquema de 3 meses ainda não começou.
Acho que vai deixar estas séries somente no 12.7.
Postei a alguns dias a noticia sobre a saida do catalyst destas placas...
opa baixando p conferir esse MLAA now operates up to 80% faster than previous versions:bwahaha:
Não. Parece que o pessoal interpretou a notícia de forma errada. O fim do suporte para as série pré-5000 é somente para o Linux. Para o windows a amd vai continuar lançando drivers whql mas somente a cada três meses. Eles estão fazendo isso para focar mais nas placas DX11 já que nas antigas não tem como arrancar mais performance.
AMD confirmed to TechPowerUp its plans of removing pre-HD 5000 series Radeon GPUs from the Catalyst mainline update model (where WHQL-certified driver updates are released on a monthly basis), but that doesn't necessarily mean a discontinuation of support for those products. AMD told us that it is merely relocating pre-HD 5000 GPUs (under the Radeon HD 2000, HD 3000, and HD 4000 series), to a new update model that will have new WHQL-certified drivers being released on a quarterly basis.
Pre-HD 5000 Will be Removed from Catalyst Mainline, But Onto a New Support Model: AMD | techPowerUp
esse é o driver final? estou usando o 12.3 na minha 7970 e não tive nenhum problema. Sei que o driver 12.3 é final não sei nada sobre esse 12.4...desculpe minha ignorancia pois é minha primeira placa da AMD e não sei quando lançar a versão final. Alguem ai tem como me dizer o que é esse MLAA. É algum tipo de AA tipo o FXAA da nvidia ou é outra coisa da placa.
Todo driver com o selo WHQL é oficial. Para ficar mais fácil, todo driver que aparecer nessa página aqui é oficial: ATI Radeon
Então é só colocar essa página nos favoritos.
To usando aqui gostei bastante.Corrigiu uns bugs que eu tinha no youtube(pelo menos algumas partes).
Nossa povo, eu atualizei pra esse driver pelo próprio catalyst e bugou todo meu pc Uheuhaeuhae
sério, a resolução ficou em 800x600, aí nem tinha a que eu uso
aí reiniciei o pc
deu um monte de erro, falou que estava sem placa de vídeo, sem directx 9, blablablaaaa
tentei desinstalar, reeinstalar
desinstalar, passar driver sweeper, instalar...
etc...
nada resolveu
Tive que fazer System Restore :/
:damn::damn::feelbad:
Queria ver benchmark desses drivers com MLAA, pra ver se esses 80% são verdade mesmo!
Testei aqui na HD 7970 o BF3 , MW3 , Crysis 2 , Minecraft :haha:. Tudo perfeito.
Minha primeira vez com AMD e nada a desejar. :nerd::nerd:
Nas series HD4000 os melhores drivers são até o 11.9 depois disso veio diminuindo a performance das vgas os drivers mais atuais.
Driver atualizado, confesso que deu trabalho pois deu um montão de erro. mais enfim consegui atualizar o bendito 12.4
Vou ver se percebo alguma melhora no performance.
testei só no BF3 e com esse driver a placa aumento 1°C e no fps parece está tudo estável...mas o foda é achar servidor de bf3 que não tenha lag...nao costumo jogar esse jogo mas quase todos os sv que encontro tem lag = /
depois eu vou dar uma testada no bf3 sem vsync , pq eu jogo com vsync
mais reparei q o uso da vg ficava em 75-80% (bf3 multi) ultra + vsync
Testei aqui com MLAA antes com o 12.3 e baixei e testei com o 12.4 e realmente ficou bem mais rapido, só que senti a qualidade desse MLAA inferior na versão 12.4
E melhorou também e relação ao 12.3 na questão de usar o Firefox a VGA ficava em bastante uso com os clocks no maximo, e agora voltou ao normal com a 12.4
Testei no game Just Cause 2 com e sem MLAA
A diferença dele ativado e desativado a queda foi de apenas 3 fps.
Testei aqui esse novo MLAA somente no Alien vs predator e a diferença de performance e qualidade foi bem grande. Esse novo MLAA é muito melhor que o antigo e percebi que ele removeu mais serrilhado que o injectFXAA mas ainda perde em qualidade para o injectSMAA.
Para mim no bench do AvsP a ordem de qualidade de imagem ficou assim: injectSMAA > MLAA 12.4 > injectFXAA > AAx4 (apesar de não ter blur remove poucos serrilhados) > NO AA > MLAA 12.3 (remove bem os serrilhados mas tem um blur horrível, prefiro sem AA).
Performance dos diferentes filtros:
No AA = 100
AAx4 = 67
MLAA CATALYST 12.3 = 46
MLAA CATALYST 12.4 = 93
injectFXAA = 90
injectSMAA = 90
mto bom Diogo, aqui baixei tmb e senti uma melhor bem significativa, AMD dessa vez acertou:poker:
aqui melhorou...
Iscuitem, e o problema de superaquecimento em Crossfire que o 12.3 tinha, sabem dizer com certeza se foi resolvido nesse 12.4?
ahhh eu quero ver esse mlaa funcionando la no cafofo do osama!!!!
tomara q fique tudo perfeito mesmo!!!
