AMD Catalyst™ Display Driver 15.7 WHQL
WINDOWS 10, 8.1 e 7 (32 e 64 BITS): http://support.amd.com/en-us/download
REPORTE ALGUM PROBLEMA DE DRIVER DIRETO PARA A AMD: http://www.amdsurveys.com/se.ashx?s=5A1E27D23A3DE979
RELEASE NOTES:
RELEASE NOTES:
Compatible Operating Systems
The latest version of the AMD Catalyst™ Software Suite, AMD Catalyst™ 15.7 is designed to support the following Microsoft Windows platforms:
Windows® 10 (32 & 64-bit)
Windows® 8.1 (32 & 64-bit)
Windows® 7 SP1 or higher (32 & 64-bit)
Highlights of the AMD Catalyst™ 15.7 Windows Driver
Windows® 10 Support
This is a Technical Preview driver with full WDDM 2.0 support for Windows® 10 and DirectX® 12 on all Graphics Core Next (GCN) supported products, -AMD Radeon™ HD 7000 and newer graphics products. Official driver support for AMD products will be available when Microsoft launches Windows® 10 on July 29th, 2015.
NOTE: To ensure stability, users should upgrade to the latest available Windows® 10 Technical Preview build provided by Microsoft before installing AMD Catalyst™ 15.7.
Virtual Super Resolution (VSR)
VSR provides image quality enhancements to games and Windows® desktop users by rendering images at a higher resolution and then down-scaling the same. VSR support has now been extended to the following products:
AMD Radeon™ R9 Fury Series AMD Radeon™ R9 280 Series
AMD Radeon™ R9 390 Series AMD Radeon™ R9 270 Series
AMD Radeon™ R9 380 Series AMD Radeon™ R7 260 Series
AMD Radeon™ R7 370 Series AMD Radeon™ HD 7900 Series
AMD Radeon™ R7 360 Series AMD Radeon™ HD 7800 Series
AMD Radeon™ R9 295X2 AMD Radeon™ HD 7790 Series
AMD Radeon™ R9 290 Series Desktop A-Series 7400K APUs and above
Below is a list of supported resolutions:
Target Display Timing Supported VSR Modes
1366 X 768 @ 60Hz 1600 X 900
1920 X 1080
1600 X 900 @ 60Hz 1920 X 1080
1920 X 1080 @ 60Hz 2560 X 1440
3200 X 1800
3840 X 2160 (AMD Radeon™ R9 285, AMD Radeon™ R9 Fury Series)
1920 X 1200 @ 60Hz 2048 X 1536
2560 X 1600
3840 X 2400 (AMD Radeon™ R9 285, AMD Radeon™ R9 Fury Series)
2560 X 1440 @ 60Hz 3200 X 1800
1920 X 1080 @ 120Hz 1920 X 1200 @ 120Hz
2048 X 1536 @ 120Hz
Frame Rate Target Control™ (FRTC)
FRTC allows the user to set a maximum frame rate when playing an application in full screen exclusive mode. This feature provides the following benefits:
Reduced GPU power consumption
Reduced system heat
Lower fan speeds and less noise
This feature is supported on applications using DirectX® 10 or higher and on the following AMD graphics products:
AMD Radeon™ R9 295X2 AMD Radeon™ HD 7700 Series
AMD FreeSync™ and AMD CrossFire™ Support
AMD FreeSync™ and AMD CrossFire™ can now be used together in applications using DirectX® 10 or higher. Please note, this feature is currently not supported on systems configured in AMD Dual Graphics mode.
AMD CrossFire™ Profile Enhancements
AMD Catalyst™ 15.7 includes enhancement for the following games since AMD Catalyst™ Omega:
Battlefield: Hardline
Evolve
Far Cry® 4
Lords of the Fallen
Project CARS
Total War: Attila
Alien: Isolation™
Assassin's Creed® Unity
Civilization®: Beyond Earth™
FIFA 2015
GRID Autosport
Ryse: Son of Rome
Talos Principle
The Crew
Grand Theft Auto V
Dying Light
The Witcher® 3: Wild Hunt
Performance Optimizations versus AMD Catalyst™ Omega Driver
Single GPU performance on Windows® 8.1 based system:
Up to 7% in Far Cry® 4 on AMD Radeon™ R7 and AMD Radeon™ R9 200 series and up *
Up to 10% in Tomb Raider on AMD Radeon™ R7 and AMD Radeon™ R9 200 series and up *
http://support.amd.com/en-us/kb-articles/Pages/AMDCatalyst15-7WINReleaseNotes.aspx
