Evento:
<4>Jan 1 00:00:22 Activate SLICs => 0
<4>Jan 1 00:00:22 BRAZIL Initialization
<4>Jan 1 00:00:22 osAssignInterrupt: Enable IRQ(17) for DSP
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 Enable IRQ for DSP
<4>Jan 1 00:00:22 osAssignInterrupt: Enable IRQ(21) for DSP
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 # DSP Voice Module Part 2 Loading Ok
<4>Jan 1 00:00:22 ##################################################
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/rtp.o 0xc0377000 -s .data 0xc03824c0 -s .bss 0xc0382fa0
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 # RTP Stack Module Loading ...
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 Register /dev/rtp Device ...Register /sys/sagem/rtp SysCtl ...<6>device eth0 entered promiscuous mode
<4>Jan 1 00:00:22 Setting Max Stations:32
<6>Jan 1 00:00:22 2xMaxPowerLevel: 38 (LEG)
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 JXU: set the rxBufsize to 3851
<4>Jan 1 00:00:22 ath_newstate: ath0: INIT -> SCAN
<4>Jan 1 00:00:22 ath_newstate: ath0: SCAN -> JOIN
<4>Jan 1 00:00:22 ath_chan_set: Changing to channel - 9 - (2452), Flags 30080, PF 0
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 ath_newstate: ath0: JOIN -> RUN
<6>Jan 1 00:00:22 device ath0 entered promiscuous mode
<4>Jan 1 00:00:22 ath_newstate: ath0: RUN -> INIT
<4>Jan 1 00:00:22 ni->ni_vap->iv_opmode = 6
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22
<30>Jan 1 00:00:23 hostapd: ath0: STA f8:d0:bd:66:e5:02 IEEE 802.11: associated
<30>Jan 1 00:00:23 hostapd: ath0: STA f8:d0:bd:66:e5:02 WPA: pairwise key handshake completed (RSN)
<30>Jan 1 00:00:24 hostapd: ath0: STA 64:20:0c:31:d4:a0 IEEE 802.11: associated
<30>Jan 1 00:00:24 hostapd: ath0: STA 64:20:0c:31:d4:a0 WPA: pairwise key handshake completed (RSN)
<30>Jan 1 00:00:24 hostapd: ath0: STA 44:a7:cf:e4:47:ba IEEE 802.11: associated
<30>Jan 1 00:00:24 hostapd: ath0: STA 44:a7:cf:e4:47:ba WPA: pairwise key handshake completed (RSN)
<4>Jan 1 00:01:00 ADSL_LINK_UP_CONF..
<4>Jan 1 00:01:00
<4>Jan 1 00:01:00
<4>Jan 1 00:01:00
<4>Jan 1 00:01:02 CONFIGURATION en UBR_NO_PCR
<4>Jan 1 00:01:02 >>> bmChangeMacList currNumConfiguredMacAddrs = 0 MAX_NUM_SUPPORTED_MAC_ADDRESSES = 4
<4>Jan 1 00:01:02 0x2c:0xe4:0x12:0x9c:0x64:0x1e
<4>Jan 1 00:01:04 QOS: vpi 0 vci 36
<4>Jan 1 00:01:04 CLASS_CBR
<4>Jan 1 00:01:04
<4>Jan 1 00:01:04 >>> bmChangeMacList MacAddress = 0x2c:0xe4:0x12:0x9c:0x64:0x1e
<4>Jan 1 00:01:04 >>> bmChangeMacList index = 0 listMacAddr = 0x2c:0xe4:0x12:0x9c:0x64:0x1e
<4>Jan 1 00:01:04 QOS: vpi 0 vci 37
<4>Jan 1 00:01:04 >>> bmChangeMacList currNumConfiguredMacAddrs = 1 MAX_NUM_SUPPORTED_MAC_ADDRESSES = 4
<4>Jan 1 00:01:04 QOS: vpi 0 vci 38
<30>May 4 18:36:54 hostapd: ath0: STA 64:20:0c:31:d4:a0 WPA: group key handshake completed (RSN)
<30>May 4 18:36:54 hostapd: ath0: STA f8:d0:bd:66:e5:02 WPA: group key handshake completed (RSN)
<30>May 4 18:36:54 hostapd: ath0: STA 44:a7:cf:e4:47:ba WPA: group key handshake completed (RSN)
<30>May 4 19:09:06 hostapd: ath0: STA 44:a7:cf:e4:47:ba IEEE 802.11: deassociated
<30>May 4 19:17:34 hostapd: ath0: STA 44:a7:cf:e4:47:ba IEEE 802.11: associated
<30>May 4 19:17:34 hostapd: ath0: STA 44:a7:cf:e4:47:ba WPA: pairwise key handshake completed (RSN)
<30>May 4 19:19:46 hostapd: ath0: STA f8:d0:bd:66:e5:02 IEEE 802.11: deassociated
<30>May 4 19:21:39 hostapd: ath0: STA f8:d0:bd:66:e5:02 IEEE 802.11: associated
<30>May 4 19:21:39 hostapd: ath0: STA f8:d0:bd:66:e5:02 WPA: pairwise key handshake completed (RSN)
<30>May 4 19:39:17 hostapd: ath0: STA f8:d0:bd:66:e5:02 IEEE 802.11: deassociated
<30>May 4 19:39:33 hostapd: ath0: STA 44:a7:cf:e4:47:ba IEEE 802.11: deassociated
<30>May 4 19:41:13 hostapd: ath0: STA 44:a7:cf:e4:47:ba IEEE 802.11: associated
<30>May 4 19:41:13 hostapd: ath0: STA 44:a7:cf:e4:47:ba WPA: pairwise key handshake completed (RSN)
<30>May 4 19:44:39 hostapd: ath0: STA 44:a7:cf:e4:47:ba IEEE 802.11: deassociated
ces at 0x0 in 16-bit bank
<4>Jan 1 00:00:22 Amd/Fujitsu Extended Query Table at 0x0040
<4>Jan 1 00:00:22 openrg_flash: CFI does not contain boot bank location. Assuming top.
<5>Jan 1 00:00:22 number of CFI chips: 1
<5>Jan 1 00:00:22 cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
<5>Jan 1 00:00:22 Creating 1 MTD partitions on "openrg_flash":
<5>Jan 1 00:00:22 0x00000000-0x02000000 : "openrg"
<4>Jan 1 00:00:22 openrg_flash: detected at 0x1e000000 size 33554432 bytes
<6>Jan 1 00:00:22 Freeing unused kernel memory: 136k freed
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/hard_watchdog_module.o 0xc0004000 -s .data 0xc0005820 -s .bss 0xc0005960
<4>Jan 1 00:00:22
<6>Jan 1 00:00:22 HardwareWatchdogInitialize : NORMAL BOOT
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 HardwareWatchdogInitialize :: --- WATCHDOG -- INITIALIZED with ED72 value (i.e. 5999ms)
<4>Jan 1 00:00:22 HardwareWatchdogInitialize :: --- WATCHDOG -- Pacify timer of 2000 ms STARTED
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/be_pppoa_mod.o 0xc0007000 -s .data 0xc0008710 -s .bss 0xc0008860
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/fusivlib.o 0xc0022000 -s .data 0xc002eb50 -s .bss 0xc0030ee0
<4>Jan 1 00:00:22 fusiv library initializing...
<4>Jan 1 00:00:22 Buffer Copy Through DMA is enabled
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 fusiv library initialized SUCCESSFULLY...
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/bus_arbiter_lkm.o 0xc000a000 -s .data 0xc000b380 -s .bss 0xc000b4e0
<4>Jan 1 00:00:22 vox bus arbiter interrupt handlers registered
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/opensrc_lkm.o 0xc0002000 -s .data 0xc00026d0 -s .bss 0xc0002820
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/bm.o 0xc0014000 -s .data 0xc0017170 -s .bss 0xc0017340
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 Buffer Manager is initializing...
<4>Jan 1 00:00:22 BMU GIGE clock
<4>Jan 1 00:00:22 Slave Mem Alloc: Req size 16 Ptr2Block 0x191f0000
<4>Jan 1 00:00:22 Load into BM APU Successful !!!
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 Buffer Manager initialized SUCCESSFULLY...
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/sysutil.o 0xc0019000 -s .data 0xc001c240 -s .bss 0xc001c380
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/timerlib.o 0xc0010000 -s .data 0xc0010de0 -s .bss 0xc0010f40
<4>Jan 1 00:00:22 Timers are getting initalized
<4>Jan 1 00:00:22 Timers are initilized SUCCESSFULLY...
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/ethdriver.o 0xc0044000 -s .data 0xc004bb20 -s .bss 0xc004e900
<4>Jan 1 00:00:22 Module params: eth0_mii=0 eth1_mii=1
<4>Jan 1 00:00:22 eth0: Netpro Sierra Ethernet found at 0xb9110000, irq 14
<4>Jan 1 00:00:22 GIGE 1 clock dev->baseAddr b9110000
<4>Jan 1 00:00:22 Slave Mem Alloc: Req size 16 Ptr2Block 0x191f0010
<4>Jan 1 00:00:22 eth0 interface configured in GMII mode
<4>Jan 1 00:00:22 eth1: Netpro Sierra Ethernet found at 0xb9150000, irq 13
<4>Jan 1 00:00:22 GIGE 2 clock dev->baseAddr b9150000
<4>Jan 1 00:00:22 SraPort_initializePort: phyAddr=0x1f: PHY attached
<4>Jan 1 00:00:22 Slave Mem Alloc: Req size 16 Ptr2Block 0x191f0020
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 Ethernet Driver is initialized SUCCESSFULLY
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/atmdriver_lkm.o 0xc0078000 -s .data 0xc008c2a0 -s .bss 0xc008e940
<4>Jan 1 00:00:22 VDSL AP and VDSL PHY clocks are enabled
<4>Jan 1 00:00:22 Slave Mem Alloc: Req size 8 Ptr2Block 0x191f0030
<4>Jan 1 00:00:22 Slave Mem Alloc: Req size 72 Ptr2Block 0x191f0038
<4>Jan 1 00:00:22 Slave Mem Alloc: Req size 120 Ptr2Block 0x191f0080
<4>Jan 1 00:00:22 Slave Mem Alloc: Req size 192 Ptr2Block 0x191f00f8
<4>Jan 1 00:00:22 Slave Mem Alloc: Req size 256 Ptr2Block 0x191f01b8
<4>Jan 1 00:00:22 Calling vdslAtmCellHeaderRAMReset()....
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 ATM Driver Initialized SUCCESSFULLY...
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/periap.o 0xc003a000 -s .data 0xc003bc20 -s .bss 0xc003dc60
<4>Jan 1 00:00:22 periApDriverInit: doneSlave Mem Alloc: Req size 16 Ptr2Block 0x191f02b8
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 *******LOAD firmware to AP
![Stick Out Tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
ERI_ID result:0Load into PERI_AP APU Successful !!!
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/ath_hal.o 0xc02bb000 -s .data 0xc03285d0 -s .bss 0xc0332f00
<6>Jan 1 00:00:22 ath_hal: 0.9.14.25 (AR5212, AR5416, RF5111, RF5112, RF2413, RF5413, DEBUG, REGOPS_FUNC)
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/wlan.o 0xc0336000 -s .data 0xc0375030 -s .bss 0xc03758e0
<6>Jan 1 00:00:22 wlan: 0.8.4.2 (Atheros/multi-bss)
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/ath_rate_atheros.o 0xc0061000 -s .data 0xc0066970 -s .bss 0xc006f440
<6>Jan 1 00:00:22 ath_rate_atheros: Version 2.0.1
<4>Jan 1 00:00:22 Copyright (c) 2001-2004 Atheros Communications, Inc, All Rights Reserved
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/ath_dfs.o 0xc022f000 -s .data 0xc0237c00 -s .bss 0xc0237d80
<6>Jan 1 00:00:22 ath_dfs: Version 2.0.0
<4>Jan 1 00:00:22 Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/wlan_wep.o 0xc000d000 -s .data 0xc000e830 -s .bss 0xc000e980
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/wlan_tkip.o 0xc003f000 -s .data 0xc0042410 -s .bss 0xc0042560
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/wlan_ccmp.o 0xc001e000 -s .data 0xc0020250 -s .bss 0xc00203a0
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/wlan_xauth.o 0xc0033000 -s .data 0xc0033300 -s .bss 0xc0033440
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/wlan_acl.o 0xc0050000 -s .data 0xc0051010 -s .bss 0xc0051160
<6>Jan 1 00:00:22 wlan: mac acl policy registered
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/ath_pci.o 0xc0274000 -s .data 0xc029fdf0 -s .bss 0xc02a09e0
<6>Jan 1 00:00:22 ath_pci: 0.9.4.5 (Atheros/multi-bss)
<6>Jan 1 00:00:22 ath_pci: CR-LSDK-1.3.1.110_3-4-9_0-0-draft_10
<4>Jan 1 00:00:22 PCI: Enabling device 0000:00:03.0 (0000 -> 0002)
<4>Jan 1 00:00:22 wifi%d ath_pci_probe Mac Address to configure 2c:e4:12:9c:64:21
<6>Jan 1 00:00:22 ar5416InitMacAddr: Eeprom mac address read : 74:b4:92:9f:df:75
<4>Jan 1 00:00:22 Chan Freq RegPwr HT CTL CTL_U CTL_L DFS
<4>Jan 1 00:00:22 1 2412n 27 HT20 1 0 1 N
<4>Jan 1 00:00:22 1 2412n 20 HT40 1 0 1 N
<4>Jan 1 00:00:22 2 2417n 20 HT40 1 0 1 N
<4>Jan 1 00:00:22 3 2422n 20 HT40 1 1 1 N
<4>Jan 1 00:00:22 4 2427n 20 HT40 1 1 1 N
<4>Jan 1 00:00:22 5 2432n 20 HT40 1 1 1 N
<4>Jan 1 00:00:22 6 2437n 20 HT40 1 1 1 N
<4>Jan 1 00:00:22 7 2442n 20 HT40 1 1 1 N
<4>Jan 1 00:00:22 8 2447n 20 HT40 1 1 1 N
<4>Jan 1 00:00:22 9 2452n 20 HT40 1 1 1 N
<4>Jan 1 00:00:22 10 2457n 20 HT40 1 1 1 N
<4>Jan 1 00:00:22 11 2462n 20 HT40 1 1 1 N
<4>Jan 1 00:00:22 12 2467n 20 HT40 1 1 0 N
<4>Jan 1 00:00:22 13 2472n 20 HT40 1 1 0 N
<4>Jan 1 00:00:22 dfs_init_radar_filters: dfs->dfs_rinfo.rn_numradars: 0
<4>Jan 1 00:00:22 DFS min filter rssiThresh = 18
<4>Jan 1 00:00:22 DFS max pulse dur = 131 ticks
<4>Jan 1 00:00:22 wifi0: 11ng rates: 1Mbps 2Mbps 5.5Mbps 11Mbps 6Mbps 9Mbps 12Mbps 18Mbps 24Mbps 36Mbps 48Mbps 54Mbps
<4>Jan 1 00:00:22 wifi0: 11ng MCS: 0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15
<4>Jan 1 00:00:22 wifi0: mac 384.2 phy 15.15 radio 12.0
<4>Jan 1 00:00:22 wifi0: Use hw queue 1 for WME_AC_BE traffic
<4>Jan 1 00:00:22 wifi0: Use hw queue 0 for WME_AC_BK traffic
<4>Jan 1 00:00:22 wifi0: Use hw queue 2 for WME_AC_VI traffic
<4>Jan 1 00:00:22 wifi0: Use hw queue 3 for WME_AC_VO traffic
<4>Jan 1 00:00:22 wifi0: Use hw queue 8 for CAB traffic
<4>Jan 1 00:00:22 wifi0: Use hw queue 9 for beacons
<4>Jan 1 00:00:22 wifi0: Use hw queue 7 for UAPSD
<6>Jan 1 00:00:22 2xMaxPowerLevel: 32 (LEG)
<4>Jan 1 00:00:22
<6>Jan 1 00:00:22 wifi0: ath_pci_probe 320 Mac Address configured 2c:e4:12:9c:64:21
<6>Jan 1 00:00:22 wifi0: Atheros 9287: mem=0x1a000000, irq=25 hw_base=0xba000000
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/one_module.o 0xc03f5000 -s .main_flow 0xc0431a90 -s .data 0xc0450ed0 -s .bss 0xc0452d80
<4>Jan 1 00:00:22 Loading license 2e7cce03ae1ecdf8664e2a9d4237505fb4b92a03b3c702e282dad8703897fb79647f254aad168a000042689d4bbeae320ee12b21d44036dba65548ebd421923317a5e6fd3f30792f5c8c58b63fbb65f614a9b3010287.SAGEM
<4>Jan 1 00:00:22 loading license key: SAGEM
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/kleds_mod.o 0xc0053000 -s .data 0xc0054430 -s .bss 0xc00545c0
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/lb_jffs_mod.o 0xc0035000 -s .data 0xc0035200 -s .bss 0xc0035360
<5>Jan 1 00:00:22 0x01b00000-0x02000000 : "jffs2"
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/wlan_scan_ap.o 0xc005c000 -s .data 0xc005f940 -s .bss 0xc005fa80
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/hw_qos_ikanos_mod.o 0xc0037000 -s .data 0xc0037900 -s .bss 0xc0037a80
<4>Jan 1 00:00:22 hw_qos_init:183 init module
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/igmp_proxy_mod.o 0xc0244000 -s .data 0xc024b190 -s .bss 0xc024b2e0
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/rg_usfs.o 0xc0075000 -s .data 0xc0076510 -s .bss 0xc0076680
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/tcp_mss.o 0xc0000000 -s .data 0xc0000a00 -s .bss 0xc0000b80
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/rg_dhcp_pktfil.o 0xc0239000 -s .data 0xc023a440 -s .bss 0xc023a5c0
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/rg_ipv4.o 0xc0073000 -s .data 0xc0073440 -s .bss 0xc00735c0
<4>Jan 1 00:00:22 IPV4 device driver registered
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/pppoe_relay.o 0xc024d000 -s .data 0xc0250800 -s .bss 0xc0250940
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/rg_pppoe_relay.o 0xc0071000 -s .data 0xc0071db0 -s .bss 0xc0071f20
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/ife6DriverLoad_mod.o 0xc023e000 -s .data 0xc023e440 -s .bss 0xc023e5c0
<4>Jan 1 00:00:22 Initializing IFE6 Driver Load module
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/watchdog_mod.o 0xc023c000 -s .data 0xc023c9f0 -s .bss 0xc023cb60
<4>Jan 1 00:00:22 Initializing Watchdog module
<4>Jan 1 00:00:22 Initializing Watchdog module1
<4>Jan 1 00:00:22 Initializing Watchdog module2
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/btn.o 0xc0265000 -s .data 0xc0265c40 -s .bss 0xc0265de0
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/qos_ingress.o 0xc0267000 -s .data 0xc02681b0 -s .bss 0xc0268340
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/bmedrv.o 0xc026a000 -s .data 0xc026ade0 -s .bss 0xc026afa0
<4>Jan 1 00:00:22 bmedrv_init: Region 0x07800000 - 0x07ffffff allocated successfully
<4>Jan 1 00:00:22 BME Driver has been loaded SUCCESSFULLY
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/switch.o 0xc026c000 -s .data 0xc026d000 -s .bss 0xc026d1c0
<4>Jan 1 00:00:22 m88e6x6x switch driver for vx180 loaded
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 insmod: add-symbol-file build/debug/dspvoice.o 0xc048c000 -s .data 0xc04c5710 -s .bss 0xc04c98a0
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 # DSP Voice Module Part 1 Loading ...
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 Register /sys/sagem/voice SysCtl ... OK
<4>Jan 1 00:00:22 Using: Software Voicedriver orig_2-1-17_3-6-1 : 2008
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 # DSP Voice Module Part 1 Loading Ok
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 # DSP Voice Module Part 2 Loading ...
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 Could not find DSP configuration file, setting to defaults
<4>Jan 1 00:00:22 Save and reboot the system to effect the Codec Mode : 2
<4>Jan 1 00:00:22 Total words found in /dsp/dsp218x_1ch_faxonly.dsp Image 31948
<4>Jan 1 00:00:22 Total words found in /dsp/dsp218x_1ch_g729only.dsp Image 31948
<4>Jan 1 00:00:22 Total words found in /dsp/dsp218x_1ch_g711vad2only.dsp Image 31948
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 Registering Call Back Handlers
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 DSP TIME SLOT Assigned:260
<4>Jan 1 00:00:22 DSP CLock Assigned:27
<4>Jan 1 00:00:22 DSP Codec Type Assigned:2
<4>Jan 1 00:00:22 DSP SPORT Control Reg Assigned:c30f
<4>Jan 1 00:00:22 ADSP218x DOWNLOAD DONE !!!!
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 DSP Ver No:1.1
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 DSP TIME SLOT Assigned:40
<4>Jan 1 00:00:22 DSP SPORT Control Reg Assigned:820f
<4>Jan 1 00:00:22
<4>Jan 1 00:00:22 Initialization SLIC system
<4>Jan 1 00:00:22 Initializing Voice
<4>Jan 1 00:00:22 slic GPIO is 12
<4>Jan 1 00:00:22 Initializing SPI Module
<4>Jan 1 00:00:22 SAGEM SLIC card as SILABS
<4>Jan 1 00:00:22 Initializing SLICs
<4>Jan 1 00:00:22 Country use for SLIC BRAZIL
<4>Jan 1 00:00:22 port 0 is Si32176
<4>Jan 1 00:00:22 LOAD Si3217 PATCH for Rev B
<4>Jan 1 00:00:22 No verif
<4>Jan 1 00:00:22 Si3217 patch version 0X09292009
<4>Jan 1 00:00:22 Patch loaded successfully
<4>Jan 1 00:00:22 PATCH Ret=0
<4>Jan 1 00:00:22 MDAC Calibration for channel
<4>Jan 1 00:00:22 other Calibration
<4>Jan 1 00:00:22 ZCAL Calibration
ll Trace:
size to 3851
Nb 1
:00:20 Primary data cache 32kB, 4-way, linesize 32 bytes.
<4>Jan 1 00:00:22 Primary data cache 32kB, 4-way, linesize 32 bytes.
<4>Jan 1 00:00:20 Synthesized TLB refill handler (20 instructions).
<4>Jan 1 00:00:21 Synthesized TLB refill handler (20 instructions).
<4>Jan 1 00:00:22 Synthesized TLB refill handler (20 instructions).
<4>Jan 1 00:00:23 Synthesized TLB refill handler (20 instructions).
