VoWiFi da claro morreu né? Até recebe SMS, mas toda vez que faço call ele cai (um conhecido do RJ também ta com essa treta).
Já ouvi esse comentário de um amigo. É o terceiro caso que vejo. Bem estranho mesmo...VoWiFi da claro morreu né? Até recebe SMS, mas toda vez que faço call ele cai (um conhecido do RJ também ta com essa treta).
E qual a franquia desse negócio mesmo?Rapaz, interessante esses planos:
No topo ali diz no data cap, então ilimitado?E qual a franquia desse negócio mesmo?
Pelo jeito e por enquanto, sem franquia alguma.E qual a franquia desse negócio mesmo?
de plano móvel tem alguns modelos:No topo ali diz no data cap, então ilimitado?
What speeds and performance can a Verizon Broadband Internet Access Services customer expect, and where are these speeds available?
Based on our internal testing and testing commissioned from third-party vendors, Verizon expects customers will experience the following speeds unless such speeds are otherwise managed through network optimization practices described in your plan (any mobile speed ranges are based on the approximate 25th and 75th percentiles of network tests):
- 5G Ultra Wideband network:
- Mobile: typical download speeds of 90-170 Mbps with higher speeds and peaks over 1 Gbps in certain areas. Typical upload speeds of 15-30 Mbps with peak upload speeds over 100 Mbps. Uploads may be over 5G Nationwide and 4G LTE in lower signal strength conditions. Our 5G Ultra Wideband network is still being deployed and optimized. These speeds are projections based solely on internal testing, not the 25th and 75th percentiles of network tests. We will provide updates as we further deploy and optimize the network and gather more data.
- 5G Home Internet:
- 5G Home Internet plans vary depending on address/location, equipment, and network connection:
- With the 5G Internet Gateway, download speeds up to 300 Mbps. Typical upload speeds around 50 Mbps. Uploads may be over 5G Nationwide and 4G LTE in lower signal strength conditions. 4G LTE backup.
- With the Verizon Internet Gateway, download speeds of 85-300 Mbps. Typical upload speeds around 10 Mbps. Depending on location, uploads over 5G Ultra Wideband or 4G LTE, 4G LTE backup with download speeds up to 70 Mbps.
- 5G Home Internet Plus plans vary depending on address/location, equipment, and network connection:
- With the 5G Internet Gateway, download speeds of 300-1000 Mbps. Typical upload speeds around 50 Mbps. Uploads may be over 5G Nationwide and 4G LTE in lower signal strength conditions. 4G LTE backup.
Para quem ainda tem xDSL esse plano vale muito a pena. Agora, se for comparar com um FTTH 1gb simétrico, ainda vou preferir o FTTH. FTTH ainda tem MUITO gás. E outra, FTTH é internet fixa, se for pegar um 4g da vida e um plano de 350mb da claro HFC, escolho 100% o HFC. Já tive algumas boas decepções em relação ao 4G (Implantado aq no BR) (acredito que quase todos aqui já passaram alguma raiva com internet móvel).Rapaz, interessante esses planos:
ti falar, 4g nosso aqui no BR é melhor do que 4g do USA, então já vai entendendo que conexão FWA não é pra qual quer tipo de uso mesmoPara quem ainda tem xDSL esse plano vale muito a pena. Agora, se for comparar com um FTTH 1gb simétrico, ainda vou preferir o FTTH. FTTH ainda tem MUITO gás. E outra, FTTH é internet fixa, se for pegar um 4g da vida e um plano de 350mb da claro HFC, escolho 100% o HFC. Já tive algumas boas decepções em relação ao 4G (Implantado aq no BR).
Jurava que era melhor, sempre vejo a mídia brasileira almejar os EUA na questão de telecomunicação móvel. Tinha a visão que era 100% ""perfeito"" kkkkkk.ti falar, 4g nosso aqui no BR é melhor do que 4g do USA, então já vai entendendo que conexão FWA não é pra qual quer tipo de uso mesmo![]()
não, é uma zona do caralho.Jurava que era melhor, sempre vejo a mídia brasileira almejar os EUA na questão de telecomunicação móvel. Tinha a visão que era 100% ""perfeito"" kkkkkk.
Se tratando de Verizon, estar congestionada é um fato diário.
- se a rede estiver sobrecarregada, pode sofrer redução de velocidade no momento
Claro?Galera! Meu iphone recebeu uma ligação da azul hoje e NAO CAIU PRO 3G!! Testei depois ligando pra outro numero e continuou funcionando no 4G, VoLTE liberado pro DDD19?
Liguei pro iphone da patroa q é uma linha dependente no meu plano e tbm nao caiu, qualidade de audio melhor tambem.
Vai ver foi essa liberação que derrubou o VoWiFi kkk
tim like do USASe tratando de Verizon, estar congestionada é um fato diário.
Heh.tim like do USA![]()
SimClaro?
engraçadinhos.
E pensar que a Verizon foi uma das pioneiras da fibra nos EUA (e quissá do mundo), mas pararam de expandir.
Esses planos não vão permanecer, ele foram jogadas da Oi para sugar o máximo de dinheiro devido a venda da Oi móvel! As operadoras que assumirem, não vão manter esses planos e vão forçar os clientes a migrar para novos planos.Galera, me ajuda ai por favor
OI antigamente era uma porcaria, não funcionava 4g em lugar nenhum fora a velocidade baixa.
Com essa mudança, aqui no rio de janeiro quem ficará responsável será a TIM.
Então a TIM só será responsável pela empresa móvel ou irão utilizar os sinais de antena também?
Digo isso porque a OI tem uns planos legais de controle
