Quando isso ocorrer, peço a você que abra o arquivo Game.log, que fica na pasta Crysis Wars, copie o seu conteúdo, e cole aqui pra gente dar uma olhada, ok?
Deve haver algo de errado, já que ninguém mais está tendo problemas de kicks com PB lá no TERRA.
vc pediu agora toma!!!!
BackupNameAttachment=" Build(6627) Date(19 Feb 2009) Time(15 01 19)" -- used by backup system
Log Started at Thursday, February 19, 2009 15:01:19
Running 32 bit version
Executable: F:\Program Files\Electronic Arts\Crytek\Crysis Wars\Bin32\Crysis.exe
FileVersion: 1.1.1.6627
ProductVersion: 1.1.1.6627
Using STLport C++ Standard Library implementation
--- CPU detection ---
Total number of logical processors: 2
Number of available logical processors: 2
Processor 0:
CPU: Intel Intel(R) Core(TM)2 Duo CPU E6750 @ 2.66GHz
Family: 6, Model: 15, Stepping: 11
FPU: On-Chip
CPU Speed (estimated): 3599.951919 MHz
MMX: not present
SSE: present
3DNow!: not present
Serial number not present or disabled
Processor 1:
FPU: On-Chip
CPU Speed (estimated): 3599.945957 MHz
MMX: not present
SSE: present
3DNow!: not present
Total number of system cores: 2
Number of cores available to process: 2
Windows Vista 32 bit SP 1 (build 6.0.6001)
System language: Portuguese
Windows Directory: "C:\Windows"
Prerequisites...
* Installation of KB940105 hotfix required: no! (either not needed or already installed)
Local time is 15:01:20 02/19/09, system running for 9 minutes
3071MB physical memory installed, 2117MB available, 2047MB virtual memory installed, 31 percent of memory in use
PageFile usage: 47MB, Working Set: 21MB, Peak PageFile usage: 48MB,
Current display mode is 1280x1024x32, VGA
IBM enhanced (101/102-key) keyboard and 5+ button mouse installed
Stream Engine Initialization
Network initialization
[net] using iocp socket io management
Physics initialization
MovieSystem initialization
Renderer initialization
Console initialization
Time initialization
Input initialization
Sound initialization
Sound - initializing AudioDevice now!
Sound - starting to initialize Windows Audio Session API output!
Sound - 2 drivers found:
Sound - available drivers: 0 Alto-falantes (Realtek High Definition Audio) !
Sound - available drivers: 1 Realtek Digital Output (Realtek High Definition Audio) !
Sound - initializing FMOD-EX now!
Sound - initialized FMOD-EX
Sound - available record drivers: 0 Áudio CD (Realtek High Definition Audio) !
Sound - available record drivers: 1 Mixagem estéreo (Realtek High Definition Audio) !
Sound - using FMOD version: 00041403 and internal 00041403!
Sound - initializing SoundSystem now!
Font initialization
AI initialization
Initializing Animation System
Initializing 3D Engine
Script System Initialization
Entity system initialization
Initializing AI System
[PlayerProfiles] Login of user 'Yan' successful.
[PlayerProfiles] Found 2 profiles.
Profile 0 : 'default'
Profile 1 : 'YanMD'
[GameProfiles]: Successfully activated profile 'default' for user 'Yan'
$3r_FSAA = $60 $5[DUMPTODISK, REQUIRE_APP_RESTART]$4
$3r_FSAA_samples = $60 $5[DUMPTODISK, REQUIRE_APP_RESTART]$4
$3r_FSAA_quality = $60 $5[DUMPTODISK, REQUIRE_APP_RESTART]$4
[net 18:01:20.622] network hostname: YAN
[net 18:01:20.627] ip:189.122.150.85
[net 18:02:43.508] $5$5PunkBuster Client: PunkBuster Client (v2.115 | A0) Enabled
[net 18:02:43.512] connection requested to: 200.177.229.46:64087
[net 18:02:43.512] resolved as: 200.177.229.46:64087
[net 18:02:43.549] $5$5PunkBuster Client: Changing (Vista) homepath to [C:\Users\Yan\AppData\Local\PunkBuster\WH\pb\]
[net 18:02:43.602] $5$5PunkBuster Client: Attempting to resolve master5.evenbalance.com
[net 18:02:43.730] $5$5PunkBuster Client: Resolved to [66.36.231.175] (14)
[net 18:02:43.731] $5$5PunkBuster Client: PunkBuster Client (v2.115 | A0) Enabled
[net 18:02:43.751] $5$5PunkBuster Client: Game Version [1.1.1.6627]
[net 18:02:43.751] $5$5PunkBuster Client: Not Connected to a Server
[net 18:02:43.752] $5$5PunkBuster Client: Master Query Sent to (WH1.EVENBALANCE.COM) 66.180.170.20
[net 18:02:44.364] $5$5PunkBuster Client: Connected to Server 200.177.229.46:64087
[net 18:02:46.580] $5$5PunkBuster Client: PB Services socket initialized
[net 18:02:51.557] $5$5PunkBuster Client: PnkBstrA successfully loaded PnkBstrB
[net 18:02:53.598] $5$5PunkBuster Client: PnkBstrB service installed and started successfully
Game rules class: PowerStruggle
*LOADING: Level multiplayer/ps/refinery loading time: 25.96 seconds
[net 18:03:31.790] $5$5PunkBuster Client: WARNING: $1PB Kicks for Level 1 PB Restrictions on this Server
[net 18:03:31.791] $5$5PunkBuster Client: PB Server assigned guid = 2f1542925d577540e5175288250d3825
[net 18:03:31.791] $5$5PunkBuster Client: Receiving from PB Server (w v1.736 | A1394 C2.160)
[net 18:03:32.158] $5$5PunkBuster Client: 0 Current Cvar Violations
[server] Leia as regras do servidor em
http://ranking.terra.com.br/forum
CHAT YanMD to ALL:
nossa como ta lotado isso daki
[server] Proibido Vtol ou Helicoptero camperando Bunkers ou HQ
[server] Proibido Team Kill intencional - Passivel de Kick e Ban
[server] Proibido Nuke contra Infantaria, Nukes apenas contra o HQ ou em caso de defesa
[net 18:07:20.268] $5$5PunkBuster Client: Receiving from PB Server (w v1.736 | A1394 C2.160)
[server] Proibido roubar veiculos amigos - Passivel de Kick e Ban
[server] Proibido Cheater - Banimento Imediato
[server] Proibido Pornografia, Pirataria e Ofensas - Passivel de Kick e Ban
[server] Divirta-se e sinta-se a vontade para conversar com os Adminsistradores
[net 18:11:28.286] $5$5PunkBuster Client: Receiving from PB Server (w v1.736 | A1394 C2.160)
[net 18:13:36.659] $5$5PunkBuster Client: Removing "LucasHS" 2fbb (10 minutes) Ignoring MD5Tool Queries
[net 18:15:31.563] $5$5PunkBuster Client: Receiving from PB Server (w v1.736 | A1394 C2.160)
[net 18:15:36.443] Disconnect morondava.terra.com.br:64087; profid=0; cause=16; msg='Remote disconnected: PunkBuster kicked player 'YanMD' (for 0 minutes) ... Time Out trying to Update PB Client'
CGameClientChannel::Release
[net 18:15:36.458] $5$5PunkBuster Client: Not Connected to a Server
[Warning] Unknown command: WarningBox
System:Quit
O MAIS ENGRAÇADO DESSE LOG Q EU ACHEI FOI ISSO [net 18:13:36.659] $5$5PunkBuster Client: Removing "LucasHS" 2fbb (10 minutes) Ignoring MD5Tool Queries
HauHaUahUAHAuHA LUCASHS VC NAO ME ESKAPA FD*!!! edit: pesquisei em foruns no pb e isso nao eh necessariamente xite* e sim problemas tecnicos de conexao... entao nada a comprovar =/
