kkkk que nada,em Dark Souls morrer faz parte!e eu morri em?putzVocê vai estar fodido no NG+ no ultimo boss do DLC :seferrou:
In order to reach the new area/content in Dark Souls: Prepare to Die Edition please read the following below.
To reach the new content/area you will need to first defeat the Hydra found in the Darkroot Basin. After defeating the Hydra you may need to leave the area and return for the Brown Crystal Golem to appear in the cave found past where the Hydra was located. Once you have defeated the Brown Crystal Golem the spirit of Oolacile will appear, select yes to her question.
At this point you will need to continue your normal playthrough until you reach the Duke's Archives (after placing the Lordvessel which will unlock the orange/yellow mist). In the Duke's Archives defeat the Blue Crystal Golem located at the top of the first elevator in order to receive the item "Broken Pendant".
Return to the area in the Darkroot Basin where you fought the Brown Crystal Golem and a black mist will be present, examine it to warp to the new area/content. (Please note: if you summon Oolacile (to buy spells etc.) and she is present in the Darkroot Basin area/map, the black mist will not appear so make sure you do not summon her from the summon sign that appears on the shore).
Vlw cara,estranho,matei o golem,devo ter pegado o pendent,mas nem me toquei que tinha que voltar,nem sabia que o dlc só podia ser acesado assim:fuuu:
Mas tentarei dinovo....
