lançar uma dlc que é bom nada.....caraca ja deu no saco ficar no mesmo map "rum forest, rum...."
sera que com a saida do Jay melhora?
Lançar DLC...
Eu até gostei do que ele escreveu, mas me lembrei do "fuck that loser" e relembrei que esse cara é um babaca.
Eita........e eu aqui parado
Eu tenho 1 peito imortal quer comprar ?
hj o dia rendeu
Items in review Tal Rasha's Allegiance
Time of transaction 17 Jan 2013 08:09 PM PST
Total value in review $92.79
Não tinha ninguém para te ajudar ai online agora???Nunca tinha tentado solar uber, não gosto de ficar catando chave sozinho, mas fui tentar agora de noite("agora de noite" fazem algumas horas já) no mp10 aqui é 8 ou 80
Fiz os 2 primeiros de boa, fui todo feliz fazer o último achando que iria abalar kell + siegebreaker que apelação aquilo ali além do dano, siegebreaker da stun direto e ainda tem o reflete pra foder com o ls sem falar nas bolhas :fuuu: tentei várias estratégias preciso de mais ias% pra poder ignorar as bolhas ainda to fraco
Players are intended to be Elite, but after some investigation (thanks to your reports) we were able to determine that this isn't happening on the current build of the PTR. That's absolutely a bug and we'll be fixing it for a future PTR build.
Once the bug is addressed, this is what you can expect:
1. +Damage vs. Elites and +Reduced Damage from Elites affixes on items should work correctly against players.
2. The CC reduction rules that apply to Elite monsters in Inferno should also apply against players. Much like Elite monsters in Inferno, players will cap out at 65% CC reduction (with CC effects less than 0.5 seconds being ignored). These values are subject to change or go through different iterations as the PTR continues.
3. There is also an inherent 30% CC reduction in player vs. player which is not currently working on the PTR. So, a 4 second stun should only last 2.8 seconds in PvP combat. This can, of course, be combined with CC reduction from gear and skills.
(Note that pets are not currently considered Elite.)
Já fiz uber várias vezes, mas nunca sozinho, fiz pra vez se eu conseguia, simples assim, ainda faço saporra solo no 10, sem renovar nvNão tinha ninguém para te ajudar ai online agora???
Colocava no geral, sempre tem uns candangos fissurados pelos ubers on line, pelo menos serviriam para distrair o kell enquanto tu batina no breaker.
To muito puto com o STEAM, sempre coloco no modo offline quando venho pro trabalho para poder jogar na hora de folga. Já me aconteceu de eu esquecer de colocar offline e ai não ter jeito de jogar, mas dessa vez foi diferente a história eu estava em modo offline, jogando o Borderlands 2, ai sai normalmente do jogo e desligei o meu note, quando fui "aproveitar" o marasmo do turno da noite para passar o tempo eis a a surpesa, a porcaria deu um erro e agora só conectando a internet para me liberar meus jogos novamente, to muito puto com essa porcaria. O cara vai lá, compra a porcaria do jogo original, paga um rim e um figado pelos jogos, e na hora de jogar fica bugando essa merd* e vai me deixar 4 dias sem ter o que fazer nesse navio do jack sparrow sem ter o que fazer, nem meu HD de filmes está aqui. Tem horas que tem de ter uma cópia "alternativa" dos jogos originais que compramos só para poder jogar quando a STEAM da erro. Isso me dá uma raiva
Nem tenho gold pra terminar nem minha gear pvm, ou sei lá o nome imagina pra montar uma pro pvp :seferrou:Informação muito relevante ao PvP:
Falando do PvP, depois que se ganha a "luta", vai ter alguma tipo de premio, será criado alguma tipo de ranking,ou é só pra divertimento mesmo?
Alguem poderia me falar o valor destes itens!!
Obrigado!!
http://s13.postimage.org/9oak29tvb/itens.png
Só pra se 'divertir'. Não tem prêmio, ranking nem nada do tipo. :fuuu:
Quanto vc ta de dps sem o franco atirador??Ai galera, o que que eu posso melhorar aqui no meu set?
http://us.battle.net/d3/pt/profile/Rafa-1274/hero/4287629
Imaginei que era por isso que tava usando ele.128k só, eu tenho 9% de AC no set rsrsrsrs
Acho que um dos anéis mais defensivos pro PVP será o Litany com roll pra CC.
Ainda está barato na AH, com 5kk já compra um.
mesmo tendo o ias alto nao compensa vc lutar naquela bolha.. pois ela reduz o teu dano, o dano que ele recebe dentro e se eu nao me engano ainda diminui tua def/resist!Nunca tinha tentado solar uber, não gosto de ficar catando chave sozinho, mas fui tentar agora de noite("agora de noite" fazem algumas horas já) no mp10 aqui é 8 ou 80
