Bom dia Galera, surgiu a oportunidade de comprar um kit de memória 8GB (2x4GB), fiquei em dúvida entre dois modelos, gostaria de pedir a opinião de vocês.
G.SKILL Ripjaws X F3-12800CL9D-8GBXL 8GB 2X4GB DDR3-1600 CL9-9-9-24 Memory
Especificações:
Designed For 2[SUP]nd[/SUP] Generation Intel[SUP]®[/SUP] Core™ Processors
ou
Corsair CMZ8GX3M2A1600C9 Vengeance 8GB 2X4GB DDR3-1600 CL9-9-9-24 Dual Channel Memory Kit
Especificações:
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1600MHz 9-9-9-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
Key Features
8GB (2x4GB) DDR3 for AMD, Intel Dual processors and upcoming 2nd Generation Intel Core platforms
1600MHz
9-9-9-24 latency
Vengeance heat spreader for styling and performance
Intel XMP (Extreme Memory Profile) Support
Limited Lifetime Warranty
Format: DIMM
Pin Out: 240 Pin
Voltage: 1.5V
Desde já, Grato.
Especificações:
System | Desktop |
System Type | DDR3 |
M/B Chipset | Intel P67 Intel Z68 |
CAS Latency | 9-9-9-24-2N |
Capacity | 8GB (4GB x2) |
Speed | DDR3-1600 (PC3 12800) |
Test Voltage | 1.5 Volts |
PCB | |
Registered/Unbuffered | Unbuffered |
Error Checking | Non-ECC |
Type | 240-pin DIMM |
Warranty | Lifetime |
ou
Especificações:
Key Features
1600MHz
9-9-9-24 latency
Format: DIMM
Pin Out: 240 Pin
Voltage: 1.5V
Desde já, Grato.
