Foi tanto patch essa semana que não deu pra acompanhar direito. Diversas vezes o multi caia pq tinha rolado patch de noite, huahuahuah
Vai o ultimo:
Patch v.1.1.217 ( October 20th 2023)
Greetings Lampbearers,
Introducing our latest set of patch notes! In this update, we are introducing a multitude of optimizations and stability improvements.
Our team has been working hard to squash the most recent bugs, fine-tune some animations, and improve various aspects of the game to ensure you have a smoother journey through the world of Lords of the Fallen.
Keep reporting to Sentry, this really helps us focus on the most important issues.
Stability
We fixed a crash that could occur when enemy AIs used their abilities in specific conditions.
Fixed a potential GPU crash caused by the initial cinematic resizing the viewport. Now it fades to black until we resolve the ratio-changing engine hiccups on some GPUs.
Optimization
We've started a rework on how the animations of complex enemies are calculated to gain additional performance without compromising quality.
Skyrest has undergone further optimization of its walls to improve performance.
Ruiner's totems have been optimized.
Parasites have received an additional optimization pass.
Improvements have been made to shadow cost and overdraw in the Skyrest bridge area.
A slight animation budget optimization has been implemented to ensure that hidden enemies do not blink. Why would they blink? Instead, they will keep their eyes wide open, waiting for the player to appear, allowing for a more effective ambush.
AI
Crossbowmen have undergone additional adjustments to their behavior in order to make them smarter without increasing their difficulty. This should result in a more engaging and balanced gameplay experience when encountering these enemies in the game.
A navmesh in the cistern has been adjusted to assist an invisible archer in targeting the player more efficiently.
The aggro ranges of the Deep Sparrow, Infernal Enchantress, and Mendacious Visage have been revised to prevent them from pursuing players after losing sight.
The Abbess and the Conflagrant Seer will now refrain from using their abilities against the player if the player is not in plain sight.
The worms spawned by the Mendacious Visage can now be dodged more easily.
There was one instance of a Pilgrim at Pilgrim's Perch who could see the player from a very far distance. Now, he will only notice the player when they get closer.
A fix has been implemented for archers to keep the arrow in place while applying vertical offset. This is a visual fix for archers that, when aiming at you from slopes, the arrow was being incorrectly displaced. The most visible impact was on the Holy Archer, particularly in the women's area section.
An update has been made to the "LookAt" behavior for NPCs to prevent neck snapping when the player gets close to them. This improvement aims to create a smoother and more natural interaction between the player and NPCs.
Balancing
The amount of poise damage inflicted by enhanced throwable items has been reduced.
Dev sword won't be ruining your PVP anymore.
Customization
Removed root bone influence from the Stalker's Hunter body and legs to improve the visuals.
The Holy Archer character model has been adjusted. These changes include removing the belt from the torso, shortening the cloth on the head, and modifying CLPs to accommodate these alterations
Swelling on the skirt part of the Marksman Armour has been removed to improve visuals and physics.
Level Design
Fixed an issue where players could interact with a Soulflay Chain from the ground in Skyrest Bridge, bypassing one step of the puzzle.
An invasion area at Pilgrim's Perch could be easily abandoned with a simple jump. To address this exploit, we've added an additional "moth-wall".
Fixed an issue where players could interact with the Soulflay Chain from the ground in the Swamp area. This fix prevents players from bypassing one step of the puzzle.
Lock-on targeting has been re-enabled for ambush enemies in the following areas: Forsaken Fen, Fitzroy's Gorge, Cursed Fief, Redcopse, Sunless Skein, and Manse of the Hallowed Sentinels.
Collisions
Two locations in the Forsaken Fen have been tweaked to prevent creatures from getting stuck under certain combat conditions.
Players can clip through the floor at a specific spot in the refractory of the Manse.
The camera could clip with the statue in the Leprosarium.
Improved the navigation of "drones" in a secret "room" within Bramis Castle.
Added an additional collision box for AIs to prevent them from falling through a hole at the Tower of Penance. Players can still push them through.
Fixed a collision issue in Lower Calrath that could prevent players from stepping on it without using a jump.
Collision fixes and optimization in the area around Lower Calrath's orphanage have been implemented.
Corrected hidden landscape collision on Manse Supply Road to prevent thrown objects from getting stuck.
Players were not dying properly due to the Void volume being too low on Pilgrim's Perch.
A collision issue between a rock and a wooden structure has been fixed to prevent players from getting stuck under certain conditions.
A wrong collision setup that made it difficult to pick up an item in Lower Calrath's Smelter area has been fixed.
A collision bug that occurred on a specific bed at Bramis Castle has been fixed.
Players could get stuck on a collision in the Sunless Skein.
Fixed a hole at Fritzroy's Gorge that could cause players to fall through it.
Fixed a collision on an asset that could cause players to get stuck when rolling in a certain way.
A misplaced collision could cause players to fall through the ground in the tutorial area.
Visuals
The LOD (Level of Detail) settings of the Strider have been updated to address an issue where the jewelry would behave unexpectedly when transitioning from LOD1 to LOD0. This update should result in a smoother and more visually consistent experience with the Strider character in the game.
Fixed a torn skirt by resetting the bones to their reference pose. This was discovered while cleaning her abp for optimization.
Fixed some ground artifacts in the Forsaken Fen.
Gameplay
Fixed controller vibration and camera shake from some level elements that ignored if the player turned that option off in the menu.
In Light we Walk.
Comprei e devolvi ele hj não sei se foi o "último patch" mas travou 3x nos 30 min que joguei, crashou no primeiro Boss, antes do segundo e durante a luta do segundo. Eu não uso drivers atualizados pode ser isso o problema.
Mega sena é coisa de terceiro mundo/pobre.se eu ganhar na mega hj, eu compro esse game
Tem q jogar na loteria dos Estados Unidos, o prêmio estava acumulado em R$9 BILHÕES de reais!!
Ticket in California Wins $1.765 Billion Powerball Jackpot
A single ticket sold in California matched all six numbers drawn Wednesday night to win a Powerball jackpot worth $1.765 billion.www.powerball.com
Aqui desde o lançamento eu simplesmente setei o game em 60 fps com g-sync e roda tudo no ultra exceto reflexo médio a 1440p. Rodando bem fluido e sem queda alguma. Esse game com fps alto gera drop e fica realmente zoado.Esperei alguns patchs para jogar novamente do zero e com essa última atualização estou tendo muitas quedas de fps, tá pior que a build original do jogo, mais alguém?
E parece que piorou a performance, tá rodando 99% da placa com 100 fps em média isso com dlss equilibrado, que eu me lembre eu tinha mais fps no lançamento do jogo. Como um souls like essas quedas atrapalham bastante a jogatina.
Alguém já testou? Vou baixar pra ver.Alguém chegou a testar aquele mod que tem no site da Nexus? Diz resolver bastante problema de performance..
LOTF - Fixes and Improvements
This mod addresses various aspects of the game, ranging from reduced stuttering, reduced latency and overall stability.www.nexusmods.com
Então retome a sua sanidade e vá jogar Elden ring.Terminei o game. Foi meu segundo souls (Lies of P o primeiro). Não tenho experiencia com os souls da from, então não tenho muito parâmetro, mas gostei no geral do game. Lies of P no geral foi mais divertido, tem uma puta historia e melhor combate, mas a arte de Lords of the Fallen é realmente muito boa. Level design acima da média. Você percebe que realmente o orçamento foi bem alto, mas ainda não vale o preço cheio (e peguei a deluxe, haha).
Terminei o game com 62 horas e no level 102.
Nota 8.
Agora é descansar um pouco de Souls e ver se animo com Elden Ring, apesar que os gráficos no mundo aberto do jogo me desanimou um pouco, ainda mais depois de jogar estes novos.
Nossa testei o mod aqui e ficou bem pior tanto performance como transições não recomendo.Alguém já testou? Vou baixar pra ver.
Só para deixar registrado que nesse período off de jogos souls, terminei o primeiro Lords of the Fallen (2014)Terminei o game. Foi meu segundo souls (Lies of P o primeiro). Não tenho experiencia com os souls da from, então não tenho muito parâmetro, mas gostei no geral do game. Lies of P no geral foi mais divertido, tem uma puta historia e melhor combate, mas a arte de Lords of the Fallen é realmente muito boa. Level design acima da média. Você percebe que realmente o orçamento foi bem alto, mas ainda não vale o preço cheio (e peguei a deluxe, haha).
Nota 8.
Eu ia postar se ninguem está jogando o game pois acabei de comprar na Epic (estou com umas 15 horas) e todas as vezes que tentei jogar coop não achou ninguem, só fui invadido uma unica vez (nesse aspecto até prefiro, pois odeio esse lance de invasão).Ta foda o online,raramente acho alguem,e quando acho ,demora um ano pra conectar,loading eterno quase.
