GEFORCE RTX 3090 | GEFORCE RTX 3080 | GEFORCE RTX 3070 | ||
GPU Engine Specs: | NVIDIA CUDA® Cores | 10496 | 8704 | 5888 |
Boost Clock (GHz) | 1.70 | 1.71 | 1.73 | |
Memory Specs: | Standard Memory Config | 24 GB GDDR6X | 10 GB GDDR6X | 8 GB GDDR6 |
Memory Interface Width | 384-bit | 320-bit | 256-bit | |
Technology Support: | Ray Tracing Cores | 2nd Generation | 2nd Generation | 2nd Generation |
Tensor Cores | 3rd Generation | 3rd Generation | 3rd Generation | |
NVIDIA Architecture | Ampere | Ampere | Ampere | |
Microsoft DirectX® 12 Ultimate | Yes | Yes | Yes | |
NVIDIA DLSS | Yes | Yes | Yes | |
PCI Express Gen 4 | Yes | Yes | Yes | |
NVIDIA® GeForce Experience™ | Yes | Yes | Yes | |
NVIDIA Ansel | Yes | Yes | Yes | |
NVIDIA FreeStyle | Yes | Yes | Yes | |
NVIDIA ShadowPlay | Yes | Yes | Yes | |
NVIDIA Highlights | Yes | Yes | Yes | |
NVIDIA G-SYNC® | Yes | Yes | Yes | |
Game Ready Drivers | Yes | Yes | Yes | |
NVIDIA Studio Drivers | Yes | Yes | Yes | |
NVIDIA GPU Boost™ | Yes | Yes | Yes | |
NVIDIA NVLink™ (SLI-Ready) | Yes | - | - | |
Vulkan RT API, OpenGL 4.6 | Yes | Yes | Yes | |
HDMI 2.1 | Yes | Yes | Yes | |
DisplayPort 1.4a | Yes | Yes | Yes | |
NVIDIA Encoder | 7th Generation | 7th Generation | 7th Generation | |
NVIDIA Decoder | 5th Generation | 5th Generation | 5th Generation | |
VR Ready | Yes | Yes | Yes | |
Display Support: | Maximum Digital Resolution (1) | 7680x4320 | 7680x4320 | 7680x4320 |
Standard Display Connectors | HDMI 2.1, 3x DisplayPort 1.4a | HDMI 2.1, 3x DisplayPort 1.4a | HDMI 2.1, 3x DisplayPort 1.4a | |
Multi Monitor | 4 | 4 | 4 | |
HDCP | 2.3 | 2.3 | 2.3 | |
Founders Edition Card Dimensions: | Length | 12.3" (313 mm) | 11.2" (285 mm) | 9.5" (242 mm) |
Width | 5.4" (138 mm) | 4.4" (112 mm) | 4.4" (112 mm) | |
Height | 3-Slot | 2-Slot | 2-Slot | |
Founders Edition Thermal Power Specs: | Maximum GPU Temperature (in C) | 93 | 93 | 93 |
Graphics Card Power (W) | 350 | 320 | 220 | |
Recommended System Power (W) (2) | 750 | 750 | 650 | |
Supplementary Power Connectors | 2x PCIe 8-pin | 2x PCIe 8-pin | 1x PCIe 8-pin |
1 - Up to 4k 12-bit HDR at 240Hz with DP1.4a+DSC. Up to 8k 12-bit HDR at 60Hz with DP 1.4a+DSC or HDMI2.1+DSC. With dual DP1.4a+DSC, up to 8K HDR at 120Hz
2 - Recommendation is made based on PC configured with an Intel Core i9-10900K processor. A lower power rating may work depending on system configuration.
Note: The above specifications represent this GPU as incorporated into NVIDIA's reference graphics card design. Clock specifications apply while gaming with medium to full GPU utilization. Graphics card specifications may vary by add-in-card manufacturer. Please refer to the add-in-card manufacturers' website for actual shipping specifications.
NVIDIA GeForce RTX 30 Series GPUs Powered by Ampere Architecture
Experience The Ultimate Performance For Gamers & Creators With Unrealistic Advanced Features.
www.nvidia.com
