Configuração
Q6600 G0 VID 1.2875 Cooler Hyper TX2 com FAN foi trocado por um Zalman ZM-F2 Plus 2900 RPM + Artic Silver 5 http://www.zalman.co.kr/eng/product/Product_Read.asp?idx=330
Asus P5K Deluxe Wifi-AP
4x1GB Corsair Value 667 com dissipador de calor de cobre Akasa
IceAge 500W
HIS Radeon 4850 Cooler Zalman VF900CU 2800 RPM + Artic Silver 5
Na Bios eu deixei assim:
Advanced
JumperFree Configuration
AI overclocking (Manual)
CPU Ratio Setting (Manual)
Ratio CMOS setting (9.0)
FSB strap to north bridge (Auto)
FSB Frequency (400)
PCIE Frequency (100)
DRAM Frequency (DDR2- 818MHz)
Dram command rate (2N)
DRAM Timing Control (Autol)
DRAM Static Read Control (Disable)
Transaction Booster (Auto)
CPU voltage (1.4625V)
CPU PLL voltage (1.5V)
FSB termination Voltage (1.2V)
DRAM Voltage (1.8V)
North bridge voltage (1.25)
South bridge voltage (1.05)
Clock Over Chargind Mode (Auto)
Load line calibration (enable)
CPU GTL voltage reference (auto)
NB GTL voltage reference (auto)
CPU spread spectrum (disable)
PCIE spread spectrum (disable)
CPU Configuration
CPU ratio control (9.0)
C1E support (disable)
Max CPUID Value Limit (disable)
Vanderpool technology (disable)
CPU TM Function (disable)
Execute disable Bit (disable)
Intel SpeedStep Tech (Disable)
Eu torturei o sistema com o everest e não reinicio e as temperatura do processador chego no maximo a 62º , mas dai sempre que mandava o antivirus scanear depois de uns 10min o pc reiniciava, não sabia pq, até que baixei o memtest e o programa não chega a 5% o pc reinicia ....... o que posso fazer para estabilizar ?
IceAge 500W
![img2243b.jpg](http://img138.imageshack.us/img138/2931/img2243b.jpg)
Advanced
FSB Frequency (400)
DRAM Voltage (1.8V)
CPU Configuration
