Redmi Note 10
Dimensões
160.5 x 74.5 x 8.3 mm
Peso
178.8 g
Tela
6.43", AMOLED, 1080 x 2400p, 450 nits (typ), 1100 nits (pico)
Proteção Corning Gorilla Glass 3
Plataforma
Android 11, MIUI 12
Chipset Qualcomm SDM678 Snapdragon 678
CPU Octa-core (2x2.2 GHz Kryo 460 Gold & 6x1.7 GHz Kryo 460 Silver)
GPU Adreno 612
Memória
Slot par SD
Interna 64GB 4GB RAM, 128GB 4GB RAM, 128GB 6GB RAM
Câmera
48 MP, f/1.8, 26mm (wide), 1/2.0", 0.8µm, PDAF
8 MP, f/2.2, 118˚ (ultrawide), 1/4.0", 1.12µm
2 MP, f/2.4, (macro)
2 MP, f/2.4, (profundidade)
Vídeo 4K@30fps, 1080p@30/60fps
Frontal
13 MP, f/2.5, (wide), 1/3.06", 1.12µm
Vídeo 1080p@30fps
Som
Estéreo
Entrada 3.5mm
Bateria
5000 mAh
Carregamento Rápido 33W
Cores
Shadow Black (Onyx Gray), Frost White (Pebble White), Aqua Green (Lake Green)
Especificação Completa
Xiaomi Redmi Note 10 - Full phone specifications (gsmarena.com)
Redmi Note 10S
Dimensões
Peso
178.8 g
Tela
6.43", Super AMOLED, 1080 x 2400p, 450 nits (typ), 1100 nits (pico)
Plataforma
Android 11, MIUI 12
Chipset Mediatek Helio G95 (12 nm)
CPU Octa-core (2x2.05 GHz Cortex-A76 & 6x2.0 GHz Cortex-A55)
GPU Mali-G76 MC4
Memória
Slot par SD
Interna 64GB 6GB RAM, 128GB 6GB RAM, 128GB 8GB RAM
Câmera
64 MP, f/1.8, 26mm (wide), 1/1.97", 0.7µm, PDAF
2 MP, f/2.4, (produndidade)
Vídeo 4K@30fps, 1080p@30/60/120fps, 720p@960fps
Frontal
Vídeo 1080p@30fps
Som
Estéreo
Entrada 3.5mm
Bateria
5000 mAh
Cores
Ocean Blue, Onyx Gray, Pebble White
Xiaomi Redmi Note 10S - Full phone specifications (gsmarena.com)
Redmi Note 10 Pro
Dimensões
164 x 76.5 x 8.1 mm
Peso
193 g
Tela
6.67", AMOLED, 1080 x 2400p, 120Hz, 450 nits (typ), 1200 nits (pico)
Proteção Corning Gorilla Glass 5
Plataforma
Android 11, MIUI 12
Chipset Qualcomm SM7150 Snapdragon 732G (8 nm)
CPU Octa-core (2x2.3 GHz Kryo 470 Gold & 6x1.8 GHz Kryo 470 Silver)
GPU Adreno 618
Memória
Slot par SD
Câmera
108 MP, f/1.9, 26mm (wide), 1/1.52", 0.7µm, dual pixel PDAF
5 MP, f/2.4, (macro), AF
Frontal
16 MP, f/2.5, (wide), 1/3.06", 1.0µm
Vídeo 1080p@30fps, 720p@120fps
Som
Estéreo
Entrada 3.5mm
Bateria
5020 mAh
Cores
Onyx Gray, Glacier Blue, Gradient Bronze
Xiaomi Redmi Note 10 Pro - Full phone specifications (gsmarena.com)
Dimensões
Peso
178.8 g
Tela
Plataforma
Android 11, MIUI 12
GPU Adreno 612
Memória
Slot par SD
Câmera
Frontal
Vídeo 1080p@30fps
Som
Estéreo
Entrada 3.5mm
Bateria
5000 mAh
Cores
Redmi Note 10S
Dimensões
Peso
178.8 g
Tela
Plataforma
Android 11, MIUI 12
GPU Mali-G76 MC4
Memória
Slot par SD
Câmera
Frontal
Vídeo 1080p@30fps
Som
Estéreo
Entrada 3.5mm
Bateria
5000 mAh
Cores
Redmi Note 10 Pro
Dimensões
164 x 76.5 x 8.1 mm
Peso
193 g
Tela
Plataforma
Android 11, MIUI 12
GPU Adreno 618
Memória
Slot par SD
Câmera
Frontal
Som
Estéreo
Entrada 3.5mm
Bateria
5020 mAh
Cores
