Demorei mas chegueiMerlimBR, abra o Malwarebytes e clique em Quarentena. Selecione o item e clique no botão Remover Tudo. Siga as instruções abaixo:
Execute o HijackThis e clique em Do a system scan only. Marque a entrada abaixo e clique em Fix Checked
Ainda com o HijackThis aberto, clique no botão Config (ao lado direito), clique em Misc Tools. Marque as opções "List also minor sections" e "List empty sections". Logo após clique no botão Generate StartupList Log.
Será aberto um log no Bloco de Notas para você. O mesmo também estará na pasta do HijackThis com o nome startuplist.txt.
Cole este log aqui amigo MerlimBR.
No Quarentena não tem nada, então só fiz o outro, segue o log:
StartupList report, 22/04/2009, 00:11:52
StartupList version: 1.52.2
Started from : C:\Program Files (x86)\Trend Micro\HijackThis\HijackThis.EXE
Detected: Windows Vista SP1 (WinNT 6.00.1905)
Detected: Internet Explorer v7.00 (7.00.6001.18000)
* Using default options
* Including empty and uninteresting sections
* Showing rarely important sections
Running processes:
C:\Fraps\fraps.exe
C:\Program Files (x86)\ASUS\EPU-6 Engine\SixEngine.exe
C:\Program Files (x86)\ASUS\AASP\1.00.76\aaCenter.exe
C:\Program Files (x86)\Analog Devices\SoundMAX\SoundMAX.exe
C:\Program Files (x86)\Analog Devices\Core\smax4pnp.exe
C:\Program Files (x86)\ASUS\AI Suite\AiNap\AiNap.exe
C:\Program Files (x86)\Mozilla Firefox\firefox.exe
C:\Program Files (x86)\Trend Micro\HijackThis\HijackThis.exe
Listing of startup folders:
Shell folders Startup:
[C:\Users\mLm\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup]
*No files*
Shell folders AltStartup:
*Folder not found*
User shell folders Startup:
*Folder not found*
User shell folders AltStartup:
*Folder not found*
Shell folders Common Startup:
[C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup]
*No files*
Shell folders Common AltStartup:
*Folder not found*
User shell folders Common Startup:
*Folder not found*
User shell folders Alternate Common Startup:
*Folder not found*
Checking Windows NT UserInit:
[HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon]
UserInit = C:\Windows\system32\userinit.exe,
[HKLM\Software\Microsoft\Windows\CurrentVersion\Winlogon]
*Registry key not found*
[HKCU\Software\Microsoft\Windows NT\CurrentVersion\Winlogon]
*Registry value not found*
[HKCU\Software\Microsoft\Windows\CurrentVersion\Winlogon]
Autorun entries from Registry:
HKLM\Software\Microsoft\Windows\CurrentVersion\Run
SoundMAXPnP = C:\Program Files (x86)\Analog Devices\Core\smax4pnp.exe
(Default) =
Ai Nap = "C:\Program Files (x86)\ASUS\AI Suite\AiNap\AiNap.exe"
QFan Help = "C:\Program Files (x86)\ASUS\AI Suite\QFan3\QFanHelp.exe"
Cpu Level Up help = "C:\Program Files (x86)\ASUS\AI Suite\CpuLevelUpHelp.exe"
StartCCC = "C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static\CLIStart.exe" MSRun
HKLM\Software\Microsoft\Windows\CurrentVersion\RunOnce
*No values found*
HKLM\Software\Microsoft\Windows\CurrentVersion\RunOnceEx
HKLM\Software\Microsoft\Windows\CurrentVersion\RunServices
HKLM\Software\Microsoft\Windows\CurrentVersion\RunServicesOnce
HKCU\Software\Microsoft\Windows\CurrentVersion\Run
fsm =
DAEMON Tools Lite = "C:\Program Files (x86)\DAEMON Tools Lite\daemon.exe" -autorun
WMPNSCFG = C:\Program Files (x86)\Windows Media Player\WMPNSCFG.exe
HKCU\Software\Microsoft\Windows\CurrentVersion\RunOnce
*No values found*
HKCU\Software\Microsoft\Windows\CurrentVersion\RunOnceEx
HKCU\Software\Microsoft\Windows\CurrentVersion\RunServices
HKCU\Software\Microsoft\Windows\CurrentVersion\RunServicesOnce
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Run
HKCU\Software\Microsoft\Windows NT\CurrentVersion\Run
Autorun entries in Registry subkeys of:
[OptionalComponents]
*No subkeys found*
[AdobeUpdater]
*No subkeys found*
File association entry for .EXE:
HKEY_CLASSES_ROOT\exefile\shell\open\command
(Default) = "%1" %*
File association entry for .COM:
HKEY_CLASSES_ROOT\comfile\shell\open\command
(Default) = "%1" %*
File association entry for .BAT:
HKEY_CLASSES_ROOT\batfile\shell\open\command
(Default) = "%1" %*
File association entry for .PIF:
HKEY_CLASSES_ROOT\piffile\shell\open\command
(Default) = "%1" %*
File association entry for .SCR:
HKEY_CLASSES_ROOT\scrfile\shell\open\command
(Default) = "%1" /S
File association entry for .HTA:
HKEY_CLASSES_ROOT\htafile\shell\open\command
(Default) = C:\Windows\SysWOW64\mshta.exe "%1" %*
File association entry for .TXT:
HKEY_CLASSES_ROOT\txtfile\shell\open\command
(Default) = %SystemRoot%\system32\NOTEPAD.EXE %1
Enumerating Active Setup stub paths:
HKLM\Software\Microsoft\Active Setup\Installed Components
(* = disabled by HKCU twin)
[>{22d6f312-b0f6-11d0-94ab-0080c74c7e95}]
StubPath = %SystemRoot%\system32\unregmp2.exe /ShowWMP
[>{26923b43-4d38-484f-9b9e-de460746276c}] *
StubPath = C:\Windows\SysWOW64\ie4uinit.exe -UserIconConfig
[>{60B49E34-C7CC-11D0-8953-00A0C90347FF}] *
StubPath = RunDLL32 IEDKCS32.DLL,BrandIE4 SIGNUP
[{2C7339CF-2B09-4501-B3F3-F3508C9228ED}] *
StubPath = %SystemRoot%\system32\regsvr32.exe /s /n /i:/UserInstall %SystemRoot%\system32\themeui.dll
[{44BBA840-CC51-11CF-AAFA-00AA00B6015C}] *
StubPath = "%ProgramFiles(x86)%\Windows Mail\WinMail.exe" OCInstallUserConfigOE
[{6BF52A52-394A-11d3-B153-00C04F79FAA6}] *
StubPath = %SystemRoot%\system32\unregmp2.exe /FirstLogon /Shortcuts /RegBrowsers /ResetMUI
[{89820200-ECBD-11cf-8B85-00AA005B4340}] *
StubPath = regsvr32.exe /s /n /i:U shell32.dll
[{89820200-ECBD-11cf-8B85-00AA005B4383}] *
StubPath = C:\Windows\SysWOW64\ie4uinit.exe -BaseSettings
[{89B4C1CD-B018-4511-B0A1-5476DBF70820}] *
StubPath = C:\Windows\SysWOW64\Rundll32.exe C:\Windows\SysWOW64\mscories.dll,Install
Enumerating ICQ Agent Autostart apps:
HKCU\Software\Mirabilis\ICQ\Agent\Apps
Load/Run keys from C:\Windows\WIN.INI:
load=*INI section not found*
run=*INI section not found*
Load/Run keys from Registry:
HKLM\..\Windows NT\CurrentVersion\WinLogon: load=*Registry value not found*
HKLM\..\Windows NT\CurrentVersion\WinLogon: run=*Registry value not found*
HKLM\..\Windows\CurrentVersion\WinLogon: load=*Registry key not found*
HKLM\..\Windows\CurrentVersion\WinLogon: run=*Registry key not found*
HKCU\..\Windows NT\CurrentVersion\WinLogon: load=*Registry value not found*
HKCU\..\Windows NT\CurrentVersion\WinLogon: run=*Registry value not found*
HKCU\..\Windows\CurrentVersion\WinLogon: load=*Registry key not found*
HKCU\..\Windows\CurrentVersion\WinLogon: run=*Registry key not found*
HKCU\..\Windows NT\CurrentVersion\Windows: load=*Registry value not found*
HKCU\..\Windows NT\CurrentVersion\Windows: run=*Registry value not found*
HKLM\..\Windows NT\CurrentVersion\Windows: load=*Registry value not found*
HKLM\..\Windows NT\CurrentVersion\Windows: run=*Registry value not found*
HKLM\..\Windows NT\CurrentVersion\Windows: AppInit_DLLs=
Shell & screensaver key from C:\Windows\SYSTEM.INI:
Shell=*INI section not found*
SCRNSAVE.EXE=*INI section not found*
drivers=*INI section not found*
Shell & screensaver key from Registry:
Shell=explorer.exe
SCRNSAVE.EXE=C:\Windows\system32\logon.scr
drivers=*Registry value not found*
Policies Shell key:
HKCU\..\Policies: Shell=*Registry key not found*
HKLM\..\Policies: Shell=*Registry value not found*
Checking for EXPLORER.EXE instances:
C:\Windows\Explorer.exe: PRESENT!
C:\Explorer.exe: not present
C:\Windows\Explorer\Explorer.exe: not present
C:\Windows\System\Explorer.exe: not present
C:\Windows\System32\Explorer.exe: not present
C:\Windows\Command\Explorer.exe: not present
C:\Windows\Fonts\Explorer.exe: not present
Checking for superhidden extensions:
.lnk: HIDDEN! (arrow overlay: yes)
.pif: HIDDEN! (arrow overlay: yes)
.exe: not hidden
.com: not hidden
.bat: not hidden
.hta: not hidden
.scr: not hidden
.shs: *Registry key not found*
.shb: *Registry key not found*
.vbs: not hidden
.vbe: not hidden
.wsh: not hidden
.scf: HIDDEN! (arrow overlay: NO!)
.url: HIDDEN! (arrow overlay: yes)
.js: not hidden
.jse: not hidden
Verifying REGEDIT.EXE integrity:
- Regedit.exe found in C:\Windows
- .reg open command is normal (regedit.exe %1)
- Company name OK: 'Microsoft Corporation'
- Original filename NOT OK: 'REGEDIT.EXE.MUI'
- File description: 'Editor do Registro'
Registry check failed!
Enumerating Browser Helper Objects:
AcroIEHelperStub - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll - {18DF081C-E8AD-4283-A596-FA578C2EBDC3}
(no name) - C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll - {9030D464-4C02-4ABF-8ECC-5164760863C6}
(no name) - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll - {AE7CD045-E861-484f-8273-0445EE161910}
(no name) - C:\Program Files (x86)\Free Download Manager\iefdm2.dll - {CC59E0F9-7E43-44FA-9FAA-8377850BF205}
(no name) - C:\PROGRA~2\FlashFXP\IEFlash.dll - {E5A1691B-D188-4419-AD02-90002030B8EE}
SmartSelect - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll - {F4971EE7-DAA0-4053-9964-665D8EE6A077}
Enumerating Task Scheduler jobs:
*No jobs found*
Enumerating Download Program Files:
[Windows Genuine Advantage Validation Tool]
InProcServer32 = C:\Windows\SysWow64\LegitCheckControl.DLL
CODEBASE = http://download.microsoft.com/downl...-48D9-9B0E-1719D1177202/LegitCheckControl.cab
[Shockwave Flash Object]
InProcServer32 = C:\Windows\SysWow64\Macromed\Flash\Flash10b.ocx
CODEBASE = http://fpdownload2.macromedia.com/get/shockwave/cabs/flash/swflash.cab
Enumerating Winsock LSP files:
NameSpace #1: C:\Windows\system32\NLAapi.dll
NameSpace #2: C:\Windows\system32\napinsp.dll
NameSpace #3: C:\Windows\system32\pnrpnsp.dll
NameSpace #4: C:\Windows\system32\pnrpnsp.dll
NameSpace #5: C:\Windows\System32\mswsock.dll
NameSpace #6: C:\Windows\System32\winrnr.dll
Protocol #1: C:\Windows\system32\mswsock.dll
Protocol #2: C:\Windows\system32\mswsock.dll
Protocol #3: C:\Windows\system32\mswsock.dll
Protocol #4: C:\Windows\system32\mswsock.dll
Protocol #5: C:\Windows\system32\mswsock.dll
Protocol #6: C:\Windows\system32\mswsock.dll
Protocol #7: C:\Windows\system32\mswsock.dll
Protocol #8: C:\Windows\system32\mswsock.dll
Protocol #9: C:\Windows\system32\mswsock.dll
Protocol #10: C:\Windows\system32\mswsock.dll
Enumerating Windows NT/2000/XP services
Microsoft ACPI Driver: system32\drivers\acpi.sys (system)
ADI UAA Function Driver for High Definition Audio Service: system32\drivers\ADIHdAud.sys (manual start)
Adobe Version Cue CS4: "C:\Program Files (x86)\Common Files\Adobe\Adobe Version Cue CS4\Server\bin\VersionCueCS4.exe" -win32service (manual start)
adp94xx: \SystemRoot\system32\drivers\adp94xx.sys (disabled)
adpahci: \SystemRoot\system32\drivers\adpahci.sys (disabled)
adpu160m: \SystemRoot\system32\drivers\adpu160m.sys (disabled)
adpu320: \SystemRoot\system32\drivers\adpu320.sys (disabled)
Andrea ADI Filters Service: %SystemRoot%\system32\AEADISRV.EXE (autostart)
@%SystemRoot%\system32\aelupsvc.dll,-1: %systemroot%\system32\svchost.exe -k netsvcs (autostart)
Ancilliary Function Driver for Winsock: \SystemRoot\system32\drivers\afd.sys (system)
Intel AGP Bus Filter: \SystemRoot\system32\drivers\agp440.sys (manual start)
aic78xx: \SystemRoot\system32\drivers\djsvs.sys (disabled)
@%SystemRoot%\system32\Alg.exe,-112: %SystemRoot%\System32\alg.exe (manual start)
aliide: \SystemRoot\system32\drivers\aliide.sys (disabled)
AMD External Events Utility: %SystemRoot%\system32\atiesrxx.exe (autostart)
amdide: \SystemRoot\system32\drivers\amdide.sys (disabled)
AMD K8 Processor Driver: \SystemRoot\system32\drivers\amdk8.sys (disabled)
@%systemroot%\system32\appinfo.dll,-100: %SystemRoot%\system32\svchost.exe -k netsvcs (manual start)
@appmgmts.dll,-3250: %SystemRoot%\system32\svchost.exe -k netsvcs (manual start)
arc: \SystemRoot\system32\drivers\arc.sys (disabled)
arcsas: \SystemRoot\system32\drivers\arcsas.sys (disabled)
AsIO: SysWow64\drivers\AsIO.sys (system)
ASUS System Control Service: C:\Program Files (x86)\ASUS\AsSysCtrlService\1.00.00\AsSysCtrlService.exe (autostart)
@%systemroot%\system32\rascfg.dll,-32000: system32\DRIVERS\asyncmac.sys (manual start)
IDE Channel: system32\drivers\atapi.sys (system)
ATI Function Driver for HDMI Service: system32\drivers\AtiHdmi.sys (manual start)
atikmdag: system32\DRIVERS\atikmdag.sys (manual start)
atksgt: system32\DRIVERS\atksgt.sys (autostart)
@%SystemRoot%\system32\audiosrv.dll,-204: %SystemRoot%\System32\svchost.exe -k LocalSystemNetworkRestricted (autostart)
@%SystemRoot%\system32\audiosrv.dll,-200: %SystemRoot%\System32\svchost.exe -k LocalServiceNetworkRestricted (autostart)
@%SystemRoot%\system32\bfe.dll,-1001: %systemroot%\system32\svchost.exe -k LocalServiceNoNetwork (autostart)
@%SystemRoot%\system32\qmgr.dll,-1000: %SystemRoot%\System32\svchost.exe -k netsvcs (autostart)
blbdrive: \SystemRoot\system32\drivers\blbdrive.sys (disabled)
Bowser: system32\DRIVERS\bowser.sys (manual start)
Brother USB Mass-Storage Lower Filter Driver: \SystemRoot\system32\drivers\brfiltlo.sys (manual start)
Brother USB Mass-Storage Upper Filter Driver: \SystemRoot\system32\drivers\brfiltup.sys (manual start)
@%systemroot%\system32\browser.dll,-100: %SystemRoot%\System32\svchost.exe -k netsvcs (autostart)
Brother MFC Serial Port Interface Driver (WDM): \SystemRoot\system32\drivers\brserid.sys (disabled)
Brother WDM Serial driver: \SystemRoot\system32\drivers\brserwdm.sys (disabled)
Brother MFC USB Fax Only Modem: \SystemRoot\system32\drivers\brusbmdm.sys (disabled)
Brother MFC USB Serial WDM Driver: \SystemRoot\system32\drivers\brusbser.sys (manual start)
Bluetooth Serial Communications Driver: \SystemRoot\system32\drivers\bthmodem.sys (disabled)
CD/DVD File System Reader: system32\DRIVERS\cdfs.sys (disabled)
CD-ROM Driver: system32\DRIVERS\cdrom.sys (system)
@%SystemRoot%\System32\certprop.dll,-11: %SystemRoot%\system32\svchost.exe -k netsvcs (manual start)
Consumer IR Devices: \SystemRoot\system32\drivers\circlass.sys (disabled)
Common Log (CLFS): System32\CLFS.sys (system)
Microsoft .NET Framework NGEN v2.0.50727_X86: %systemroot%\Microsoft.NET\Framework\v2.0.50727\mscorsvw.exe (manual start)
Microsoft .NET Framework NGEN v2.0.50727_X64: %systemroot%\Microsoft.NET\Framework64\v2.0.50727\mscorsvw.exe (manual start)
COMODO Internet Security Helper Service: "C:\Program Files\COMODO\COMODO Internet Security\cmdagent.exe" (autostart)
COMODO Internet Security Sandbox Driver: System32\DRIVERS\cmdguard.sys (system)
COMODO Internet Security Helper Driver: System32\DRIVERS\cmdhlp.sys (system)
cmdide: \SystemRoot\system32\drivers\cmdide.sys (disabled)
Microsoft Composite Battery Driver: \SystemRoot\system32\drivers\compbatt.sys (disabled)
@comres.dll,-947: %SystemRoot%\system32\dllhost.exe /Processid:{02D4B3F1-FD88-11D1-960D-00805FC79235} (manual start)
Crcdisk Filter Driver: system32\drivers\crcdisk.sys (system)
@%SystemRoot%\system32\cryptsvc.dll,-1001: %SystemRoot%\system32\svchost.exe -k NetworkService (autostart)
Offline Files Driver: system32\drivers\csc.sys (system)
@%systemroot%\system32\cscsvc.dll,-200: %SystemRoot%\System32\svchost.exe -k LocalSystemNetworkRestricted (autostart)
@oleres.dll,-5012: %SystemRoot%\system32\svchost.exe -k DcomLaunch (autostart)
@%systemroot%\system32\drivers\dfsc.sys,-101: System32\Drivers\dfsc.sys (system)
@dfsrres.dll,-101: %SystemRoot%\system32\DFSR.exe (manual start)
@%SystemRoot%\system32\dhcpcsvc.dll,-100: %SystemRoot%\system32\svchost.exe -k LocalServiceNetworkRestricted (autostart)
Disk Driver: system32\drivers\disk.sys (system)
@%SystemRoot%\System32\dnsapi.dll,-101: %SystemRoot%\system32\svchost.exe -k NetworkService (autostart)
@%systemroot%\system32\dot3svc.dll,-1102: %SystemRoot%\system32\svchost.exe -k LocalSystemNetworkRestricted (manual start)
@%systemroot%\system32\dps.dll,-500: %SystemRoot%\System32\svchost.exe -k LocalServiceNoNetwork (autostart)
Microsoft Kernel DRM Audio Descrambler: system32\drivers\drmkaud.sys (manual start)
LDDM Graphics Subsystem: \SystemRoot\System32\drivers\dxgkrnl.sys (manual start)
Intel(R) PRO/1000 NDIS 6 Adapter Driver: system32\DRIVERS\E1G6032E.sys (manual start)
EAMON: system32\DRIVERS\eamon.sys (autostart)
@%systemroot%\system32\eapsvc.dll,-1: %SystemRoot%\System32\svchost.exe -k netsvcs (manual start)
easdrv: system32\DRIVERS\easdrv.sys (system)
ReadyBoost Caching Driver: System32\drivers\ecache.sys (system)
@%SystemRoot%\ehome\ehrecvr.exe,-101: %systemroot%\ehome\ehRecvr.exe (manual start)
@%SystemRoot%\ehome\ehsched.exe,-101: %systemroot%\ehome\ehsched.exe (manual start)
@%SystemRoot%\ehome\ehstart.dll,-101: %windir%\system32\svchost.exe -k LocalServiceNoNetwork (autostart)
Eset HTTP Server: "C:\Program Files\ESET\ESET NOD32 Antivirus\EHttpSrv.exe" (manual start)
Eset Service: "C:\Program Files\ESET\ESET NOD32 Antivirus\x86\ekrn.exe" (autostart)
elxstor: \SystemRoot\system32\drivers\elxstor.sys (disabled)
@%SystemRoot%\system32\emdmgmt.dll,-1000: %systemroot%\system32\svchost.exe -k LocalSystemNetworkRestricted (autostart)
ENTECH64: \??\C:\Windows\system32\DRIVERS\ENTECH64.sys (manual start)
epfwtdir: system32\DRIVERS\epfwtdir.sys (system)
Microsoft Hardware Error Device Driver: \SystemRoot\system32\drivers\errdev.sys (disabled)
@%SystemRoot%\system32\wevtsvc.dll,-200: %SystemRoot%\System32\svchost.exe -k LocalServiceNetworkRestricted (autostart)
@comres.dll,-2450: %SystemRoot%\system32\svchost.exe -k LocalService (autostart)
@%systemroot%\system32\fxsresm.dll,-118: %systemroot%\system32\fxssvc.exe (manual start)
Floppy Disk Controller Driver: system32\DRIVERS\fdc.sys (disabled)
@%systemroot%\system32\fdPHost.dll,-100: %SystemRoot%\system32\svchost.exe -k LocalService (manual start)
@%systemroot%\system32\fdrespub.dll,-100: %SystemRoot%\system32\svchost.exe -k LocalService (autostart)
File Information FS MiniFilter: system32\drivers\fileinfo.sys (system)
FileTrace: system32\drivers\filetrace.sys (manual start)
FLEXnet Licensing Service: "C:\Program Files (x86)\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe" (manual start)
FLEXnet Licensing Service 64: "C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService64.exe" (manual start)
Floppy Disk Driver: system32\DRIVERS\flpydisk.sys (disabled)
FltMgr: system32\drivers\fltmgr.sys (system)
@%SystemRoot%\system32\PresentationHost.exe,-3309: %systemroot%\Microsoft.Net\Framework64\v3.0\WPF\PresentationFontCache.exe (manual start)
BitLocker Drive Encryption Filter Driver: System32\DRIVERS\fvevol.sys (system)
Microsoft Generic AGPv3.0 Filter for K8 Processor Platforms: \SystemRoot\system32\drivers\gagp30kx.sys (manual start)
@gpapi.dll,-112: %windir%\system32\svchost.exe -k GPSvcGroup (autostart)
Microsoft 1.1 UAA Function Driver for High Definition Audio Service: system32\drivers\HdAudio.sys (manual start)
Microsoft UAA Bus Driver for High Definition Audio: system32\DRIVERS\HDAudBus.sys (manual start)
Microsoft Bluetooth HID Miniport: \SystemRoot\system32\drivers\hidbth.sys (disabled)
Microsoft Infrared HID Driver: \SystemRoot\system32\drivers\hidir.sys (disabled)
@%SystemRoot%\System32\hidserv.dll,-101: %SystemRoot%\system32\svchost.exe -k LocalSystemNetworkRestricted (manual start)
Microsoft HID Class Driver: system32\DRIVERS\hidusb.sys (manual start)
@%SystemRoot%\system32\kmsvc.dll,-6: %SystemRoot%\System32\svchost.exe -k netsvcs (manual start)
HpCISSs: \SystemRoot\system32\drivers\hpcisss.sys (disabled)
HTTP: system32\drivers\HTTP.sys (manual start)
i2omp: \SystemRoot\system32\drivers\i2omp.sys (disabled)
i8042 Keyboard and PS/2 Mouse Port Driver: system32\DRIVERS\i8042prt.sys (system)
Intel RAID Controller Vista: \SystemRoot\system32\drivers\iastorv.sys (disabled)
@%systemroot%\Microsoft.NET\Framework64\v3.0\Windows Communication Foundation\ServiceModelInstallRC.dll,-8193: "%systemroot%\Microsoft.NET\Framework64\v3.0\Windows Communication Foundation\infocard.exe" (manual start)
iirsp: \SystemRoot\system32\drivers\iirsp.sys (disabled)
@%SystemRoot%\system32\ikeext.dll,-501: %systemroot%\system32\svchost.exe -k netsvcs (autostart)
COMODO Internet Security Firewall Driver: system32\DRIVERS\inspect.sys (system)
intelide: \SystemRoot\system32\drivers\intelide.sys (disabled)
Intel Processor Driver: system32\DRIVERS\intelppm.sys (manual start)
@%systemroot%\system32\IPBusEnum.dll,-102: %SystemRoot%\system32\svchost.exe -k LocalSystemNetworkRestricted (manual start)
@%systemroot%\system32\rascfg.dll,-32013: system32\DRIVERS\ipfltdrv.sys (manual start)
@%SystemRoot%\system32\iphlpsvc.dll,-200: %SystemRoot%\System32\svchost.exe -k NetSvcs (autostart)
IP in IP Tunnel Driver: system32\DRIVERS\ipinip.sys (manual start)
IPMIDRV: \SystemRoot\system32\drivers\ipmidrv.sys (disabled)
IP Network Address Translator: system32\DRIVERS\ipnat.sys (manual start)
IR Bus Enumerator: system32\drivers\irenum.sys (manual start)
PnP ISA/EISA Bus Driver: \SystemRoot\system32\drivers\isapnp.sys (disabled)
iScsiPort Driver: system32\DRIVERS\msiscsi.sys (manual start)
ITEATAPI_Service_Install: \SystemRoot\system32\drivers\iteatapi.sys (disabled)
ITERAID_Service_Install: \SystemRoot\system32\drivers\iteraid.sys (disabled)
Keyboard Class Driver: system32\DRIVERS\kbdclass.sys (system)
Keyboard HID Driver: \SystemRoot\system32\drivers\kbdhid.sys (disabled)
@keyiso.dll,-100: %SystemRoot%\system32\lsass.exe (manual start)
KSecDD: System32\Drivers\ksecdd.sys (system)
Kernel Streaming Thunks: \SystemRoot\system32\drivers\ksthunk.sys (manual start)
@comres.dll,-2946: %SystemRoot%\System32\svchost.exe -k NetworkService (autostart)
@%systemroot%\system32\srvsvc.dll,-100: %SystemRoot%\system32\svchost.exe -k netsvcs (autostart)
@%systemroot%\system32\wkssvc.dll,-100: %SystemRoot%\System32\svchost.exe -k LocalService (autostart)
lirsgt: system32\DRIVERS\lirsgt.sys (autostart)
Link-Layer Topology Discovery Mapper I/O Driver: system32\DRIVERS\lltdio.sys (autostart)
@%SystemRoot%\system32\lltdres.dll,-1: %SystemRoot%\System32\svchost.exe -k LocalService (manual start)
@%SystemRoot%\system32\lmhsvc.dll,-101: %SystemRoot%\system32\svchost.exe -k LocalServiceNetworkRestricted (autostart)
LSI_FC: \SystemRoot\system32\drivers\lsi_fc.sys (disabled)
LSI_SAS: \SystemRoot\system32\drivers\lsi_sas.sys (disabled)
LSI_SCSI: \SystemRoot\system32\drivers\lsi_scsi.sys (disabled)
UAC File Virtualization: \SystemRoot\system32\drivers\luafv.sys (autostart)
Logitech USB Monitor Filter: system32\DRIVERS\LVUSBS64.sys (manual start)
@%SystemRoot%\ehome\ehres.dll,-15501: %SystemRoot%\system32\svchost.exe -k LocalService (disabled)
megasas: \SystemRoot\system32\drivers\megasas.sys (disabled)
MegaSR: \SystemRoot\system32\drivers\megasr.sys (disabled)
@%systemroot%\system32\mmcss.dll,-100: %SystemRoot%\system32\svchost.exe -k netsvcs (autostart)
Modem: system32\drivers\modem.sys (manual start)
Microsoft Monitor Class Function Driver Service: system32\DRIVERS\monitor.sys (manual start)
Mouse Class Driver: system32\DRIVERS\mouclass.sys (system)
Mouse HID Driver: system32\DRIVERS\mouhid.sys (manual start)
Mount Point Manager: System32\drivers\mountmgr.sys (system)
Microsoft Multi-Path Bus Driver: \SystemRoot\system32\drivers\mpio.sys (disabled)
@%SystemRoot%\system32\FirewallAPI.dll,-23092: System32\drivers\mpsdrv.sys (manual start)
@%SystemRoot%\system32\FirewallAPI.dll,-23090: %SystemRoot%\system32\svchost.exe -k LocalServiceNoNetwork (autostart)
Mraid35x: \SystemRoot\system32\drivers\mraid35x.sys (disabled)
WebDav Client Redirector Driver: \SystemRoot\system32\drivers\mrxdav.sys (manual start)
SMB MiniRedirector Wrapper and Engine: system32\DRIVERS\mrxsmb.sys (manual start)
SMB 1.x MiniRedirector: system32\DRIVERS\mrxsmb10.sys (manual start)
SMB 2.0 MiniRedirector: system32\DRIVERS\mrxsmb20.sys (manual start)
msahci: \SystemRoot\system32\drivers\msahci.sys (disabled)
Microsoft Multi-Path Device Specific Module: \SystemRoot\system32\drivers\msdsm.sys (disabled)
@comres.dll,-2797: %SystemRoot%\System32\msdtc.exe (manual start)
ISA/EISA Class Driver: system32\drivers\msisadrv.sys (system)
@%SystemRoot%\system32\iscsidsc.dll,-5000: %systemroot%\system32\svchost.exe -k netsvcs (manual start)
@%SystemRoot%\system32\msimsg.dll,-27: %systemroot%\system32\msiexec /V (manual start)
Microsoft Streaming Service Proxy: system32\drivers\MSKSSRV.sys (manual start)
Microsoft Streaming Clock Proxy: system32\drivers\MSPCLOCK.sys (manual start)
Microsoft Streaming Quality Manager Proxy: system32\drivers\MSPQM.sys (manual start)
Microsoft System Management BIOS Driver: system32\DRIVERS\mssmbios.sys (manual start)
Microsoft Streaming Tee/Sink-to-Sink Converter: system32\drivers\MSTEE.sys (manual start)
ATK0110 ACPI UTILITY: system32\DRIVERS\ASACPI.sys (manual start)
Mup: System32\Drivers\mup.sys (system)
mv61xx: system32\DRIVERS\mv61xx.sys (system)
mv64xx: system32\DRIVERS\mv64xx.sys (system)
@%SystemRoot%\system32\qagentrt.dll,-6: %SystemRoot%\System32\svchost.exe -k NetworkService (manual start)
NativeWiFi Filter: system32\DRIVERS\nwifi.sys (manual start)
NDIS System Driver: system32\drivers\ndis.sys (system)
@%systemroot%\system32\rascfg.dll,-32001: system32\DRIVERS\ndistapi.sys (manual start)
NDIS Usermode I/O Protocol: system32\DRIVERS\ndisuio.sys (manual start)
@%systemroot%\system32\rascfg.dll,-32002: system32\DRIVERS\ndiswan.sys (manual start)
NetBIOS Interface: system32\DRIVERS\netbios.sys (system)
NETBT: System32\DRIVERS\netbt.sys (system)
@%SystemRoot%\System32\netlogon.dll,-102: %systemroot%\system32\lsass.exe (manual start)
@%SystemRoot%\system32\netman.dll,-109: %SystemRoot%\System32\svchost.exe -k LocalSystemNetworkRestricted (manual start)
@%SystemRoot%\system32\netprof.dll,-246: %SystemRoot%\System32\svchost.exe -k LocalService (autostart)
@%systemroot%\Microsoft.NET\Framework64\v3.0\Windows Communication Foundation\ServiceModelInstallRC.dll,-8201: "%systemroot%\Microsoft.NET\Framework64\v3.0\Windows Communication Foundation\SMSvcHost.exe" (disabled)
nfrd960: \SystemRoot\system32\drivers\nfrd960.sys (disabled)
@%SystemRoot%\System32\nlasvc.dll,-1: %SystemRoot%\System32\svchost.exe -k NetworkService (autostart)
@%SystemRoot%\system32\nsisvc.dll,-200: %systemroot%\system32\svchost.exe -k LocalService (autostart)
NSI proxy service: system32\drivers\nsiproxy.sys (system)
NVIDIA nForce RAID Driver : \SystemRoot\system32\drivers\nvraid.sys (disabled)
nvstor: \SystemRoot\system32\drivers\nvstor.sys (disabled)
NVIDIA nForce AGP Bus Filter: \SystemRoot\system32\drivers\nv_agp.sys (manual start)
IPX Traffic Filter Driver: system32\DRIVERS\nwlnkflt.sys (manual start)
IPX Traffic Forwarder Driver: system32\DRIVERS\nwlnkfwd.sys (manual start)
Microsoft Office Diagnostics Service: "C:\Program Files (x86)\Common Files\Microsoft Shared\OFFICE12\ODSERV.EXE" (manual start)
VIA OHCI Compliant IEEE 1394 Host Controller: system32\DRIVERS\ohci1394.sys (manual start)
Office Source Engine: "C:\Program Files (x86)\Common Files\Microsoft Shared\Source Engine\OSE.EXE" (manual start)
@%SystemRoot%\system32\p2psvc.dll,-8004: %SystemRoot%\System32\svchost.exe -k LocalServiceNetworkRestricted (manual start)
@%SystemRoot%\system32\p2psvc.dll,-8006: %SystemRoot%\System32\svchost.exe -k LocalServiceNetworkRestricted (manual start)
Parallel port driver: \SystemRoot\system32\drivers\parport.sys (disabled)
Partition Manager: System32\drivers\partmgr.sys (system)
@%SystemRoot%\system32\pcasvc.dll,-1: %systemroot%\system32\svchost.exe -k LocalSystemNetworkRestricted (autostart)
PCI Bus Driver: system32\drivers\pci.sys (system)
pciide: system32\drivers\pciide.sys (system)
pcmcia: \SystemRoot\system32\drivers\pcmcia.sys (disabled)
PEAUTH: system32\drivers\peauth.sys (autostart)
@%systemroot%\sysWow64\perfhost.exe,-2: %SystemRoot%\SysWow64\perfhost.exe (manual start)
Logitech QuickCam IM(PID_PEPI): system32\DRIVERS\LV302V64.SYS (manual start)
@%systemroot%\system32\pla.dll,-500: %SystemRoot%\System32\svchost.exe -k LocalServiceNoNetwork (manual start)
@%SystemRoot%\system32\umpnpmgr.dll,-100: %SystemRoot%\system32\svchost.exe -k DcomLaunch (autostart)
PnkBstrA: C:\Windows\system32\PnkBstrA.exe (autostart)
@%SystemRoot%\system32\p2psvc.dll,-8002: %SystemRoot%\System32\svchost.exe -k LocalServiceNetworkRestricted (manual start)
@%SystemRoot%\system32\p2psvc.dll,-8000: %SystemRoot%\System32\svchost.exe -k LocalServiceNetworkRestricted (manual start)
@%SystemRoot%\System32\polstore.dll,-5010: %SystemRoot%\system32\svchost.exe -k NetworkServiceNetworkRestricted (autostart)
@%systemroot%\system32\rascfg.dll,-32006: system32\DRIVERS\raspptp.sys (manual start)
Processor Driver: \SystemRoot\system32\drivers\processr.sys (disabled)
@%systemroot%\system32\profsvc.dll,-300: %systemroot%\system32\svchost.exe -k netsvcs (autostart)
@%systemroot%\system32\psbase.dll,-300: %SystemRoot%\system32\lsass.exe (manual start)
@%SystemRoot%\System32\drivers\pacer.sys,-101: system32\DRIVERS\pacer.sys (system)
Protexis Licensing V2: "c:\Program Files (x86)\Common Files\Protexis\License Service\PsiService_2.exe" (autostart)
QLogic Fibre Channel Miniport Driver: \SystemRoot\system32\drivers\ql2300.sys (disabled)
QLogic iSCSI Miniport Driver: \SystemRoot\system32\drivers\ql40xx.sys (disabled)
@%SystemRoot%\system32\qwave.dll,-1: %windir%\system32\svchost.exe -k LocalService (manual start)
@%SystemRoot%\system32\drivers\qwavedrv.sys,-1: \SystemRoot\system32\drivers\qwavedrv.sys (manual start)
Remote Access Auto Connection Driver: System32\DRIVERS\rasacd.sys (system)
@%Systemroot%\system32\rasauto.dll,-200: %SystemRoot%\system32\svchost.exe -k netsvcs (manual start)
@%systemroot%\system32\rascfg.dll,-32005: system32\DRIVERS\rasl2tp.sys (manual start)
@%Systemroot%\system32\rasmans.dll,-200: %SystemRoot%\system32\svchost.exe -k netsvcs (manual start)
@%systemroot%\system32\rascfg.dll,-32007: system32\DRIVERS\raspppoe.sys (manual start)
@%systemroot%\system32\sstpsvc.dll,-202: system32\DRIVERS\rassstp.sys (manual start)
Redirected Buffering Sub Sysytem: system32\DRIVERS\rdbss.sys (system)
RDPCDD: System32\DRIVERS\RDPCDD.sys (system)
Terminal Server Device Redirector Driver: system32\DRIVERS\rdpdr.sys (manual start)
RDP Encoder Mirror Driver: system32\drivers\rdpencdd.sys (system)
@%Systemroot%\system32\mprdim.dll,-200: %SystemRoot%\system32\svchost.exe -k netsvcs (disabled)
@regsvc.dll,-1: %SystemRoot%\system32\svchost.exe -k regsvc (manual start)
RivaTuner64: \??\C:\Program Files (x86)\RivaTuner v2.24\RivaTuner64.sys (manual start)
@%systemroot%\system32\Locator.exe,-2: %SystemRoot%\system32\locator.exe (manual start)
@oleres.dll,-5010: %SystemRoot%\system32\svchost.exe -k rpcss (autostart)
Link-Layer Topology Discovery Responder: system32\DRIVERS\rspndr.sys (autostart)
@%SystemRoot%\system32\samsrv.dll,-1: %SystemRoot%\system32\lsass.exe (autostart)
SBP-2 Transport/Protocol Bus Driver: \SystemRoot\system32\drivers\sbp2port.sys (disabled)
@%SystemRoot%\System32\SCardSvr.dll,-1: %SystemRoot%\system32\svchost.exe -k LocalService (manual start)
@%SystemRoot%\system32\schedsvc.dll,-100: %systemroot%\system32\svchost.exe -k netsvcs (autostart)
@%SystemRoot%\System32\certprop.dll,-13: %SystemRoot%\system32\svchost.exe -k netsvcs (manual start)
@%SystemRoot%\system32\sdrsvc.dll,-107: %SystemRoot%\system32\svchost.exe -k SDRSVC (manual start)
@%SystemRoot%\system32\seclogon.dll,-7001: %windir%\system32\svchost.exe -k netsvcs (autostart)
@%SystemRoot%\system32\Sens.dll,-200: %SystemRoot%\system32\svchost.exe -k netsvcs (autostart)
Serenum Filter Driver: \SystemRoot\system32\drivers\serenum.sys (manual start)
Serial Port Driver: \SystemRoot\system32\drivers\serial.sys (disabled)
Serial Mouse Driver: \SystemRoot\system32\drivers\sermouse.sys (disabled)
@%SystemRoot%\System32\SessEnv.dll,-1026: %SystemRoot%\System32\svchost.exe -k netsvcs (manual start)
SFF Storage Class Driver: \SystemRoot\system32\drivers\sffdisk.sys (disabled)
SFF Storage Protocol Driver for MMC: \SystemRoot\system32\drivers\sffp_mmc.sys (manual start)
SFF Storage Protocol Driver for SDBus: \SystemRoot\system32\drivers\sffp_sd.sys (manual start)
High-Capacity Floppy Disk Drive: \SystemRoot\system32\drivers\sfloppy.sys (disabled)
@%SystemRoot%\system32\ipnathlp.dll,-106: %SystemRoot%\System32\svchost.exe -k netsvcs (disabled)
@%SystemRoot%\System32\shsvcs.dll,-12288: %SystemRoot%\System32\svchost.exe -k netsvcs (autostart)
SiSRaid2: \SystemRoot\system32\drivers\sisraid2.sys (disabled)
SiSRaid4: \SystemRoot\system32\drivers\sisraid4.sys (disabled)
@%SystemRoot%\system32\SLsvc.exe,-101: %SystemRoot%\system32\SLsvc.exe (autostart)
@%SystemRoot%\system32\SLUINotify.dll,-103: %SystemRoot%\system32\svchost.exe -k LocalService (manual start)
@%SystemRoot%\system32\tcpipcfg.dll,-50005: system32\DRIVERS\smb.sys (system)
@%SystemRoot%\system32\snmptrap.exe,-3: %SystemRoot%\System32\snmptrap.exe (manual start)
@%systemroot%\system32\spoolsv.exe,-1: %SystemRoot%\System32\spoolsv.exe (autostart)
sptd: System32\Drivers\sptd.sys (system)
srv: System32\DRIVERS\srv.sys (manual start)
srv2: System32\DRIVERS\srv2.sys (manual start)
srvnet: System32\DRIVERS\srvnet.sys (manual start)
@%systemroot%\system32\ssdpsrv.dll,-100: %SystemRoot%\system32\svchost.exe -k LocalService (manual start)
@%SystemRoot%\system32\sstpsvc.dll,-200: %SystemRoot%\system32\svchost.exe -k LocalService (manual start)
Steam Client Service: C:\Program Files (x86)\Common Files\Steam\SteamService.exe /RunAsService (manual start)
@%SystemRoot%\system32\wiaservc.dll,-9: %SystemRoot%\system32\svchost.exe -k imgsvc (autostart)
Software Bus Driver: system32\DRIVERS\swenum.sys (manual start)
@%SystemRoot%\System32\swprv.dll,-103: %SystemRoot%\System32\svchost.exe -k swprv (manual start)
Symc8xx: \SystemRoot\system32\drivers\symc8xx.sys (disabled)
Sym_hi: \SystemRoot\system32\drivers\sym_hi.sys (disabled)
Sym_u3: \SystemRoot\system32\drivers\sym_u3.sys (disabled)
@%SystemRoot%\system32\sysmain.dll,-1000: %systemroot%\system32\svchost.exe -k LocalSystemNetworkRestricted (autostart)
@%SystemRoot%\system32\TabSvc.dll,-100: %SystemRoot%\System32\svchost.exe -k LocalSystemNetworkRestricted (autostart)
@%SystemRoot%\system32\tapisrv.dll,-10100: %SystemRoot%\System32\svchost.exe -k NetworkService (manual start)
@%SystemRoot%\system32\tbssvc.dll,-100: %SystemRoot%\System32\svchost.exe -k LocalService (autostart)
@%SystemRoot%\system32\tcpipcfg.dll,-50003: System32\drivers\tcpip.sys (system)
Microsoft IPv6 Protocol Driver: system32\DRIVERS\tcpip.sys (manual start)
TCP/IP Registry Compatibility: System32\drivers\tcpipreg.sys (autostart)
TDPIPE: system32\drivers\tdpipe.sys (manual start)
TDTCP: system32\drivers\tdtcp.sys (manual start)
@%SystemRoot%\system32\tcpipcfg.dll,-50004: system32\DRIVERS\tdx.sys (system)
Terminal Device Driver: system32\DRIVERS\termdd.sys (system)
@%SystemRoot%\System32\termsrv.dll,-268: %SystemRoot%\System32\svchost.exe -k NetworkService (autostart)
@%SystemRoot%\System32\shsvcs.dll,-8192: %SystemRoot%\System32\svchost.exe -k netsvcs (autostart)
@%systemroot%\system32\mmcss.dll,-102: %SystemRoot%\system32\svchost.exe -k LocalService (manual start)
@%SystemRoot%\system32\trkwks.dll,-1: %SystemRoot%\System32\svchost.exe -k LocalSystemNetworkRestricted (autostart)
@%SystemRoot%\servicing\TrustedInstaller.exe,-100: %SystemRoot%\servicing\TrustedInstaller.exe (manual start)
Terminal Services Security Filter Driver: System32\DRIVERS\tssecsrv.sys (manual start)
Microsoft Tun Miniport Adapter Driver: system32\DRIVERS\tunmp.sys (manual start)
Microsoft IPv6 Tunnel Miniport Adapter Driver: system32\DRIVERS\tunnel.sys (manual start)
Microsoft AGPv3.5 Filter: \SystemRoot\system32\drivers\uagp35.sys (manual start)
udfs: system32\DRIVERS\udfs.sys (disabled)
@%SystemRoot%\system32\ui0detect.exe,-101: %SystemRoot%\system32\UI0Detect.exe (manual start)
Uli AGP Bus Filter: \SystemRoot\system32\drivers\uliagpkx.sys (manual start)
uliahci: \SystemRoot\system32\drivers\uliahci.sys (disabled)
UlSata: \SystemRoot\system32\drivers\ulsata.sys (disabled)
ulsata2: \SystemRoot\system32\drivers\ulsata2.sys (disabled)
UMBus Enumerator Driver: system32\DRIVERS\umbus.sys (manual start)
@%SystemRoot%\system32\umrdp.dll,-1000: %SystemRoot%\System32\svchost.exe -k LocalSystemNetworkRestricted (manual start)
@%systemroot%\system32\upnphost.dll,-213: %SystemRoot%\system32\svchost.exe -k LocalService (autostart)
USB Audio Driver (WDM): system32\drivers\usbaudio.sys (manual start)
Microsoft USB Generic Parent Driver: system32\DRIVERS\usbccgp.sys (manual start)
eHome Infrared Receiver (USBCIR): \SystemRoot\system32\drivers\usbcir.sys (disabled)
Microsoft USB 2.0 Enhanced Host Controller Miniport Driver: system32\DRIVERS\usbehci.sys (manual start)
Microsoft USB Standard Hub Driver: system32\DRIVERS\usbhub.sys (manual start)
Microsoft USB Open Host Controller Miniport Driver: \SystemRoot\system32\drivers\usbohci.sys (disabled)
Microsoft USB PRINTER Class: \SystemRoot\system32\drivers\usbprint.sys (disabled)
USB Mass Storage Driver: system32\DRIVERS\USBSTOR.SYS (manual start)
Microsoft USB Universal Host Controller Miniport Driver: system32\DRIVERS\usbuhci.sys (manual start)
@%SystemRoot%\system32\dwm.exe,-2000: %SystemRoot%\System32\svchost.exe -k LocalSystemNetworkRestricted (autostart)
@%SystemRoot%\system32\vds.exe,-100: %SystemRoot%\System32\vds.exe (manual start)
vga: system32\DRIVERS\vgapnp.sys (manual start)
VgaSave: \SystemRoot\System32\drivers\vga.sys (system)
viaide: \SystemRoot\system32\drivers\viaide.sys (disabled)
Volume Manager Driver: system32\drivers\volmgr.sys (system)
Dynamic Volume Manager: System32\drivers\volmgrx.sys (system)
Storage volumes: system32\drivers\volsnap.sys (system)
vsmraid: \SystemRoot\system32\drivers\vsmraid.sys (disabled)
@%systemroot%\system32\vssvc.exe,-102: %systemroot%\system32\vssvc.exe (manual start)
@%SystemRoot%\system32\w32time.dll,-200: %SystemRoot%\system32\svchost.exe -k LocalService (autostart)
Wacom Serial Pen HID Driver: \SystemRoot\system32\drivers\wacompen.sys (disabled)
Remote Access IP ARP Driver: system32\DRIVERS\wanarp.sys (manual start)
Remote Access IPv6 ARP Driver: system32\DRIVERS\wanarp.sys (system)
@%systemroot%\system32\wbengine.exe,-104: "%systemroot%\system32\wbengine.exe" (manual start)
@%SystemRoot%\system32\wcncsvc.dll,-3: %SystemRoot%\System32\svchost.exe -k LocalService (manual start)
@%SystemRoot%\system32\WcsPlugInService.dll,-200: %SystemRoot%\system32\svchost.exe -k wcssvc (manual start)
Microsoft Watchdog Timer Driver: \SystemRoot\system32\drivers\wd.sys (disabled)
Kernel Mode Driver Frameworks service: system32\drivers\Wdf01000.sys (system)
@%systemroot%\system32\wdi.dll,-502: %SystemRoot%\System32\svchost.exe -k wdisvc (manual start)
@%systemroot%\system32\wdi.dll,-500: %SystemRoot%\System32\svchost.exe -k LocalSystemNetworkRestricted (manual start)
@%systemroot%\system32\webclnt.dll,-100: %SystemRoot%\system32\svchost.exe -k LocalService (autostart)
@%SystemRoot%\system32\wecsvc.dll,-200: %SystemRoot%\system32\svchost.exe -k NetworkService (manual start)
@%SystemRoot%\System32\wercplsupport.dll,-101: %SystemRoot%\System32\svchost.exe -k netsvcs (manual start)
@%SystemRoot%\System32\wersvc.dll,-100: %SystemRoot%\System32\svchost.exe -k WerSvcGroup (autostart)
@%ProgramFiles%\Windows Defender\MsMpRes.dll,-103: %SystemRoot%\System32\svchost.exe -k secsvcs (autostart)
@%SystemRoot%\system32\winhttp.dll,-100: %SystemRoot%\system32\svchost.exe -k LocalService (manual start)
@%Systemroot%\system32\wbem\wmisvc.dll,-205: %systemroot%\system32\svchost.exe -k netsvcs (autostart)
@%Systemroot%\system32\wsmsvc.dll,-101: %SystemRoot%\System32\svchost.exe -k NetworkService (manual start)
@%SystemRoot%\System32\wlansvc.dll,-257: %SystemRoot%\system32\svchost.exe -k LocalSystemNetworkRestricted (manual start)
Microsoft Windows Management Interface for ACPI: system32\DRIVERS\wmiacpi.sys (manual start)
@%Systemroot%\system32\wbem\wmiapsrv.exe,-110: %systemroot%\system32\wbem\WmiApSrv.exe (manual start)
@%ProgramFiles%\Windows Media Player\wmpnetwk.exe,-101: "%ProgramFiles%\Windows Media Player\wmpnetwk.exe" (manual start)
@%SystemRoot%\system32\wpcsvc.dll,-100: %SystemRoot%\system32\svchost.exe -k LocalServiceNetworkRestricted (manual start)
@%SystemRoot%\system32\wpdbusenum.dll,-100: %SystemRoot%\system32\svchost.exe -k LocalSystemNetworkRestricted (autostart)
Winsock IFS driver: \SystemRoot\system32\drivers\ws2ifsl.sys (disabled)
@%SystemRoot%\System32\wscsvc.dll,-200: %SystemRoot%\System32\svchost.exe -k LocalServiceNetworkRestricted (autostart)
@%systemroot%\system32\SearchIndexer.exe,-103: %systemroot%\system32\SearchIndexer.exe /Embedding (autostart)
@%systemroot%\system32\wuaueng.dll,-105: %systemroot%\system32\svchost.exe -k netsvcs (autostart)
WUDFRd: system32\DRIVERS\WUDFRd.sys (manual start)
@%SystemRoot%\system32\wudfsvc.dll,-1000: %SystemRoot%\system32\svchost.exe -k LocalSystemNetworkRestricted (autostart)
Xbox 360 Wireless Receiver Driver Service 21: system32\DRIVERS\xusb21.sys (manual start)
NDIS6.0 Miniport Driver for Marvell Yukon Ethernet Controller: system32\DRIVERS\yk60x64.sys (manual start)
Enumerating Windows NT logon/logoff scripts:
*No scripts set to run*
Windows NT checkdisk command:
BootExecute = autocheck autochk *
Windows NT 'Wininit.ini':
PendingFileRenameOperations: *Registry value not found*
Enumerating ShellServiceObjectDelayLoad items:
WebCheck: C:\Windows\SysWOW64\webcheck.dll
HKCU\Software\Microsoft\Windows\CurrentVersion\policies\Explorer\Run
HKLM\Software\Microsoft\Windows\CurrentVersion\policies\Explorer\Run
End of report, 47.708 bytes
Report generated in 0,110 seconds
Command line options:
/verbose - to add additional info on each section
/complete - to include empty sections and unsuspicious data
/full - to include several rarely-important sections
/force9x - to include Win9x-only startups even if running on WinNT
/forcent - to include WinNT-only startups even if running on Win9x
/forceall - to include all Win9x and WinNT startups, regardless of platform
/history - to list version history only
Running processes:
C:\Fraps\fraps.exe
*No files*
*Folder not found*
*Folder not found*
*Folder not found*
*No files*
*Folder not found*
*Folder not found*
*Folder not found*
(Default) =
*No values found*
fsm =
*No values found*
*No subkeys found*
[AdobeUpdater]
*No subkeys found*
(Default) = "%1" %*
(Default) = "%1" %*
(Default) = "%1" %*
(Default) = "%1" %*
(Default) = "%1" /S
Shell=explorer.exe
Policies Shell key:
.exe: not hidden
.com: not hidden
.bat: not hidden
.hta: not hidden
.scr: not hidden
.vbs: not hidden
.vbe: not hidden
.wsh: not hidden
.js: not hidden
.jse: not hidden
*No jobs found*
