Eu estava comentando do meu roteador RT-AC68U. Esqueci que aqui é sobre o outro kkkkkkMas o seu é chines ou americano?
Falha minha.
![Coolface :coolface: :coolface:](/styles/dark_responsive/xenforo/menes/coolface.png)
Falha minha.
Por aqui atualizou normalmente e interessante que mesmo em modo AiMesh, ambos foram atualizados simultaneamente.Impressão minha ou nessa atualização da versão stock da Asus eles removeram todas as línguas deixando apenas chinês e inglês? Sacanagem...
384.6 (xx-xxx-xxxx)
- NOTE: The RT-AC87U is not supported in this release, as
Asus hasn't released any updated code for that model.
- NEW: Merged with GPL 384_21045/382_50624.
- NEW: Added support for the "-p" option to netstat.
- NEW: Added setting to enable DNS rebind protection, on the
DHCP page. This works by rejecting upstream server
responses that would point at a private IP.
- CHANGED: Updated nano to 2.9.8
- CHANGED: Updated curl to 7.60.0 (contains security fixes)
- CHANGED: Allow selecting text (for copy/paste operations)
on AiProtection pages.
- CHANGED: Added AES-*-GCM ciphers to the OpenVPN legacy
ciphers (so they can be explicitely used without
using NCP).
- CHANGED: Updated dnsmasq to 2.80test2-17-g51e4eee (themiron)
- CHANGED: Since dnsmasq 2.80, dnsmasq now ensures that unsigned
DNS replies received with DNSSEC enabled are legitimate.
If your upstream DNS doesn't support DNSSEC, this means
all replies from signed zones will be considered
invalid. Make sure you only enable DNSSEC if your
upstream DNS servers do support it. This behaviour is
a bit slower, but far more secure than the old default.
- CHANGED: Network Tools -> Netstat output also report program/PID
- CHANGED: Updated CA bundle to June 20th version.
- FIXED: IPv6-related issues on non-HND platform (themiron)
- FIXED: Couldn't log on WTFast if accessing the router
webui over https.
- FIXED: USB modem support code failing to properly pass
parameters to the kernel module (themiron)
- REMOVED: WTFast support for RT-AC88U/RT-AC3100/RT-AC5300,
as it's incompatible with recent versions of
curl (and has been broken for quite some time).
Not gonna revert back to a 7 years old curl
version just for wtfast.
Tem uns 2 dias que o merlin soltou o 384.6 beta
Código:384.6 (xx-xxx-xxxx) - NOTE: The RT-AC87U is not supported in this release, as Asus hasn't released any updated code for that model. - NEW: Merged with GPL 384_21045/382_50624. - NEW: Added support for the "-p" option to netstat. - NEW: Added setting to enable DNS rebind protection, on the DHCP page. This works by rejecting upstream server responses that would point at a private IP. - CHANGED: Updated nano to 2.9.8 - CHANGED: Updated curl to 7.60.0 (contains security fixes) - CHANGED: Allow selecting text (for copy/paste operations) on AiProtection pages. - CHANGED: Added AES-*-GCM ciphers to the OpenVPN legacy ciphers (so they can be explicitely used without using NCP). - CHANGED: Updated dnsmasq to 2.80test2-17-g51e4eee (themiron) - CHANGED: Since dnsmasq 2.80, dnsmasq now ensures that unsigned DNS replies received with DNSSEC enabled are legitimate. If your upstream DNS doesn't support DNSSEC, this means all replies from signed zones will be considered invalid. Make sure you only enable DNSSEC if your upstream DNS servers do support it. This behaviour is a bit slower, but far more secure than the old default. - CHANGED: Network Tools -> Netstat output also report program/PID - CHANGED: Updated CA bundle to June 20th version. - FIXED: IPv6-related issues on non-HND platform (themiron) - FIXED: Couldn't log on WTFast if accessing the router webui over https. - FIXED: USB modem support code failing to properly pass parameters to the kernel module (themiron) - REMOVED: WTFast support for RT-AC88U/RT-AC3100/RT-AC5300, as it's incompatible with recent versions of curl (and has been broken for quite some time). Not gonna revert back to a 7 years old curl version just for wtfast.
https://sourceforge.net/projects/asuswrt-merlin/files/RT-AC86U/
@opolones
Atualizei para esse beta acima e aqui continua todos os idiomas presentes, inclusive PT-BR!
Claro que vale, mas na minha opinião seria mais razoável você aguardar a instalação do serviço para aferir o equipamento que a VIVO irá instalar e ver se já não dá conta do recado, certamente ele é melhor do que os que você já tem e pode te fazer economizar uns trocados.Galera algumas duvidas, vou sair de uma net normal ADSL 15/2(a nova empresa passou cabos e ganhei 1,2mb de up) para FIBRA 50/5! Porém no momento eu tenho DLINK DIR-809, ao qual é o router que vou usar para fibra, já que meu TP-LINK TD-W8901N não é compatível com a rede nova.
A minha pergunta é, esse router da asus vale apena para fibra? quem usa recomenda? eu acho o dlink dir bom porem ele é velho e notei que no tempo que usei ele como router wifi ele tinha perca de pacotes e sinal mesmo estando do lado do aparelho.
Tem o modelo RT-AC1900P também, que é mais barato....(pretendo importar). Esse também seria uma boa escolha para nova internet?
Hoje tenho um cenário um pouco diferente mas por vários meses usei somente o Mitrastar que a VIVO me forneceu (tenho 100/50) e o desempenho da rede WiFi ficou bem acima das minhas expectativas, especialmente na rede 5ghz.
Muita gente já assina o serviço com um (pré)conceito de que precisa fugir do equipamento da operadora como o diabo foge da cruz, e não é bem assim.
@opolones
Bom dia Blz? Você conhece algum VPN grátis que de para usar nele? Que tenha servidor na índia, argentina, rússia, quero usar para comprar jogos dessas regiões na live, e como usaria muito pouco, não compensa pagar 12 dólares por mês, até fui ver aquela promoção de 14 dólares da vyprvpn, mas quando vi, já não tinha mais.E eu vou ficar chupando o dedo aqui, pois estou usando o aimesh.
Sinto falta da interface do Merlin, as modificações que ele fez são bem melhores que o firmware original, principalmente na parte de wifi e vpn.
A VPN do Merlin eu usava sem usuário, apenas conectava e pronto.
Na fw original tem que usar por usuário, ativei para salvar o usuário no app openvpn e está tudo ok.
De qualuqer maneira está funcionando bem o roteador aqui, apesar que o aimesh fica lá no quintal de casa, e dificilmente fico por lá diariamente.
Seria um sonho a Asus contratar o Merlin e colocar ele como chefe do desenvolvimento do firmware, ia ser um dos melhores firmwares em roteadores.
Então, o merlin deve ter deixado os idomas no release dele, a Asus que fez "caquinha" em retirar. Eu sempre usei em inglês, mas não acho correto retirar todos os outros idiomas da versão chinesa.
Como eu estou usando a versão oficial do asuswrt por causa da rede aimesh, já senti falta de uma opção da VPN.
Como eu comprei o pacote completo de software acima, veio a VPN gratuita por um ano, de $60 por $14, para quem quer somente a VPN.
Com o fw stock eu não posso selecionar quem vai receber o link da VPN somente, todo mundo na rede é obrigatório ficar na VPN, como eu não vou usar assim, tive que instalar o cliente da VPN nos dispositivos que quero testar, um saco isso.
Pena que a Asus está lerda em implementar as mudanças do Merlin, antigamente era mais esperta.
Alguém aqui usa dual wan ou fez algum teste usando dual wan?
Merlin não deixou os idiomas não hehe, pelo menos é isso que eu li no forúm, pois o patch da modificação de linguagens pela asus, só foi dado o merge apenas na versão nova, ou seja, na 384.7! Portanto e a partir dessa versão, nos nossos roteadores chineses vai ser apenas chinês e inglês!
Eu usei a muti anos com o meu ac68u, quando estava instalando a GVT e ainda não tinha cancelado a vivo speed. Na epoca eu testei apenas como failover e funcionava de boa.
Ficou bem legal, o problema é estressar a conexão praticamente o dia inteiro, não? =[
