Forcei o Kies a fazer o download da Rom do Froyo, mas não funcionou, diz que o aparelho já esta com a rom atualizada...
Segui esse procedimento do XDA
This tool is was designed in order to easily patch the registry to force Kies to update your Galaxy S.
This latest version of patcher works even with latest Kies (1.5.3.10103.102), all you have to do is to spoof your firmware version to and older one, you can even spoof the product code in order to change it.
The new spoof system works differently from the older patching system, it allow you to use the original dll of kies and works on latest Kies; It should even be future-proof.
PRELIMINARY NOTE:
[WARNING!] Do Not flash Any ROM (firmware) until you can get the 3 buttons DOWNLOAD MODE working, even with this Kies trick. (
o meu não funciona, mas fui na raça mesmo
If you want to test the 3 buttons download mode then notice that you can switch back to normal mode by pulling the battery out and then back in. At the next boot the phone will be back in normal mode.
LAGFIX USERS:
[WARNING!] Remember to disable lagfix before to update.
This will avoid filesystem errors that may occurs at the boot of the new flashed firmware.
não fiz lag fix
INSTRUCTIONS:
1) Download latest Kies Registry Patcher, tool is attachment. Note: It require Microsoft .NET Framework 3.5 or later version.
OK
2) Update Kies to 1.5.3.10103.102.
OK
3) Launch Kies Registry Patcher; If you patched the dll in the past with an older version of the patcher then be sure to launch new release as administrator since it have to revert the dll to the original version as the patch isn't needed anymore (Right click on application > Run as Administrator).
OK
4) Launch Kies and connect your phone; Wait for Kies to recognize it properly.
OK
5) You have 2 possibilities now:
5a) Drop down the combo-box "Spoof Product Code as" and select the wanted one. It should automatically fill the "Spoof Software Revision as" textbox with the needed data necessary to find your update.
This feature was added in order to give all the opportunity to use the needed product code. (Special thanks to MCOGW that shared with me his database of product codes/sw revisions).
The label above will be completed with the country related to the chosen product code.
OK, usei a ZTA que é do Brasil
5b) From patcher select:
File > Load Backup
Open the backup that you want to use (e.g. kies-backup-XEU.xml if you want to spoof your phone as XEU, or if your phone is XEU yet and you want to flash it again).
6) From patcher answer "YES" in order to apply the registry update.
OK
7) From Kies you can now update as normal.
aqui, FAIL total
bom galera, li o que o Wolverine escreveu e consertei o que tava dando pau, foi no passo 5a, selecionei o ZW e foi, agora ex celular da Claro, com Froyo da VIVO e GMAIL com GTALK, celular sem lag algum, liso liso liso, sensacional, nunca mais volto para a rom da Claro sem gmail
