Silent Hill 1 Pc Version
N 64
SRS FOREVER!!!
Olá amigos do Adrena...:cool:
Silent Hill PC Version:
TAMANHO DO GAME: 363 MB
EMPRESA: silentscape
SITE: www.silentscape.tk
____________________________________________
|Silent Hill - PC (con)Version |
|Created By: Konami |
|PC (con)Version By: Silentscape Studios |
|PC Site (our site): www.silentscape.tk |
|Our Email Address: [email protected] |
|____________________________________________|
--------Contents--------
1) Introduction
2) Configuring Settings
3) Controls
4) Using Quick Save\Load
5) Using Mouse Support
6) How to Play In A PSX
7) Contact Info
(1)--Introduction--
This is the PC version of Silent Hill, which is one of the most (if not THE most) scariest
games you'll ever play. The PC version is based on ePSXe, a Playstation emulator. ePSXe
is the main "engine" for the game. However, we have tweaked it to fully support Silent Hill
and provide the best game experience possible. We've also simplified the configuration process
greatly, so no more hassling with various emulators trying to get the game to work correctly.
(2)--Configuring Settings--
Run the Silent Hill launcher (using the "Silent Hill" shortcut in the start menu or desktop).
Then click where it says "Settings". It's a wizard-like step-by-step process and explains each
option as you see it. For different computer systems, different settings work better. You'll
just have to try various options to see which settings work best.
(3)--Controls--
Esc = Exits the game. There's no prompt so make sure you have the game saved first (if needed).
F1 = Quick Save
F2 = Cycle Quick Save Slots
F3 = Quick Load (from currently selected slot)
F5 = Disable\Re-enable Mouse Support (see description below)
F10 = Freeze (pause) anywhere in the game (even videos). Press again to un-freeze.
Up Arrow = Walk Forward
Down Arrow = Walk Backward
Left Arrow = Turn Left
Right Arrow = Turn Right
Spacebar = Action \ Fire Weapon \ Use
Backspace = View Map \ Exit Menu Screens
I = Access Inventory
TAB = Turn On or Off Flashlight \ Exit Menu Screens
Left Shift = Run (hold down to run, release to walk)
Left CTRL = Hold Down to Raise Weapon (then press Spacebar to fire)
Q = Sidestep Left
E = Sidestep Right
Z = Look Around (hold it down then use arrow keys)
P = Pause Game \ Skip Movie Scenes
(4)--Using Quick Save\Load--
The quick save feature allows you to save anywhere at any point in the game. If you want
to be able to use multiple quick saves, use the cycle quick save slots option (F2). Whatever
slot you currently have it set at is what the Quick Save (F1) and Quick Load (F3) use.
For example, you can use F2 to pick a quick save slot. From then on whenever you quick save
or quick load, it'll use the data from that slot. Push F2 again (cycle to another slot) and
it will now start using the quick save\load data from that new slot.
Although you can use quick save, you can still save normally using the save points throughout
the game. Whenever you access the "Save" screen at a save point, you can use both save Slot 1 and
Slot 2. There's no difference, so use either one. Also, you can save more than once in both
slots. You can have pretty much an infinite number of different saves.
(5)--Using Mouse Support--
The mouse support isn't really that great, since the game wasn't originally meant to be
used with a mouse. However you can use it if you want. Press and hold either the left or right
mouse button. Then move the mouse up a little bit until you start moving. While you're
walking (or running), you can move the mouse left or right to turn in that direction.
The mouse only works for movement. To fire weapons and use items you still have to use
the keyboard keys. To disable mouse support, press F5. Press it again to re-enable it.
(6)--How to Play In A Playstation--
If you want to play Silent Hill in a playstation, then it's possible. All you need to do is
burn the "data.iso" to CD using any program that supports ISO burning (Nero, Easy CD Creator, etc).
Please note that in order to play burned games you need to have a modchip installed (or know how
to do the swap trick).
(7)--Contact Info--
If you have any comments, questions, concerns, or need any help regarding the game, then you may
email us at [email protected]
You can also visit our website at www.silentscape.tk for more information and updates.
Posteriormente postarei SS....:yes:
Enjoy...:music:
strikegamer
Gamista :)
Eu tenho esse jogo instalado aqui...
Claro q não se compara aos outros silent hill pelas limitações da época, mas fizeram um trabalho muito bem feito com esse emulador otimizado.
Dá pra mudar resolução , colocar filtros, alterar controles... mto bom msm...
Vale lembrar, como está escrito na descrição do primeiro tópico, que ele roda no emulador ePSXE, mas esse jogo tá tipo com um Autorun, nao precisando mexer em nenhuma config direto do emulador...
Ah galera, e se lembrem tbem, que por mais q tenha opçoes, o emulador nao faz milagres hehehe, pra traficos melhores só um remake msm hehehe...
Leo.
Leon
eu tô com ele aqui... só que parei naquele colégio, já revirei tudo, e não sei o que tem que fazer...
alguém ajuda?
Sgt. Rock
PSN/Steam ID: Jhonrock
perae, isso é uma versão pc mesmo?... um porte oficial da konami? Ou é um fan port? Uma versão emulada do PS1.
Eu conheço um, mas na verdade, lá no integro do jogo, era uma versão emulada, um frontend do ePSXe com algumas opções especiais. Só que tinha alguns bugs.
Leo.
Leon
é uma versão alterada, pq pra PC não existe...
na verdade é um programa que contém o emulador de PXS e o rom, só que integrado.
Gargula
Gamer since 1994!
Eu tava jogando ao menos tentando jogar, os controles sao extremamente confusos.
Se vc da esc o jogo fecha aehuhueahae.
Leo.
Leon
os controles do jogo não são complicados... só esse ESC aí que é mal-feito mesmo.:slap:
kasparov
VALEU pela dica muito bom ter esse jogo guardado no HD, alguem tem ai uns save pra poder relembrar as fases ?
flw
RRenan
Fotinhus Please !!!!
RRenan
Link pra Download pessoal !!! Se naum for Proibido !!!
Dantas
Nerd Mór
The screeeeeeeeeeeeeeeeans!! The screenshots my godness!
Que massa, to censurado agora :D
Meteoro
E ae N 64 blz, ehehe mundo pequeno ^^
Abraços ae
Nem preciso falar nada sobre esse jogo neh :whistle: :fun: :yes: :lol: :wave:
mash
Galera, mto bacana!!!
Alguém manda MP para lojas online que possam estar com pré-venda!
Sabe como é, não quero que seja divulgado abertamente. :lol: :evil: :said: :cry: :boring:
bobarros
Eu vou na faculdade ver se pego uma matéria e quando votlar eu vejo se funciona aqui, quem quiser pod eme mandar uma MP.
Mas eu acho que merecia ter saido um remake do primeiro junto com o filme.
Leo.
Leon
o jogo é ótimo, pena que essa versão é cheia de pau...
N 64
SRS FOREVER!!!
Abraços ae
É isso aê amigo Meteoro...Blz???
Quero rodar POP 3D no windows XP...ajuda aê...amigão!!!
T+:yes:
