Service Menu Code For Samsung TV:
There are many codes available for accessing service menu in various Samsung TV models. You can try following codes one by one until you get access to service menu:
First power off your TV using the remote, then press following buttons quickly on the remote:
Mute + 1 + 8 + 2 + Power
Display/Info + Menu + Mute + Power
Display/Info + P.STD + Mute + Power
P.STD + Help + Sleep + Power
P.STD + Menu + Sleep + Power
Sleep + P.STD + Mute + Power
You can press Channel Up/Down buttons to navigate between available options. To change their values, press Volume Up/Down buttons.
Hidden Secret Service Menu Codes for Sony, Samsung, LG and Philips TV
https://www.youtube.com/watch?v=Ff2X...ature=youtu.be
https://www.youtube.com/watch?v=I7HY...ature=youtu.be
https://www.youtube.com/watch?v=fcFS...ature=youtu.be
https://www.youtube.com/watch?v=az0e...ature=youtu.be
Има някои грешни преводи в клиповете!!
Decoding Samsung panel
EXAMPLE from a QE65Q8F
How to read the panel type in the service menu - example Type 65A1MU8XM (from the Service Menu) ?
Как да разчетете типа панел в сервизното меню - пример Type 65A1MU8XM (от сервизното меню) ?
65 - Inch/size (размер)
A - Vendor /производител/
1 - Panel frequency (работна честота на панела)
- 6 - 50 (60Hz)
- 1 - 100 (120Hz)
- 2 - 200 (240Hz)-> [100/120Hz panel + BFI...or scanning backlight]
M - Panel coating (покритие на панела)
- M - Matt
- U - Ultra Clear
- A - AntiGlare
U - Resolution (резолюция)
- U - Ultra HD
- F - Full HD,
- H - HD ready,
8 - Generation panel (revision) ?
- 9 - 9 revision ?
- 8 - 8 revision ?
- 7 - 7 revision ?
- 0 - base revision (Depending on the series and diagonal)
X - BLU (BackLight Unit) - (тип подсветка)
- X - Edge LED Bottom (With Local Dimming) + QDCF
- S - Edge LED Bottom
- Q - Quantum Dots (in series KS)
- K - Edge LED (in K series)
- years 2008/2014
- Y - Direct Led + Full Local Dimming
- T - Edge LED + Limited Local Dimming
- W - Edge LED (Without Local Dimming)
- C - CCFL (cold catode fluorescent lamp)
- L - LED,
- D - Direct LED
- E - Edge LED
- V - Vertical Edge LED (above and below) / Two side Edge led
- S - Side by side LED (left & right) / Single side LED
- EH - Even horizontal
- RH - Rounded horizontal
M - Samsung Model Year Where (година на модела):
- M - 2017
- K - 2016
- J - 2016
- H - 2014
Warning!!
UE55MU6102: a-si TFT IPS(PLS) panel (RGB), 60/50Hz, in service menu 55,
UE55MU6102: a-si TFT Samsung MVA panel (RGB), 60/50Hz, in service menu
55A6AUOVK,
UE50MU6102: a-si TFT MVA panel (RGB), 60/50Hz, platform
UE43MU6100: a-si TFT AMVA panel (RGB), 60/50Hz, in service menu 43L6AUOVM,
UE40MU6102: a-si TFT MVA panel (RGВ), 60/50Hz,
UE55M5512: a-si TFT MVA panel (RGВ), 60/50Hz,
UE43M5502: a-si TFT MVA panel (RGB), 60/50Hz,
UE32M5602: a-si TFT MVA panel (RGВ), 60/50Hz,
