x264 Benchmark - Como se sai seu computador?
  • Iniciador de Tópicos Gatuno
  • Data de Início
i5 2500k@4.5 ghz
Results for x264.exe r1342
encoded 1442 frames, 117.56 fps, 3900.68 kb/s
encoded 1442 frames, 120.59 fps, 3900.68 kb/s
encoded 1442 frames, 119.76 fps, 3900.68 kb/s
encoded 1442 frames, 121.69 fps, 3900.68 kb/s
encoded 1442 frames, 36.46 fps, 3971.95 kb/s
encoded 1442 frames, 36.54 fps, 3971.85 kb/s
encoded 1442 frames, 36.52 fps, 3970.69 kb/s
encoded 1442 frames, 36.50 fps, 3970.53 kb/s
System Details
Name Intel Sandy Bridge
Codename
Specification Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
Specification PC3-12800
Core Stepping
Technology 32 nm
manufacturer Gigabyte Technology Co., Ltd.
vendor Gigabyte Technology Co., Ltd.
Stock frequency 3300 MHz
Core Speed 3292.5 MHz
Northbridge Intel ID0100 rev. 09
Southbridge Intel ID1C46 rev. 04
Command Rate 2T
Command Rate 2T
Memory Type
Memory Size 4096 MBytes
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600)
Number of processors 1
Number of threads 4
Number of threads 4 (max 16)
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX
Package (platform ID) (0x1)
Temperature 0 36°C (96°F) [0x24] (TMPIN0)
Temperature 1 25°C (76°F) [0x19] (TMPIN1)
Temperature 2 48°C (118°F) [0x30] (TMPIN2)
Temperature 0 55°C (130°F) [0x2B] (Core #0)
Temperature 1 57°C (134°F) [0x29] (Core #1)
Temperature 2 56°C (132°F) [0x2A] (Core #2)
Temperature 3 55°C (130°F) [0x2B] (Core #3)
Opa, fiz umas comparações aqui com o meu, hoje chegou meu Hyper 212 e pude sair do stock sem medo, seguem os resultados COM e SEM over, Cooler Box e Hyper 212
i5 760 Stock COM Hyper 212 Dual Fan (Não sei pq mostra 2.9 ali no Core Speed sendo que o Stock é 2.8, enfim, sem muita diferença)
x264 HD BENCHMARK 3.0 RESULTS
Please do not compare it with older versions of the benchmark!
Please copy/paste everything below the line to to report your data
encoded 1442 frames, 67.18 fps, 3900.68 kb/s
encoded 1442 frames, 68.27 fps, 3900.68 kb/s
encoded 1442 frames, 68.47 fps, 3900.68 kb/s
encoded 1442 frames, 68.07 fps, 3900.68 kb/s
encoded 1442 frames, 22.11 fps, 3971.44 kb/s
encoded 1442 frames, 22.17 fps, 3971.14 kb/s
encoded 1442 frames, 22.02 fps, 3968.70 kb/s
encoded 1442 frames, 22.12 fps, 3970.60 kb/s
System Details
Name Intel Core i5 760
product System Product Name
Codename Lynnfield
Specification Intel(R) Core(TM) i5 CPU 760 @ 2.80GHz
Core Stepping B1
Technology 45 nm
Stock frequency 2800 MHz
Core Speed 2942.4 MHz
Northbridge Intel DMI Host Bridge rev. 11
Southbridge Intel P55 rev. 06
CAS# latency (CL) 9.0
RAS# to CAS# delay (tRCD) 9
RAS# Precharge (tRP) 9
Cycle Time (tRAS) 24
Command Rate (CR) 2T
Memory Frequency 668.7 MHz (2:10)
Memory Type DDR3
Memory Size 6144 MBytes
Channels Single
Windows Version Microsoft Windows 7 (6.1) Enterprise Edition Service Pack 1 (Build 7601)
Number of threads 4
Package (platform ID) Socket 1156 LGA (0x1)
Temperature 0 42°C (107°F) [0x2A] (SYSTIN)
Temperature 1 42°C (107°F) [0x54] (CPUTIN)
Temperature 2 30°C (85°F) [0x3C] (AUXTIN)
Temperature 0 41°C (105°F) [0x3A] (Core #0)
Temperature 1 36°C (96°F) [0x3F] (Core #1)
Temperature 2 41°C (105°F) [0x3A] (Core #2)
Temperature 3 34°C (93°F) [0x41] (Core #3)
i5 760@3.1Ghz COOLER BOX
encoded 1442 frames, 71.33 fps, 3900.68 kb/s
encoded 1442 frames, 72.80 fps, 3900.68 kb/s
encoded 1442 frames, 73.11 fps, 3900.68 kb/s
encoded 1442 frames, 72.58 fps, 3901.21 kb/s
encoded 1442 frames, 21.68 fps, 3971.82 kb/s
encoded 1442 frames, 22.18 fps, 3971.21 kb/s
encoded 1442 frames, 22.16 fps, 3971.68 kb/s
encoded 1442 frames, 22.20 fps, 3971.07 kb/s
System Details
Codename Lynnfield
Core Stepping B1
Technology 45 nm
Core Speed 3086.8 MHz
Memory Frequency 701.5 MHz (2:10)
Memory Type DDR3
Channels Dual
Number of threads 4
Temperature 0 82°C (179°F) [0x52] (SYSTIN)
Temperature 1 83°C (180°F) [0xA5] (CPUTIN)
Temperature 2 64°C (146°F) [0x7F] (AUXTIN)
Temperature 0 81°C (177°F) [0x12] (Core #0)
Temperature 1 78°C (172°F) [0x15] (Core #1)
Temperature 2 83°C (181°F) [0x10] (Core #2)
Temperature 3 81°C (177°F) [0x12] (Core #3)
i5 760@3.4 Com Hyper 212 (Over automático da MOBO, exibido no teste 3.6)
encoded 1442 frames, 73.30 fps, 3900.68 kb/s
encoded 1442 frames, 73.89 fps, 3900.68 kb/s
encoded 1442 frames, 73.25 fps, 3900.68 kb/s
encoded 1442 frames, 73.19 fps, 3900.68 kb/s
encoded 1442 frames, 26.36 fps, 3971.79 kb/s
encoded 1442 frames, 26.44 fps, 3971.84 kb/s
encoded 1442 frames, 26.52 fps, 3971.88 kb/s
encoded 1442 frames, 26.48 fps, 3970.58 kb/s
System Details
Codename Lynnfield
Core Stepping B1
Technology 45 nm
Core Speed 3621.1 MHz
Memory Frequency 517.3 MHz (2:6)
Memory Type DDR3
Channels Single
Number of threads 4
Temperature 0 58°C (136°F) [0x3A] (SYSTIN)
Temperature 1 59°C (138°F) [0x76] (CPUTIN)
Temperature 2 41°C (105°F) [0x52] (AUXTIN)
Temperature 0 57°C (134°F) [0x2A] (Core #0)
Temperature 1 53°C (127°F) [0x2E] (Core #1)
Temperature 2 53°C (127°F) [0x2E] (Core #2)
Temperature 3 53°C (127°F) [0x2E] (Core #3)
O restante da Config está na sign. Tive um ganho excelente na temperatura (Praticamente 50% em tudo) com o clock bem mais elevado.
Primeiro em Stock 2.8
encoded 1442 frames, 55.40 fps, 3898.70 kb/s
encoded 1442 frames, 55.66 fps, 3898.70 kb/s
encoded 1442 frames, 55.56 fps, 3898.70 kb/s
encoded 1442 frames, 55.15 fps, 3898.70 kb/s
encoded 1442 frames, 24.84 fps, 3970.88 kb/s
encoded 1442 frames, 24.78 fps, 3970.44 kb/s
encoded 1442 frames, 24.76 fps, 3970.88 kb/s
encoded 1442 frames, 24.77 fps, 3970.38 kb/s
System Details
Name AMD Phenom II X6 1055T
Codename Thuban
Specification AMD Phenom(tm) II X6 1055T Processor
Core Stepping PH-E0
Technology 45 nm
Core Speed 2800.1 MHz
FID range 4.0x - 16.5x
Northbridge AMD 790X rev. 00
Southbridge AMD SB700 rev. 00
CAS# latency (CL) 5.0
RAS# to CAS# delay (tRCD) 5
RAS# Precharge (tRP) 5
Cycle Time (tRAS) 18
Memory Frequency 400.0 MHz (1:2)
Memory Type DDR2
Memory Size 2048 MBytes
Channels Single
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 1 (Build 7601)
Number of threads 6
Number of threads 6 (max 6)
L2 cache 6 x 512 KBytes, 16-way set associative, 64-byte line size
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V
Package Socket AM3 (938)
Package Type 0x1
Temperature 0 45°C (112°F) [0x2D] (TMPIN0)
Temperature 2 38°C (100°F) [0x26] (TMPIN2)
Temperature 0 30°C (85°F) [0xEE] (Core #0)
Temperature 1 30°C (85°F) [0xEE] (Core #1)
Temperature 2 30°C (85°F) [0xF0] (Core #2)
Temperature 3 30°C (85°F) [0xF0] (Core #3)
Temperature 4 30°C (85°F) [0xEF] (Core #4)
Temperature 5 30°C (85°F) [0xEC] (Core #5)
Agora em 3.5
encoded 1442 frames, 66.35 fps, 3898.70 kb/s
encoded 1442 frames, 66.45 fps, 3898.70 kb/s
encoded 1442 frames, 66.50 fps, 3898.70 kb/s
encoded 1442 frames, 66.36 fps, 3898.70 kb/s
encoded 1442 frames, 31.60 fps, 3961.14 kb/s
encoded 1442 frames, 31.39 fps, 3968.30 kb/s
encoded 1442 frames, 31.36 fps, 3968.25 kb/s
encoded 1442 frames, 31.28 fps, 3971.72 kb/s
System Details
Codename Thuban
Core Stepping PH-E0
Technology 45 nm
Core Speed 3500.1 MHz
Cycle Time (tRAS) 15
Memory Frequency 416.7 MHz (3:5)
Memory Type DDR2
Channels Single
Number of threads 6
Package Type 0x1
Temperature 2 32°C (89°F) [0x20] (TMPIN2)
Temperature 0 29°C (84°F) [0xEB] (Core #0)
Temperature 1 30°C (85°F) [0xED] (Core #1)
Temperature 2 30°C (85°F) [0xEC] (Core #2)
Temperature 3 30°C (85°F) [0xEC] (Core #3)
Temperature 4 29°C (84°F) [0xEB] (Core #4)
meu humilde resultado, proc em stock!
encoded 1442 frames, 37.33 fps, 3899.26 kb/s
encoded 1442 frames, 38.61 fps, 3899.26 kb/s
encoded 1442 frames, 37.41 fps, 3899.26 kb/s
encoded 1442 frames, 35.60 fps, 3899.26 kb/s
encoded 1442 frames, 9.98 fps, 3971.40 kb/s
encoded 1442 frames, 10.01 fps, 3972.02 kb/s
encoded 1442 frames, 9.98 fps, 3971.14 kb/s
encoded 1442 frames, 9.83 fps, 3970.53 kb/s
System Details
Name AMD Athlon II X2 260
Codename Regor
Specification AMD Athlon(tm) X2 260 Processor
Core Stepping DA-C3
Technology 45 nm
Stock frequency 3200 MHz
Core Speed 3200.1 MHz
FID range 4.0x - 16.0x
Northbridge AMD 780G rev. 00
CAS# latency (CL) 6.0
RAS# to CAS# delay (tRCD) 6
RAS# Precharge (tRP) 6
Memory Type DDR2
Memory Size 3072 MBytes
Channels Dual, (Unganged)
Windows Version Microsoft Windows 7 (6.1) Home Premium Edition Service Pack 1 (Build 7601)
Number of threads 2
Number of threads 2 (max 2)
L2 cache 2 x 1024 KBytes, 16-way set associative, 64-byte line size
Package Type 0x1
Temperature 0 50°C (121°F) [0x32] (TMPIN0)
Temperature 1 32°C (89°F) [0x20] (TMPIN1)
Temperature 0 30°C (85°F) [0xBD8] (THRM)
Temperature 0 47°C (117°F) [0x17A] (Core #0)
Temperature 1 47°C (117°F) [0x17A] (Core #1)
encoded 1442 frames, 58.97 fps, 3900.68 kb/s
encoded 1442 frames, 59.55 fps, 3900.68 kb/s
encoded 1442 frames, 59.76 fps, 3900.68 kb/s
encoded 1442 frames, 61.13 fps, 3900.68 kb/s
encoded 1442 frames, 19.15 fps, 3970.91 kb/s
encoded 1442 frames, 19.03 fps, 3969.30 kb/s
encoded 1442 frames, 19.09 fps, 3972.61 kb/s
encoded 1442 frames, 19.09 fps, 3970.71 kb/s
System Details
Name AMD Phenom II X4 940
Codename Deneb
Specification AMD Phenom(tm) II X4 940 Processor
Core Stepping RB-C2
Technology 45 nm
Core Speed 3016.0 MHz
Memory Frequency 402.1 MHz (1:2)
Memory Type DDR2
Channels Dual, (Ganged)
Windows Version Microsoft Windows 7 (6.1) (Build 7600)
Number of threads 4
Number of threads 4 (max 4)
L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size
Package Socket AM2+ (940)
Package Type 0x1
Temperature 0 48°C (118°F) [0x30] (TMPIN0)
Temperature 1 38°C (100°F) [0x26] (TMPIN1)
Temperature 0 47°C (116°F) [0x178] (Core #0)
Temperature 1 47°C (116°F) [0x178] (Core #1)
Temperature 2 47°C (116°F) [0x178] (Core #2)
Temperature 3 47°C (116°F) [0x178] (Core #3)
Postando novamente, agora com over feito manualmente na BIOS @3.61Ghz, um ganho considerável aos anteriores (Disponíveis na mesma página, post #253).
encoded 1442 frames, 85.78 fps, 3901.21 kb/s
encoded 1442 frames, 85.48 fps, 3900.68 kb/s
encoded 1442 frames, 86.15 fps, 3900.68 kb/s
encoded 1442 frames, 85.14 fps, 3901.21 kb/s
encoded 1442 frames, 26.01 fps, 3959.70 kb/s
encoded 1442 frames, 26.12 fps, 3971.90 kb/s
encoded 1442 frames, 26.25 fps, 3970.93 kb/s
encoded 1442 frames, 26.05 fps, 3970.85 kb/s
System Details
Codename Lynnfield
Core Stepping B1
Technology 45 nm
Core Speed 3612.0 MHz
Command Rate (CR) 1T
Memory Frequency 802.7 MHz (2:8)
Memory Type DDR3
Channels Dual
Number of threads 4
Temperature 0 61°C (141°F) [0x3D] (SYSTIN)
Temperature 1 61°C (141°F) [0x7A] (CPUTIN)
Temperature 2 43°C (108°F) [0x55] (AUXTIN)
Temperature 0 58°C (136°F) [0x29] (Core #0)
Temperature 1 56°C (132°F) [0x2B] (Core #1)
Temperature 2 57°C (134°F) [0x2A] (Core #2)
Temperature 3 50°C (121°F) [0x31] (Core #3)
Alguém poderia me explicar uma coisa dessa:
Results for x264.exe r1913
Pass 1
encoded 1442 frames, 80.24 fps, 3911.63 kb/s
encoded 1442 frames, 80.66 fps, 3911.63 kb/s
encoded 1442 frames, 77.35 fps, 3911.63 kb/s
encoded 1442 frames, 35.87 fps, 3911.63 kb/s
Pass 2
encoded 1442 frames, 18.56 fps, 3959.59 kb/s
encoded 1442 frames, 17.71 fps, 3959.48 kb/s
encoded 1442 frames, 15.18 fps, 3959.07 kb/s
encoded 1442 frames, 8.39 fps, 3959.42 kb/s
System Details
Name Intel Core i7
Codename Sandy Bridge
Specification Intel(R) Core(TM) i7-2630QM CPU @ 2.00GHz
Core Stepping D2
Technology 32 nm
Stock frequency 2000 MHz
Core Speed 798.2 MHz
Northbridge Intel Sandy Bridge rev. 09
Southbridge Intel HM65 rev. B2
Memory Frequency 665.2 MHz (1:5)
Memory Type DDR3
Number of threads 8
Number of threads 8 (max 16)
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AVX
Package (platform ID) Socket 988B rPGA (0x4)
Temperature 0 28°C (82°F) [0xBC2] (TZ00)
Temperature 1 30°C (85°F) [0xBD6] (TZ01)
Já procurei em todos os lugares possíveis por uma solução e nada! Isso porque esse teste foi bom! Algumas vezes no Run 4 ele derruba pra 8 fps. Quase igual ao meu Core 2 Duo. Alguém tem alguma idéia?
Pass 1
Pass 2
System Details
Name Intel Core i7
Core Stepping D2
Technology 32 nm
Memory Type DDR3
Number of threads 8
Atualiza o programa e ve se ta estavel esse over ai. Ta fraco mesmo.
Não fiz over
Não fiz over. Comprei pela internet e chegou ontem desse jeito. Não sei o que acontece! Alguém tem alguma idéia?
Segue o meu teste, gostaria de ver um sandy para fazer a comparação.
x264 HD BENCHMARK 4.0 RESULTS
Please do NOT compare it with older versions of the benchmark!
Pass 1
encoded 1442 frames, 156.03 fps, 3911.63 kb/s
encoded 1442 frames, 156.42 fps, 3911.63 kb/s
encoded 1442 frames, 155.10 fps, 3911.63 kb/s
encoded 1442 frames, 156.16 fps, 3911.63 kb/s
Pass 2
encoded 1442 frames, 37.99 fps, 3958.48 kb/s
encoded 1442 frames, 37.81 fps, 3960.98 kb/s
encoded 1442 frames, 37.82 fps, 3960.62 kb/s
encoded 1442 frames, 37.75 fps, 3959.12 kb/s
System Details
Name Intel Core i7 920
Codename Bloomfield
Specification Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
Core Stepping D0
Technology 45 nm
Stock frequency 2666 MHz
Core Speed 4011.3 MHz
Northbridge Intel X58 rev. 12
Southbridge Intel 82801JR (ICH10R) rev. 00
CAS# latency (CL) 8.0
RAS# to CAS# delay (tRCD) 8
RAS# Precharge (tRP) 8
Command Rate 2T
Command Rate 2T
Command Rate 2T
Memory Frequency 764.1 MHz (2:8)
Memory Type DDR3
Channels Triple
Number of threads 8
Package (platform ID) Socket 1366 LGA (0x1)
Temperature 0 47°C (116°F) [0x2F] (TMPIN0)
Temperature 1 67°C (152°F) [0x43] (TMPIN1)
Temperature 2 37°C (98°F) [0x25] (TMPIN2)
Temperature 0 47°C (116°F) [0xC82] (THRM)
Então lá vai, i7 2600K@3.9GHz
to http://forums.techarp.com/reviews-articles/26363-x264-hd-benchmark-4-0-a.html
Pass 1
encoded 1442 frames, 167.93 fps, 3911.63 kb/s
encoded 1442 frames, 173.63 fps, 3911.63 kb/s
encoded 1442 frames, 173.97 fps, 3911.63 kb/s
encoded 1442 frames, 174.79 fps, 3911.63 kb/s
Pass 2
encoded 1442 frames, 44.56 fps, 3959.01 kb/s
encoded 1442 frames, 44.56 fps, 3959.06 kb/s
encoded 1442 frames, 44.43 fps, 3960.55 kb/s
encoded 1442 frames, 44.48 fps, 3960.39 kb/s
C2Q Q9550 @2.83Ghz
Pass 1
encoded 1442 frames, 94.23 fps, 3912.26 kb/s
encoded 1442 frames, 94.91 fps, 3912.26 kb/s
encoded 1442 frames, 94.71 fps, 3912.26 kb/s
encoded 1442 frames, 95.19 fps, 3912.26 kb/s
Pass 2
encoded 1442 frames, 19.33 fps, 3961.46 kb/s
encoded 1442 frames, 19.37 fps, 3962.19 kb/s
encoded 1442 frames, 19.32 fps, 3961.38 kb/s
encoded 1442 frames, 19.23 fps, 3961.01 kb/s
System Details
Name Intel Core 2 Quad Q9550
Codename Yorkfield
Specification Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz
Core Stepping E0
Technology 45 nm
Stock frequency 2833 MHz
Core Speed 2002.1 MHz
FID range 6.0x - 8.5x
Northbridge Intel P45/P43/G45/G43 rev. A3
RAS# to CAS# delay (tRCD) 4
RAS# Precharge (tRP) 4
Memory Frequency 400.4 MHz (5:6)
Memory Type DDR2
Channels Dual, (Symmetric)
Number of threads 4
L2 cache 2 x 6144 KBytes, 24-way set associative, 64-byte line size
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T, VT-x
Package (platform ID) Socket 775 LGA (0x4)
Temperature 0 37°C (98°F) [0x25] (TMPIN0)
Temperature 1 33°C (91°F) [0x21] (TMPIN1)
i5 2500k @4.2Ghz
Pass 1
encoded 1442 frames, 173.84 fps, 3912.26 kb/s
encoded 1442 frames, 173.46 fps, 3912.26 kb/s
encoded 1442 frames, 172.08 fps, 3912.26 kb/s
encoded 1442 frames, 176.91 fps, 3912.26 kb/s
Pass 2
encoded 1442 frames, 34.77 fps, 3961.60 kb/s
encoded 1442 frames, 34.55 fps, 3961.89 kb/s
encoded 1442 frames, 35.56 fps, 3961.56 kb/s
encoded 1442 frames, 35.52 fps, 3961.28 kb/s
encoded 1442 frames, 76.96 fps, 3898.70 kb/s
encoded 1442 frames, 76.90 fps, 3898.70 kb/s
encoded 1442 frames, 76.52 fps, 3898.70 kb/s
encoded 1442 frames, 32.66 fps, 3947.61 kb/s
encoded 1442 frames, 32.65 fps, 3968.05 kb/s
encoded 1442 frames, 32.59 fps, 3969.96 kb/s
encoded 1442 frames, 32.24 fps, 3968.30 kb/s
System Details
Name AMD Phenom II X6 1090T
Codename Thuban
Specification AMD Phenom(tm) II X6 1090T Processor
Core Stepping PH-E0
Technology 45 nm
Core Speed 3520.4 MHz
Northbridge AMD 770 rev. 00
Memory Frequency 440.0 MHz (1:2)
Memory Type DDR2
Number of threads 6
Package Type 0x1
Temperature 0 52°C (125°F) [0x34] (TMPIN0)
Temperature 1 34°C (93°F) [0x22] (TMPIN1)
encoded 1442 frames, 124.49 fps, 3900.68 kb/s
encoded 1442 frames, 124.32 fps, 3900.68 kb/s
encoded 1442 frames, 124.92 fps, 3900.68 kb/s
encoded 1442 frames, 122.68 fps, 3901.21 kb/s
encoded 1442 frames, 36.91 fps, 3971.85 kb/s
encoded 1442 frames, 36.91 fps, 3971.24 kb/s
encoded 1442 frames, 36.84 fps, 3971.63 kb/s
encoded 1442 frames, 37.02 fps, 3971.44 kb/s
System Details
Name Intel Core i5 2500K
Specification PC3-12800E
Core Stepping D2
Technology 32 nm
Core Speed 4489.7 MHz
Southbridge Intel P67 rev. B2
Command Rate 2T
Command Rate 2T
Command Rate 2T
Command Rate 2T
Memory Frequency 798.2 MHz (1:6)
Memory Type DDR3
Memory Size 8192 MBytes
Number of threads 4
Package (platform ID) Socket 1155 LGA (0x1)
Temperature 0 34°C (93°F) [0x22] (Aux)
Temperature 1 42°C (107°F) [0x2A] (CPU)
Temperature 2 52°C (125°F) [0x34] (Mainboard)
SB é o que há.... imagina esses processadores a 5.5ghz
PROGRAMA ATUALIZADO
Pass 1
encoded 1442 frames, 182.02 fps, 3912.26 kb/s
encoded 1442 frames, 186.76 fps, 3912.26 kb/s
encoded 1442 frames, 186.18 fps, 3912.26 kb/s
encoded 1442 frames, 182.69 fps, 3912.26 kb/s
Pass 2
encoded 1442 frames, 37.34 fps, 3961.74 kb/s
encoded 1442 frames, 37.25 fps, 3961.39 kb/s
encoded 1442 frames, 37.50 fps, 3961.83 kb/s
encoded 1442 frames, 37.51 fps, 3961.19 kb/s
Estranhos esses testes acima com i5 2500k@4.4ghz, ele ficou igual ao meu i7 920@4ghz. Isso ta certo mesmo? Eu achava que ele seriam bem superiores.:huh:
nesse bench leva vantagem processadores que tem mais cores ou, no caso do i7, ht.
meu 950 a 4.1gz em modo economia:
encoded 1442 frames, 94.03 fps, 3899.02 kb/s
encoded 1442 frames, 94.90 fps, 3899.02 kb/s
encoded 1442 frames, 95.88 fps, 3899.02 kb/s
encoded 1442 frames, 93.84 fps, 3898.50 kb/s
encoded 1442 frames, 38.58 fps, 3956.27 kb/s
encoded 1442 frames, 38.28 fps, 3952.25 kb/s
encoded 1442 frames, 38.24 fps, 3962.39 kb/s
encoded 1442 frames, 35.01 fps, 3949.36 kb/s
System Details
Name Intel Core i7 950
Codename Bloomfield
Specification Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz
Core Stepping D0
Technology 45 nm
Stock frequency 3066 MHz
Core Speed 4139.8 MHz
Northbridge Intel X58 rev. 13
Cycle Time (tRAS) 22
Command Rate 2T
Command Rate 2T
Command Rate 2T
Memory Frequency 720.0 MHz (2:8)
Memory Type DDR3
Channels Triple
Number of threads 8
Temperature 0 40°C (103°F) [0x28] (TMPIN0)
Temperature 1 49°C (120°F) [0x31] (TMPIN1)
Temperature 2 56°C (132°F) [0x38] (TMPIN2)
Pelo visto meu i5 750 que estou montando agora vai dar uma baita diferença pro meu X3 720, hein?
encoded 1442 frames, 41.76 fps, 3899.26 kb/s
encoded 1442 frames, 41.53 fps, 3899.26 kb/s
encoded 1442 frames, 41.57 fps, 3899.26 kb/s
encoded 1442 frames, 40.85 fps, 3899.26 kb/s
encoded 1442 frames, 10.22 fps, 3971.80 kb/s
encoded 1442 frames, 10.41 fps, 3972.13 kb/s
encoded 1442 frames, 10.40 fps, 3971.07 kb/s
encoded 1442 frames, 10.46 fps, 3971.65 kb/s
System Details
Name AMD Phenom II X3 720
Codename Heka
Specification AMD Phenom(tm) II X3 720 Processor
Core Stepping RB-C2
Technology 45 nm
Core Speed 3200.3 MHz
Southbridge ATI SB600 rev. 00
Memory Type DDR2
Number of threads 2
L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size
Package Type 0x1
Temperature 0 44°C (111°F) [0x2C] (TMPIN0)
Temperature 2 25°C (76°F) [0x19] (TMPIN2)
