G
Gatuno
Guest
Não sei se alguém conhece esse benchmark. Achei bacana esse teste de desempenho para conversão de video com codec x264, parece que o teste é todo feito em cima do processador. Postem seus resultados!
download link direto: http://www.techarp.com/x264_Benchmark/hd/x264_Benchmark_HD_v3.0.rar
Precisa ter instalado também:http://sourceforge.net/projects/avisynth2/
Segue resultado do meu teste:
x264 HD BENCHMARK 3.0 RESULTS
Please do not compare it with older versions of the benchmark!
Please copy/paste everything below the line to to report your data
Results for x264.exe r1342
encoded 1442 frames, 66.07 fps, 3900.68 kb/s
encoded 1442 frames, 66.17 fps, 3901.21 kb/s
encoded 1442 frames, 65.93 fps, 3901.21 kb/s
encoded 1442 frames, 65.84 fps, 3900.68 kb/s
encoded 1442 frames, 19.58 fps, 3972.09 kb/s
encoded 1442 frames, 19.62 fps, 3970.95 kb/s
encoded 1442 frames, 19.68 fps, 3971.83 kb/s
encoded 1442 frames, 19.60 fps, 3971.84 kb/s
System Details
Name AMD Phenom II X4 945
product System Product Name
Codename Deneb
Specification AMD Phenom(tm) II X4 945 Processor
Core Stepping RB-C2
Technology 45 nm
Manufacturer (ID) ASint Technology (7F7F7F7F7F7FC100)
Stock frequency 3000 MHz
Core Speed 3013.2 MHz
FID range 5.0x - 15.0x
Northbridge ATI RD770 rev. 00
Southbridge ATI SB750 rev. 00
CAS# latency (CL) 9.0
RAS# to CAS# delay (tRCD) 9
RAS# Precharge (tRP) 9
Cycle Time (tRAS) 24
Command Rate (CR) 1T
Memory Frequency 669.6 MHz (3:10)
Memory Type DDR3
Memory Size 4096 MBytes
Channels Dual, (Unganged)
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600)
Number of processors 1
Number of threads 4
Number of threads 4 (max 4)
L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64
Package Socket AM2+ (940)
Package Type 0x1
Temperature 0 55°C (130°F) [0x37] (TMPIN0)
Temperature 1 38°C (100°F) [0x26] (TMPIN1)
Temperature 0 52°C (124°F) [0x19C] (Core #0)
Temperature 1 52°C (124°F) [0x19C] (Core #1)
Temperature 2 52°C (124°F) [0x19C] (Core #2)
Temperature 3 52°C (124°F) [0x19C] (Core #3)
System Details
Codename Deneb
Core Stepping RB-C2
Technology 45 nm
Memory Type DDR3
Number of threads 4
Package Type 0x1
