uia, parece que eu serei o primeiro a postar um resultado com 2 xeons da linha i7 (X5550 2.66ghz) trabalhando juntos! vou assinar o tópico para quanto tiver na loja rodar o teste.
O meu tá meio ruim né???
x264 HD BENCHMARK 3.0 RESULTS
Please do not compare it with older versions of the benchmark!
Please copy/paste everything below the line to to report your data
Results for x264.exe r1342
encoded 1442 frames, 67.28 fps, 3899.02 kb/s
encoded 1442 frames, 65.10 fps, 3899.02 kb/s
encoded 1442 frames, 65.88 fps, 3899.02 kb/s
encoded 1442 frames, 66.03 fps, 3899.02 kb/s
encoded 1442 frames, 25.04 fps, 3971.66 kb/s
encoded 1442 frames, 25.41 fps, 3962.69 kb/s
encoded 1442 frames, 25.39 fps, 3961.02 kb/s
encoded 1442 frames, 25.34 fps, 3959.53 kb/s
System Details
Name Intel Core i7 920
product System Product Name
Codename Bloomfield
Specification Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
Specification PC3-12800
Core Stepping D0
Technology 45 nm
Stock frequency 2666 MHz
Core Speed 2672.7 MHz
Northbridge Intel X58 rev. 12
Southbridge Intel 82801JR (ICH10R) rev. 00
CAS# latency (CL) 9.0
RAS# to CAS# delay (tRCD) 9
RAS# Precharge (tRP) 9
Cycle Time (tRAS) 24
Command Rate (CR) 2T
Command Rate 2T
Command Rate 2T
Command Rate 2T
Memory Frequency 801.8 MHz (2:12)
Memory Type DDR3
Memory Size 6144 MBytes
Channels Triple
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600)
Number of processors 1
Number of threads 8
Number of threads 8 (max 16)
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T
Package (platform ID) Socket 1366 LGA (0x1)
Temperature 0 55°C (130°F) [0x37] (SYSTIN)
Temperature 1 60°C (139°F) [0x78] (CPUTIN)
Temperature 2 14°C (56°F) [0x1B] (AUXTIN)
Temperature 0 63°C (145°F) [0x25] (Core #0)
Temperature 1 63°C (145°F) [0x25] (Core #1)
Temperature 2 65°C (148°F) [0x23] (Core #2)
Temperature 3 60°C (139°F) [0x28] (Core #3)
Seu resultado tá estranho. Chega a ficar mais baixo que meu pII..
O que pode estar de errado?
Segue a config...
i7 920 c/ cooler stock
p6t deluxe v2
memorias xms3 1600mhz com voltagem de 1.66
vga 4890 1gb xfx oc
ps: nao instalei nenhum codec na maquina
pode ser isso?
nada ver neh...
ahhh, seu proc tá em stock, agora q eu vi. Ta normal, fica tranquilo (Y)O que pode estar de errado?
Segue a config...
p6t deluxe v2
vga 4890 1gb xfx oc
pode ser isso?
nada ver neh...
____________________________________________
Pequeno UP de 3Ghz p/ 3.2Ghz
encoded 1442 frames, 68.76 fps, 3901.21 kb/s
encoded 1442 frames, 69.33 fps, 3900.68 kb/s
encoded 1442 frames, 68.05 fps, 3900.68 kb/s
encoded 1442 frames, 68.21 fps, 3900.68 kb/s
encoded 1442 frames, 20.90 fps, 3971.91 kb/s
encoded 1442 frames, 20.72 fps, 3971.34 kb/s
encoded 1442 frames, 20.86 fps, 3971.84 kb/s
encoded 1442 frames, 20.77 fps, 3971.58 kb/s
System Details
Name AMD Phenom II X4 810
Codename Deneb
Specification AMD Phenom(tm) II X4 810 Processor
Core Stepping RB-C2
Technology 45 nm
Stock frequency 2600 MHz
Core Speed 3211.5 MHz
FID range 5.0x - 13.0x
Northbridge AMD 790GX rev. 00
Southbridge ATI SB750 rev. 00
CAS# latency (CL) 5.0
RAS# to CAS# delay (tRCD) 5
RAS# Precharge (tRP) 5
Cycle Time (tRAS) 12
Memory Frequency 494.1 MHz (1:2)
Memory Type DDR2
Memory Size 4096 MBytes
Channels Dual, (Unganged)
Windows Version Microsoft Windows 7 (6.1) (Build 7600)
Number of threads 4
Number of threads 4 (max 4)
L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64
Package Socket AM2+ (940)
Package Type 0x1
Temperature 0 52°C (125°F) [0x34] (TMPIN0)
Temperature 1 31°C (87°F) [0x1F] (TMPIN1)
Temperature 0 52°C (125°F) [0x19E] (Core #0)
Temperature 1 52°C (125°F) [0x19E] (Core #1)
Temperature 2 52°C (124°F) [0x19D] (Core #2)
Temperature 3 52°C (124°F) [0x19D] (Core #3)
Nossa muito bom, parabéns, fico ótimo com 3.2GHz :yes:!
Abçs.
Valew brother pelo seu elogio.:thumbs_up
Te falar a real...to amando esse combo brother...é realmente forte. Assim que eu aprender a mexer mais com esse chipset 790GX, vou levá-lo mais longe.
Teus results tb estão bacanas...tinha dado uma olhada.
:thumbs_up
