[TÓPICO DEDICADO] AMD ZEN - Informações técnicas
G.Skill Trident Z DDR4 3600 PC4-28800 16GB 2x8GB CL16
Prepared by Thaiphoon Burner Super Blaster
MEMORY MODULE
Manufacturer : G.Skill
Part Number : F4-3600C16-8GTZ
Serial Number : 00000000h
JEDEC DIMM Label : 8GB 1Rx8 PC4-2133-UA1-11
Architecture : DDR4 SDRAM UDIMM
Speed Grade : DDR4-2133
Capacity : 8 GB (8 components)
Organization : 1024M x64 (1 rank)
Register Manufacturer : N/A
Register Model : N/A
Manufacturing Date : Undefined
Manufacturing Location : Taipei, Taiwan
Revision / Raw Card : 0000h / A1 (8 layers)
DRAM COMPONENTS
Manufacturer : Samsung
Part Number : K4A8G085WB-BCPB
Package : Standard Monolithic 78-ball FBGA
Die Density / Count : 8 Gb B-die (20 nm) / 1 die
Composition : 1024M x8 (64M x8 x 16 banks)
Clock Frequency : 1067 MHz (0,938 ns)
Minimum Timing Delays : 15-15-15-36-50
Read Latencies Supported : 16T, 15T, 14T, 13T, 12T, 11T, 10T
Supply Voltage : 1,20 V
XMP Certified : 1802 MHz / 16-16-16-36-52 / 1,35 V
XMP Extreme : Not programmed
SPD Revision : 1.1 / September 2015
XMP Revision : 2.0 / December 2013
SOURCE SPD DUMP
000 23 11 0C 02 85 21 00 08 00 60 00 03 01 03 00 00
010 00 00 08 0D F8 03 00 00 6E 6E 6E 11 08 76 F0 0A
020 20 08 00 05 00 A8 1E 2B 2E 00 78 00 14 3C 00 00
030 00 00 00 00 00 00 00 00 00 00 00 00 16 36 16 36
040 16 36 16 36 00 00 16 36 16 36 16 36 16 36 00 00
050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
070 00 00 00 00 00 83 B5 CE 00 00 00 00 E7 C2 2D 24
080 11 11 20 00 00 00 00 00 00 00 00 00 00 00 00 00
090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1C A0
100 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
110 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
120 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
140 04 CD 00 00 00 00 00 00 00 46 34 2D 33 36 30 30
150 43 31 36 2D 38 47 54 5A 00 00 00 00 00 00 80 CE
160 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
170 00 00 00 00 00 00 00 00 00 00 00 00 00 00 8E CF
180 0C 4A 05 20 00 00 00 00 00 A3 00 00 05 00 02 00
190 00 47 47 47 00 9F E6 F0 0A 20 08 00 05 00 C0 1C
1A0 28 00 00 00 00 00 00 00 00 00 00 91 FA FA FA BA
1B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Conseguiu rodar essa memória com essa velocidade somente ativando o XMP, ou precisou fazer os ajustes manualmente?
Patriot Viper 4 Series DDR4 16GB (2 x 8GB) 3000MHz PV416G300C6K
MEMORY MODULE
Manufacturer : Patriot Memory
Part Number : 3000 C16 Series
JEDEC DIMM Label : 8GB 2Rx8 PC4-2133-UB1-11
Capacity : 8 GB (16 components)
Organization : 1024M x64 (2 ranks)
Revision / Raw Card : 0001h / B1 (8 layers)
DRAM COMPONENTS
Manufacturer : Undefined
Part Number : Not determined
Die Density / Count : 4 Gb / 1 die
Composition : 512M x8 (32M x8 x 16 banks)
XMP Certified : 1499 MHz / 16-16-16-36-70 / 1,35 V
SOURCE SPD DUMP
000 23 11 0C 02 84 19 00 08 00 60 00 03 09 03 00 00
010 00 00 08 0D F8 03 00 00 6E 6E 6E 11 08 76 20 08
020 00 05 70 03 00 A8 1E 2B 2B 00 78 00 14 3C 00 00
030 00 00 00 00 00 00 00 00 00 00 00 00 15 2B 16 36
040 0B 2B 0C 36 00 00 36 15 2B 0C 2C 16 2B 0C 00 00
070 00 00 00 00 00 EC B5 CE 00 00 00 00 E7 C2 69 F6
080 11 11 21 01 00 00 00 00 00 00 00 00 00 00 00 00
0F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 74 DF
140 85 02 02 00 00 00 00 00 00 33 30 30 30 20 43 31
150 36 20 53 65 72 69 65 73 00 00 00 00 00 01 00 00
170 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
180 0C 4A 0D 20 00 00 00 00 00 A3 00 00 06 00 02 00
190 00 56 56 56 10 C0 76 20 08 00 05 70 03 00 B0 20
1A0 2B 00 00 00 00 00 00 00 00 D3 00 BA B0 B0 B0 AD
Tive que setar o SOC em 1.20v e vdimm em 1.40v
Olha, no AI overclock tuner sete para manual, o DOCP não é muito funcional. Pelo menos pra mim ele nunca fez nada de bom, seja com micron, hynix ou samsung.
Comece com frequência da Ram para 3066
Dram Voltage > 1.35V
VDDSOC VOLTAGE> entre 1.05 até 1.15V
Dentro de AMD CBS> UMC> Memory mapping Control> BankGroupSwap ON
Dentro de DRAM timing control> Geardown ON
Dentro de Extreme Tweaker:
VTTDDR Voltagem 0.670
VDDP Voltage 0.940V
DRAM boot voltage 1.35V ( Sempre igual a voltagem setada para a ram )
Depois nos subtimings, tente os timings da imagem abaixo
Na minha Bios, não tem a opção UMC, dentro de AMD CBS, tb não tem a sub-opção extreme tweaker, mas os ajustes indicados estão dentro de AI Tweaker, (Soc voltage, dram voltage), a opção Dram boot voltage nos existe.
Dito isso, já alterei todos os parâmetros conforme indicado, é seguro tentar bootar o sistema sem os ajustes da UMC e Dram boot voltage?
Edit: Os ajustes de subtimings que aparecem para mim também são bem diferentes desses da foto, o Trfc por ex. , tem o 2, 4, não tem tstaglr, entre outras diferenças...vou tentar alterar o Dram voltage, soc. voltage, e outros ajustes mais feijao com arroz, e ver o que da, se fica estável os 3066.
Edit: Nada, sistema nao iniciou...como tem outro usuário aqui com setup idêntico ao meu, cujo sistema inicia e segundo ele fica estável em D.O.C.P. perfil 3200, com freqüência setada em 3000, será que já posso presumir uma espécie de "defeito" em meu kit, ou MB?
Edit: usando DOCP, freqüência de 3066, Soc em 1,20 e Dram Voltage em 1,40, agora estou há quase 1 hora jogando The Witcher 3 sem instabilidade! Fiz benchs do 3d Mark, Rise of Tomb Raider e GOW sem bugs ou reboots...é seguro usar assim no dia a dia @VultureX ?
Se sim, já tendo passado por essa parte da memória RAM, pode me instruir no Ryzen Master, como proceder para ter pelo menos 3700 Mhz estáveis?
Sete somente os subtimings que existem na bios, aqui também não tem todos.
Voltagem do SoC meio alta, tente baixar pra 1.15V ou 1.10V. Talvez também consiga abaixar a voltagem da ram para 1.38V.
Não é defeito, acima e 2666MHz já é considerado overclock na plataforma e funciona assim mesmo, independente da memória ser 3000 ou 4000MHz. O controlador de memória está no processador então se você der azar com o CPU não adianta trocar a placa mãe ou memória.
Para conseguir 3200MHz terá que setar tudo manualmente e dedicar um tempo pois nas asus é possivel alcançar frequencias muito altas mas invariavelmente nao eh plug and play - Eu tenho a crosshair hero e nunca nenhum DOCP funcionou de maneira decente para mim em nenhuma das memórias que tive, nem com as B-die. Isso que você fez é o ideal, eu apenas selecionaria o DOCP 2666 e aumentaria a frequencia a partir desse perfil em Memory Frequency.
Utilize a opção de salvar o perfil de overclock na bios em Tools. É muito útil pois caso você tenha que resetar a bios não precisa descobrir e setar tudo de novo, é só carregar o perfil funcional com as configurações que foram salvas.
Você vai conseguir 3.7GHz com vcore setado entre 1.17V e 1.25V, claro se conseguir estabilidade com 1.15V melhor ainda.
Em algum lugar, possivelmente dentro do subtimings
ProcODT> 80 mOhms
Em Ai Tweaker
VDDCR CPU Voltage > Manual
VDDCR CPU Voltage Override 1.2V
VDDCR SOC Voltage> Manual
VDDCR SOC Voltage Override 1.15V
DRAM Voltage> 1.38
VTTDDR Voltage 0.690V ( este sempre metada da votlagem da RAM Exemplo: 0.675V se a ram estiver em 1.35V, 0.690V se a RAM estiver em 1.38V)
Em Digi+ VRM
VDDCR Cpu Load Line Calibration> Level 3
VDDCR Power Phase Control> Optimized
VDDCR SOC Load Line Calibration> Level 1
Sobre o BankGroupSwap e Geardown, se a bios for agesa 1.0.0.6 eles devem existir em algum lugar. São importantes para estabilidade, principalmente com memórias Hynix.
@VultureX se viu a imagem do Thyphoon no meu post. la estão todos os dados que consegui.
ProcODT> 80 mOhms
Em Ai Tweaker
DRAM Voltage> 1.38
Em Digi+ VRM
BankGroupSwap não achei mesmo, mas Gear Down tem e o proprio ajuste DOCP já o muda para enabled.
Vou tentar por segurança os 1,38 volts e 1.15 no SOC tb, mas já estou quase me conformando com os 3.066, devido não encontrar esse ajuste do BankGroupSwap, e a relativa disparidade entre os meus ajustes disponiveis de subtimings e os da imagem ilustrativa. Como os 3066 estão estáveis, vou me focar no over da CPU agora, apesar de serem coisas meio que intrínsecas...
Quanto a questão da BIOS, estou com essa: PRIME X370-PRO BIOS 0805 (Update AGESA to 1.0.0.6a).
Já as orientações do CPU, eu entendi, porém, depois que eu fizer esses ajustes, a ideia é fazer a alteração do Clock em si, no Ryzen Master, certo? E estando lá, apenas alterar direto o clock para 3700, não sendo necessário mexer em mais nada?
Edit 1: O usuario com setup identico ao meu, a que me referi, me comunicou que o sistema dele subiu estavel para 3066 (via DOCP) e o proc para 3700 (direto no Ryzen Master), sem refinar nenhum parâmetro manualmente, é o @marcoguidis , devemos atribuir isso unicamente a loteria do silício?
@VultureX olá meu caro, saberia me dizer se essas memorias BLE8G4D32BEEAK são single rank? >SITE< esta dificil achar algum site que confirme, mas o pouco que encontrei diz ser chip Micron e me fez concluir que seja single rank, nossa como está dificil achar uma memoria pro ryzen, o bichinho tá aqui na prateleira só me olhando *-*
Do contrario vou partir pra uma corsair LPX 2x8 CMK16GX4M2B3200C16
Obrigado!
Oi Marcola, desculpa.
Você pode utilizar as mesmas dicas que postei para o colega acima. Se precisar de um auxilio para alcançar estabilidade é só pedir.
Obrigado @VultureX mas no meu caso preciso mesmo de ajuda pois essa bios é nova para mim e nao sei onde exatamente colocar o que, tipo nao sei tudo que tenho que mexer e ir na tentiva e erro.
Olá.
Eu não acredito em Ryzen master. Quanto ao DOCP, na Prime todo overclock de memória se inicia obrigatoriamente por ele, até onde eu sei não tem outra opção. Tem gente que conseguiu 4.1GHz no processador com apenas 1.35V, eu não consegui, mesmo tendo um setup "idêntico". É loteria mesmo e alguns vão necessitar de mais voltagem na ram, mais voltagem no soc, mais voltagem na CPU, maior tempo de CAS e assim por diante.
Obrigado!
Olá.
Essa crucial é Dual Rank, infelizmente. Certifique-se de pegar a Versão v5.39 dessa corsair.
[]'s
Marcola.
Eu não tenho MSI mas a nomeclatura é meio que universal. Você pode tentar o Ryzen master ou dê uma boa lida no post da primeira página, na aba que fala de overclock.
Alguem teria uma opinião a respeito da X370-F da Asus?
Minha Crosshair aparentemente tá com problema.. Comprei no PY a menos de 1 mês, chegou esses dias..
Vi agora no PY essa Strix X370-F, não tem ela na tabela de fases, não achei a Crosshair VI Hero em loja alguma..
As principais diferenças são:
A X370 Strix vs C6H:
Strix tem menos portas USB.
Não tem LED de post. ( Componente obrigatório em qualquer placa desse valor. Que cagada )
Não tem botões na placa de power, reset, safe modeetc.
Não tem botão no I/O de bios flashback, não tem botão de reset da bios.
Não tem conectores para leitura da vazão e temperaturas das bombas.
Não tem entrada para ROG extension.
Menos software de valor agregado.
Na minha opinião a Strix é um meio termo entre a Prime X370 e a C6H.
Adicionada a tabela de VRM ;)
Boa @VultureX quanta eficiência kkkkk
Poxa os VRMs dela são bons ein, na tabela tá tudo verdinho kkk
Então, na sua opinião ela vale a pena?
A loja Visão VIP me disse que não tem previsão de quando a placa Crosshair vá chegar, disse que o fornecedor do PY tá sem..
Aguardo 1 mês mais ou menos sem mobo ou pego essa Strix F?
Uma coisa que me pesa muito é o bios flashback, morro de medo de ocorrer o que aconteceu com sua Taichi..
To sem saber se pego ela ou não...
Ah e os botões nela são muito úteis, e também o conector dedicado a bomba do water, agora que comprei meu primeiro water, apesar da bomba na vel max 2400 nem barulho faz.. e nem via ela abaixar dos 2400, enfim não sei a vantagem do conector dedicado..
Belo trabalho! Sua tabela ajuda demais na escolha do usuário. De acordo com sua tabela, a MSI X370 SLI PLUS consegue segurar um 1700X/1800X numa boa em stock... Compre uma dessas semana passada; chegou sexta. Como meu quarto é bem esquentadinho no verão, fico com receio por causa da qualidade dos componentes utilizados na mesma. Na sua opinião, seria melhor devolver e comprar outra placa?
Vi um review, onde a SLI Plus, bateu nos 70° graus em um bancada aberta! Fico imaginando isso dentro de um gabinete... Obrigado pelo serviço "mastigado" pra nós ai.
Pois é, nesse contexto ela empata com a Taichi mas no resto é arrebentada. Levando em consideração o custo eu iria de C6H, Taichi ou Fatality - o VRM da strix é bom - o da Taichi é melhor, O som da Strix é bom - o da Taichi é melhor ( suporta Dolby DTS ) - a Strix é capada de USB - A C6H tem USB pra dar e vender . Se asus tivesse acrescentado ao menos o led de diagnótisco mas até isso ela capou. Se me perguntarem qual é exatamente o apelo da Strix dentro da sua faixa de preço eu responderia que é puramente psicológico e visual.
Na minha só deu brick pq eu tive SMT desabilitado + estado de hibernação.
Então, a tabela reflete um cenário onde a temperatura ambiente é de 25ºC. Na SLI até R7 3.8GHz e Vcore próximo de 1.3V a placa deve se manter com o VRM em temperaturas aceitáveis.
Pois é, nesse contexto ela empata com a Taichi mas no resto é arrebentada. Levando em consideração o custo eu iria de C6H, Taichi ou Fatality - o VRM da strix é bom - o da Taichi é melhor, O som da Strix é bom - o da Taichi é melhor ( suporta Dolby DTS ) - a Strix é capada de USB - A Taichi tem USB pra dar e vender . Se asus tivesse acrescentado ao menos o led de diagnótisco mas até isso ela capou. Se me perguntarem qual é exatamente o apelo da Strix dentro da sua faixa de preço eu responderia que é puramente psicológico e visual.
Então vou de C6H, esperar o estoque dela.voltar e aquetar o faixo, é o tempo que minhas memos HyperX chegam pra gnt passar o arquivo spd e ver se elas vão a 3200 kkkk
Tava com uma emprestada e tava nos 3200 na C6H
Enfim, devolvo a emprestada e já espero as minhas..
Quanto a passar o arquivo spd de bios na memoria, tem algum perigo? Já que vamos desbloquear frequencias capadas de fabrica.
A sua comparação da Strix em relação a Taichi foi muito boa, se fosse a C6H vs Taichi qual seria o cenario? A taichi tem disponivel na loja que peguei a C6H e é até mais barata.
A Taichi te dá o feeling de uma placa mais sólida, dá boot mais rápido, entra na bios mais rápido e com ela eu consegui de alguma maneira overclock mais alto ( 70MHz a mais ) e estável com meu CPU. As alterações do bclk nela também se mostraram mais estáveis, o LLC dela é melhor, ela tem dois slots M.2, VRM dela é de altíssima qualidade e tem capacidade para suportar qualquer lançamento que venha a sair para esta plataforma. O chip de audio da Taichi é igual ao da C6H mas sem o DAC dedicado, por outro lado ela tem suporte a DTS connect que para mim é importante. Sim, a Taichi tem um slot m.2 a mais nela que é justamente onde tem o módulo Wifi.
A C6H tem um aúdio bem desenvolvido e com DAC legal, só falta a ASUS atualizar o driver pois DTS não está funcionando com o driver deles asus dropou suporte a DTS, uma vergonha... portas USB pra dar e vender, o VRM embora num nível abaixo da Taichi é de qualidade e competente. A C6H é uma placa mais bonita, bem construída e boa de benchmark.
O suporte da asus é melhor e a placa tem o recurso de recuperação da bios ( flashback ) operante.
Hoje, com a versão final da bios Agesa 1.0.0.6 eu estou mais satisfeito com a C6H mas achei abominável o bait n switch no DTS e ainda confesso ter saudades da Taichi.
Como sempre, muitissimo explicado.
Obrigado @VultureX
Vou aguardar a chega da Crosshair, a Taichi pelo visto é uma bela placa, m2 infelizmente eu ainda não tenho, comprei um 850Evo de 250gb, um m2 penso no futuro, então por enquanto o slot extra fica como bonus.
A Taichi é muito bem falada em varios reviews que vejo, pretendo 3,8Ghz Diarios dinamicos que a frequencia suba e desça sem ficar constante e 3200 na memoria, acho que a C6H deve me atender muito bem.
Muito obrigado, abraço e boa noite! :D
Comunico que obtive SUCESSO:notbad:, estava fazendo tudo ERRADO, tentando fazer o Over apenas pelo carnicento Ryzen Master:mr:, 100% de falha em todas as tentativas, na primeira tentativa direto pelo multiplicador da Bios, voi-la, 3700 MHZ estaveis no 3d Mark, Memos em @3066 com Dram 1,40 (ainda vou tentar diminuir) Vcore da Cpu em auto,testei 3d Mark e benchs do CPUZ, hoje testo em gameplays de The Witcher 3 e Gears of War, (não curto Prime ou qq outro Bench extremo distante do uso real), feliz demais em se aproximar dos 16000 no 3d Mark Fire Stryke.
Deixei alguns parâmetros de acordo com o que o @VultureX havia me indicado, mais tarde de casa coloco mais detalhes, porem ficou uma duvida:
Ao tentar deixar VDDCR CPU Voltage > Manual VDDCR CPU Voltage Override 1.2V , usando esse ou valores maiores, vi que fica fixa a voltagem, assim como o multiplicador, é assim mesmo que é para ficar, não é possível incrementar a maxima, deixando o |Vcore dinamico? Edit: @VultureX , vi que o Offset serve exatamente para isso, aumentar ou diminuir as maximas (ou minimas e mcaso de undervolt), vc não recomendou essa forma por risco de instabilidade?
Nos testes fracassados que fiz com o Ryzen Master cheguei a deixar 1,40 (!!!), numa das vezes iniciei o sistema com o clock stock e fiz alguns testes, vi que esquentou bastante, cheguei a ver bater 70 graus em alguns minutos de stress no CPU-Z, porem no ajuste atual com vcore dinamico/stock, nao passa de 60, cooler box, sem pasta especial, feliz demais estou, hoje devo tentar subir mais um pouco, mas qualquer instabilidade que aconteça deixarei assim nos 3700 mesmo, pois se o Vcore manual ficar fixo, ai já não acho vantajoso, já que o clock já fica fixo por conta do multiplicador fixado na Bios.
Quanto ao fato do multiplicador ficar travado no valor setado na Bios, isso me desagradava bastante mas depois que operei o sistema, vi que embora o valor do clock fique setado fixo em todos os núcleos, o Windows faz um gerenciamento inteligente, então direto fica o uso próximo de zero na maioria deles, a voltagem caem também ,com isso vi que as temperaturas ficam próximas a do sistema em stock, portanto quem está tendo problemas com o Ryzen master tambem, pelo menos experimente alterar o multiplicador na Bios (no ajuste de target, lá ja informa que alguns parâmetros serão alterados automaticamente para garantir a estabilidade.
Por hora é isso, desculpem algum erro de concordância, gramatical, falta de detalhes, escrevendo aqui do trampo.
Pessoal, deixando aqui um poquinho dos testes que estou fazendo no R1700X abastecendo uma GTX 1080Ti Asus ROG Strix OC.
No caso ai é um grafico mostrando a diferença de perdormance usando RAM 2133MHz vs RAM 2666MHz, hoje começo os testes com frequencia 3000MHz e se der tempo também a 3200MHz finalizando com 3600MHz ainda essa semana.
Prezados, poderiam me dizer qual placa eu devo pegar entre uma ASUS B350 PLUS e uma GIGABYTE GA AB350M Gaming 3? Pela tabela, as duas tem mais ou menos o mesmo desempenho, e pretendo deixar o processador (ryzen7) em 3.7 com o stock cooler, a asus pelo que vi tem um som bem inferior a gigabyte...
Se é nessas condições aí, vai de Gaming 3 e usufrua do som melhor e do dual bios. Trate de pegar DRAM's 3000/3200 do QVL da placa - ou Ss B-die ao menos - e seja feliz.
Não estava conseguindo ver a tabela adequadamente no tópico, então peguei o link da tabela para visualizar diretamente no navegador e...
:apelo::bwahaha:
Valeu!
hahahaha
Aqui consigo ver de boas
https :// docs.google.com/spreadsheets/d/1PxK8tx2IrjRxtWQPlnZRGrYTEk1i999Kwmk3zLpBfzc/edit#gid=994219079
copia sem os espaços
