Mamilos polêmicos....
Sim, existe uma etiqueta entre os praticantes de PvP por "esporte", digamos, assim.
Comprimento, não usar estus/humanity, usar buffering antes da luta.
Exitem lugares específicos e SL específicos
Exemplo: kiln of first flame em geral é PvP de SL alto (125)
Duel and Invasion Etiquette
There are no official rules. As an invader, it is your job to kill a host as you see fit. If you're invaded, you may likewise attempt to kill or evade the invader as you see fit. However, players generally distinguish "no rules" PvP as a separate way of playing from "dueling". In a duel, there are usually several unwritten but consistent rules:
Do not heal using Estus or Humanity
Do not retreat from the area you're fighting in
Do not gank the other player (ganging up on them in a 2v1 or 3v1 situation)
Allow the other player to cast a buff, consume an item, or complete a gesture at the beginning of the encounter (don't attack too soon)
The general idea behind a duel is to have a fair fight. Different communities will often impose stricter rules, where certain combinations of spells, gear, and attack methods are disallowed. However, it is highly recommended to NOT expect strangers to impose a lot of limitations on themselves. The more rules a player would like to see enacted in a duel, the more they should seek out pre-arranged matches where the rules are agreed upon in advance. You can never assume that a stranger will know or care to abide by the same ruleset you may be wishing for.
Because there is no in-game mechanic for distinguishing the type of encounter you will have, it is best to keep an open mind and expect differing behavior in different situations. Generally, players looking for consensual PvP will likely lean towards a dueling-style of play, while random invaders may lean towards a "no rules" style of play. But neither are a given. Perhaps most importantly, if you're a host trying to clear an area, NEVER expect an invader to be respectful of your mission. Many will attempt to defeat you ruthlessly, which is perfectly in the spirit of the game. Similarly, a host that is trying to beat a level has almost no tactics at their disposal that can be considered unfair, including ganging up on an invader with a group of friends.
Como dito antes, foi uma cultura criada pela comunidade aos poucos.
Mas é mais para "duelos" (duelo = luta "justa", ver quem ganha).
São regras tácitas e consensuais.
Todo mundo obedece? Não.
Todo invasor quer duelar justamente?Não
Tenho que obedecer? Você quem decide.
Bem vindo ao complexo mundo em sociedade. Nem todo mundo segue as regras (Huesil?
![HUE :br: :br:](/styles/dark_responsive/xenforo/menes/br.png)
Lei de Gerson FTW), mas vejam que lugares onde há mais respeito ao próximo e às regras (
se boas!) são melhores de se viver (Noruega, Finlândia, Suécia, etc)
(que diabos isso tem a ver com o jogo?)
Ninguém é obrigado a respeitar, mas acho que quanto mais essa etiqueta se espalha, mais agradável fica o jogo.
A pessoa pode usar o red soap stone para deixar uma marca de summon só pra duelos.
Em geral, se eu vejo que a pessoa quer "duelar", eu duelo (seguindo a etiqueta)
Mas se é só um cara tentando invadir pra ferrar meu jogo, eu tb me defendo do jeito que posso.
