Tenho uma duvida em relação ao destiny, eu tenho o 2 padrão, aquele que veio com a plus porem queria saber se tem algum season pass que engloba tudo que foi lançado , alguem sabe me dizer qual?
Finishers
- Finisher System added. Press the finisher button to finish critically wounded combatants.
SandboxPvE Damage Numbers DisplayGoal: To provide players with useful and legible feedback for damage dealt to enemy combatants across many years of Power progression.
PvE Difficulty TuningGoals: Widen the sweet spot where fighting higher-level combatants provides a fun, challenging, and rewarding combat experience for a more enjoyable Power climb. Also, allow players looking for even greater challenges to confront much higher-level enemies.
- Displayed damage numbers for damage dealt to non-Guardian enemy combatants are crunched
- Damage dealt is displayed using fewer digits to enhance readability of damage output
- Occurrences of displayed damage getting capped at 999,999 should be significantly reduced or eliminated
- The exponential curve used to calculate damage numbers for display is replaced with a new linear curve that is built to last for many years
- As players grow in Power, displayed damage numbers increase at a much more measured pace than previously
- This is a UI update only; player damage output, whether measured as hits to kill, time to kill, or DPS, remains unchanged by this update
- Combatants that are 10–40 levels higher take less time to kill and deal less damage
- Higher-level combatants continue to increase in difficulty up to 100 Power levels above the player
- When enemies are 100 Power levels or higher above the player, they are immune to damage
- Nameplate icons on higher-level combatants have been updated to reflect these changes
- These changes affect only higher-level combatants; the at-level or over-level experience remains unchanged
NerfsNightstalker Way of the Pathfinder (Bottom)Goal: We want to lean into the fantasy of a speedy disruptor. Pathfinders need more tools to scout the battlefield and a skill based way to engage with that gameplay more often. We should reward this scouting and battlefield control gameplay, executed well, with more opportunities to do the same. At the same time shadow shot needed some quality of life improvements for long standing frustrations.Vanish: Smoke bomb grants invisibility to allies
Provision: Killing tethered enemies creates super orbs and increases agility, armor, and recovery for allies
- Gives 1 stack of Heart of the Pack (newly revamped) to all allies hit
- Grants +34 to armor, recovery, and agility
- Gives weapon reload speed and handling
- Max 3 stacks
- Increased invisibility duration from 7 > 8 seconds
Moebius Quiver: Fire super multiple times and deals massive damage to tethered targets
- New Perk (old perk benefits moved to be part of Mobius Quiver)
- Damaging enemies with your grenades reduces the cooldown of your smoke bomb (6% per damage tick)
- Making allies invis gives you grenade energy (17.5% per ally)
Shadowshot Super (Top and Bottom path)
- Added the old Provision perk to naturally be part of Mobius Quiver
- Killing tethered enemies creates super orbs and grants stacks of Heart of the Pack for allies
- Expanded the range of Heart of the Pack from 20 > 30 meters.
Sentinel Code of the Protector (Top)Goal: This path is the main support role for Titans and focuses heavily on melee kills while staying near allies. We want to focus more heavily on buffing allies so that players care about the timing of their buff usage. With a loop which allows players to get their melee energy back more quickly this will be a more engaging path to play. Additionally, Ward of Dawn is currently not up to snuff, and needs a buff that ties in to the fantasy of buffing allies.Defensive Strike: Melee ability that creates an overshield for nearby allies
- Damage increased from 150 > 250
- One shot kill in PvP
- Improved tether accuracy near obstacles
- Suppress on hit is more consistent
Rallying Force: Melee kills heal nearby allies
- All kills while the overshield is active grant melee energy for the player with the shield (works for all allies you grant a shield to)
- This is based upon enemy threat level from 5% (minors) to 25% (players and bosses)
Ward of Dawn: Alternate super that creates a shield bubble
- Heal buffed from 10 health and 10 shields to 10 health and 20 shields (50% increase)
Sentinel Code of the Aggressor (Bottom)Shield Bash: Shoulder charge that disorients nearby enemies
- Increase ward health versus supers
- Most supers will require the whole thing to be dumped on the ward to destroy it but will (usually) not kill the players inside
- Ward grants weapons of light buff when passing through it (35% weapon damage for 15 seconds)
- Grants an additional super orb (3)
- Auto-generated orbs now grant the same amount of super energy as regular super orbs (previously the orbs gave less super energy on par with masterwork orbs)
Voidwalker Attunement of Hunger (Bottom)Vortex: Nova Bomb leaves behind a damaging AoE pool
- Now suppresses the target hit and any enemy within 2 meters (have to be basically right next to them)
Dawnblade Attunement of GraceWell of Radiance: Alternate super that creates a healing/buffing field for allies
- Initial explosion damage increased 15%
- Lingering damage increased 15%
Ability and Armor General FixesNightstalker Way of the Trapper (Top)Shadowshot:Fires an arrow that damages enemies and debuffs enemies nearby
Nightstalker Way of the Wraith (Middle)Flawless Execution:Headshot kills while crouched grant invisibility and truesight
- Damage sharing for the Nightstalker player specifically reduced from 100% to 50%
- Now all allied players have 50% damage sharing on tether
Shattering Strike: After performing a Flawless Execution, your melee attacks have a longer lunge range and weaken enemies
- Truesight now lasts 3 seconds (down from 9)
Instant ReloadingGoal: In the beginning, Lunafactions and Rally Barricade did exist, but they were clunky to use. They still had dramatic impact on gameplay even in that state, but eventually we decided to make their effects easier to handle. The problems they introduced always existed in the game, but over time these have become magnified due to new abilities, perks, and weapons introduced into the Destiny 2 sandbox. The impact of something that takes all reloading out of the equation means that other perks or effects like the Hunter’s Marksman Dodge or the Sealed Ahamkara’s Grasps can simply fall to the wayside – Even swords take a hit in comparison, being one of the few weapons that naturally never needs to reload.
- Advanced warning: When we made the change to Flawless Execution this also unintentionally nerfed this ability to only last 3 seconds (it was directly tied to the truesight). We have prepared a fix for the 4.6.1 patch to restore the weaken and lunge range increase to last the entire 9 seconds regardless of truesight and invisibility status.
Reloading is one of those mechanics that are simple, but have wide ranging consequences. Because the effect on gameplay of removing reloading is inversely proportional to the size of your weapon’s magazine and how slow your general reload animations are, weapons like Rocket Launchers and Shotguns can benefit greatly compared to other weapons. This, alongside the increase in general access to damage bonus effects like Well of Radiance left us with the decision to remove this effect from these two sources, as they were causing things to quickly snowball out of control.
Titan Rally Barricade
Warlock Rift/Well of Radiance
- This ability now provides a large increase to reload speed for the duration of the effect
- This ability no longer automatically reloads your weapons from reserves
Super Energy RegenerationGoal: These changes will reduce the speed with which players are able to earn their super which supports difficulty and reduces the current ability to trivialize certain content through excessively chaining supers. Systemically, we want to reduce base sources of supers on a large macro scale without diminishing the feeling that your actions are gaining you a worthwhile energy boost. By reducing the speed at which you gain super we can make mods and perks feel more worthwhile. We still want it to feel like you can make meaningful progress not only through normal play but by augmenting super energy through teamwork, class choices, gear, and skillful play.
- Lunafaction Boots now provides a large increase to reload speed for the duration of Well of Radiance
- This exotic no longer automatically reloads your weapons from reserves
New Energy Granted by Super Orbs:
Damage MultipliersGoal: At Destiny 2 launch, damage buffs were fairly sparse – There was Empowering Rift for a small increase, and you could combine it with a weakening effect such as Hammer Strike, but very little else. As time has gone on, we introduced Well of Radiance, Weapons of Light, Guiding Flame, Frontal Assault, etc, and combining these effects has resulted in player damage output far beyond what was previously available. Even with just a small amount of them, a player can go from 1x damage to 3x and beyond, causing there to be an extremely large gap between standard player output and theoretical output.
- Super Orb: 7.143% (50% reduction)
- Masterwork Orb: 2.5% (50% reduction)
- Kills: (25% reduction)
- Minor: 0.6%
- Elite: 0.96%
- Mini-boss: 1.8%
- Boss: 3%
- Player: 3%
- Assists: (25% reduction)
- Minor: 0.3%
- Elite: 0.48%
- Mini-boss: 0.9%
- Boss: 1.5%
- Player: 1.5%
By preventing the larger effects from stacking, we are able to keep each of them around without having to do something in response like raise boss health to compensate for these tactics, as well as create more of them. As an example, Lumina would not have been created in world where the damage bonus effect of Noble Rounds stacked with other damage effects, and these changes are simply an extension along those same lines.
While the weakening effects never stacked, we also took a look at them and adjusted their values as many of our more powerful units would simply evaporate when touched by one of them, but we compensated for that in other ways, such as either extending the duration of the effect or in the case of Shadowshot, making it affect power weapons.
Player Damage Buffs
Enemy Debuffs (Weakened)
- Player Bonuses
- Bonus damage effects that apply to all of a player's weapons simultaneously no longer stack multiplicatively. The highest applicable bonus will be used instead
- This does not affect single weapon buffs such as Rampage, Kill Clip, or exotic weapons that increase their own damage. These will still stack multiplicatively.
- Buffs that provide bonus damage will still exist simultaneously on the player, so in the event that the one with the highest multiplier wears off the next highest will be used instead.
- This change affects the following weapons/abilities (Empowering Rift, Frontal Assault, Guiding Flame, Sun Warrior, Inertia Override, Well of Radiance, Lumina/Noble Rounds, Weapons of Light)
- Notable exceptions: Vengeance (One Eyed Mask)
- Frontal Assault
- Bonus damage is now +20% (Previously +25%)
- Sun Warrior
- Well of Radiance
- Bonus damage is now +25% (Previously +35%)
- Weapons of Light
- Bonus damage is now +35% (Previously +25%)
Reduced Super Damage ResistanceGoal: Since the launch of Destiny 2 we have slowly introduced buffs to supers, especially roaming supers. While we believe supers should be powerful they should not be mindless. We want supers to be more risky in both PvE and PvP. We want players to think about positioning and timing more. Not so long ago we experimented with Spectral Blades by lowering the damage resistance substantially. These changes were generally well received and improved the experience of the super for both the person running it and the person who was running from it. In PvE players shouldn’t feel like their super makes them invulnerable and casting one should call for situational strategic thinking. In PvP players need to feel like they can challenge a super and that with skillful play there’s a chance they can beat it.
- Shadowshot
- Incoming PvE damage is now +30% (Previously +35%)
- Incoming PvP damage is now +50% (Previously +55%)
- This effect no longer excludes power weapons
- Tractor Cannon (Repulsor Force)
- Incoming PvE damage is now +30% for all elements (Previously +33%/50% for Non-Void/Void damage respectively)
- Incoming PvP damage is now +50% for all elements (Previously +33%/50% for Non-Void/Void damage respectively)
- Hammer Strike
- Incoming PvE damage is now +30% (Previously +50%)
- Duration increased from 6 to 10 seconds in PvE
- Shattering Strike
Low- 54% → 49%
- Super Damage Resistance removed from masterwork armor
- Inherent Super Damage Resistance lowered by category (see below)
Medium - 56% → 51%
- Nova Warp
- Thunder Crash
- Blade Barrage
- Nova Bomb
- Well of Radiance
High - 60% → 53%
- Hammer of Sol
- Daybreak
Other (unchanged)
- Fist of Havok
- Burning Maul
- Sentinel Shield
- Arc Staff
- Arc Lightning
- Shadowshot
- Spectral Blades - 52% / 54.4%
- Golden Gun - 0%
- Chaos Reach - 40%
Exotics
Perks
- Sweet Business
- Increased magazine size from 100 to 150.
- Increased PvE damage by 15%.
- High Caliber rounds have been replaced with Armor Piercing rounds.
- Damage changed to 15/21.2 base/precision (Previously 13.21/21.14)
- This weapon no longer requires you to be firing when you pick up ammo to have it automatically reload.
- Graviton Lance
- PvE damage increased by 30%
- Sunshot
- Increased magazine size to 12
- Vigilance Wing
- PvE damage increased by 25%
- Crimson
- Damage changed to 19/30.5 base/precision (Previously 13.76/24.75)
- Fixed an issue that was causing this weapon to deal higher flinch than intended
- Merciless
- Fixed the missing aim assist stat for this weapon
- Ace of Spades
- Memento Mori's damage bonus is now affected by range falloff
- Lumina
- Noble Rounds should apply their buff to allies more reliably now
- The Colony
- "Serve the Colony" now functions as Auto Loading Holster does
- Reduced the effectiveness of the following perks in PvE: (Added missing note 10/1)
- Rampage, Kill Clip, Swashbuckler, Multi-Kill Clip, Desperado, Surrounded, Master of Arms, Onslaught
- In general, these perks use the same damage multipliers for PvE that they did in PvP
- The change to Rampage does not affect The Huckleberry
- Onslaught and Desperado now change bullet impact values while active in PvE
- Surrounded no longer multiplies precision damage on top of base damage, as it was benefiting some weapon types more than others as a result
- Subsistence
- Reduced the impact of this perk on total reserves
- Ricochet Rounds
- Removed the hidden bonus to damage falloff
- Swashbuckler
- Perk now activates when getting a kill with Ball Lightning
- Grave Robber
- Perk now activates when getting a kill with ranged melee abilities (ie: Ball Lightning, Explosive Knife)
- One-Two Punch
- Reduced the effectiveness of stacking One-Two Punch and Cross Counter (Liar's Handshake)
- Ex: Players won’t be able to defeat Riven in less than three seconds after Shadowkeep launches using the combo of One-Two Punch and Liar's Handshake, but we know many of you will try other builds… and potentially even succeed.
Player Identity SystemsWeapon General Fixes
- Fixed an issue where AI combatants in Gambit based activities were using PvP values instead of PvE values
- Fixed an issue on Jade Rabbit where parts of the ornament were appearing on the original weapon art
- Fixed an issue where masterworked weapons would sometimes spawn a large amount of orbs off a single kill
- Fixed an issue where killing Vex Harpies with precision damage from Outbreak Perfected wasn't spawning Nanites as expected
- Added missing Thunderlord Killfeed and Obituary icons
- Infusing Thunderlord now correctly requires a destination material (EDZ Dusklight Shards)
Character Stats
- Discipline, Intellect, and Strength stats return from the original Destiny game
- Your Discipline determines your grenade recharge rate
- Your Intellect determines you super recharge rate
- Your Strength determines your melee ability recharge rate
- All stats now go from 0 to 100
- For Discipline, Intellect, and Strength, a stat of 30 is the equivalent recharge rate to the pre-Shadowkeep recharge rate with no mods affecting that recharge rate applied
- A stat of 100 is the equivalent of having 5 of the appropriate recharge rate-affecting mod applied
- Each piece of armor now provides you with contributions to each of your six stats
- Armor that drops in the world, from engrams, and activity rewards have randomized stats
Armor 2.0
- All exotic and legendary armor will drop to use the new armor system
- Armor 2.0 versions of exotic armor pieces can be pulled from your Collection provided you have collected that exotic
- All Armor 2.0 armor pieces have an energy type (Arc, Solar, Void) and an energy capacity
- Energy capacity can be upgraded by spending currencies and materials, to a maximum of 10
- Armor with 10 energy is considered to be masterworked and provides a +2 bonus to all six character stats
- All armor mods have an energy cost and an energy type (Arc, Solar, Void, or Any)
- Arc, Solar, and Void mods can only be socketed into armor of the matching energy type; mods with an Any energy cost can be socketed into any armor
- Each piece of armor comes with multiple armor mod sockets, into which your mods can be applied
- A socketed armor mod occupies an amount of the armor's energy capacity equal to the mod's energy cost; you must have enough armor energy available to be able to socket a mod
- Armor mods are no longer consumable, and are instead unlocked and resuable across all applicable armor pieces once acquired
- Armor mods can be acquired from gunsmith packages, direct purchase from the gunsmith, world engrams, and pinnacle activity engrams
- Armor 2.0 mods and pre-Armor 2.0 armor perks do not stack
Masterworks
- Fully masterworked armor no longer provide bonus damage reduction when using your super
Exotics
Economy
- Ttian
- Actium War Rig
- Now works with heavy machine guns
- Warlock
- Lunafaction Boots
- Removed the effect of automatically reloading allies' weapons while they occupy your rift
- This exotic armor piece now grants a reload speed bonus for allies occupying your rifts
Director
- Playlists Removed:
- Quickplay
- Competitive
- Playlists Added:
- Control 6v6
- 6v6 Rotator
- 4v4 Rotator
- Survival 3v3
- Survival 3v3 Freelancer (solo queue)
- Crucible Labs: Elimination 3v3
- Classic Mix 6v6 (connection-based matchmaking)
- Removed:
- Dead Cliffs
- Retribution
- Solitude
- Legion's Gulch
- Added
- Widow’s Court
- Twilight Gap
- Fragment
ChallengesRanks
Matchmaking:
- Players cannot lose Glory ranks below Fabled I
- Losing a match reduces Glory streak by 2 instead of resetting
- Losing a match reduces Valor or Infamy streak by 1 instead of resetting
- Glory adjusts more quickly to match player skill
General
- Skill-matching algorithm adjusted to allow for greater variance of matches
- Power Ammo crates are now shared in all 6v6 modes
- Added physics to the Pacifica Crucible map to prevent players from being able to navigate into an unfairly advantageous position in the environment
15 dias de atraso, 24 horas de manutenção do servidor e finalmente no dia do lançamento da erro dizendo que o jogo tá lotado
Sério mesmo que lançaram uma versão grátis pra entupir de gente e quem pagou se ferra?
Demorou mas arrumaram a bagunça no servidor, joguei um pouco e as mudanças no jogo foram colossais.
A pergunta é: PARA MELHOR OU PARA PIOR?Demorou mas arrumaram a bagunça no servidor, joguei um pouco e as mudanças no jogo foram colossais.
Vi um tópico no ResetEra dizendo que precisa de Plus para jogar PS4. Alguém saberia confirmar?
Pois estou baixando o jogo aqui e não assino Plus mais.
Aff não acredito que vou ser obrigado a assinar essa porcaria de novoPerguntei para um amigo aqui, ele me falou que precisa sim!
Faz tempo que não jogo Destiny, mas precisava de plus pra jogar Crisol e Assaltos. Nem sei se já mudou essa bagaça. Campanha eu jogava de boa sem plus, inclusive via uma galera online nas missões.Aff não acredito que vou ser obrigado a assinar essa porcaria de novo
Comecei a jogar a campanha ontem e realmente não precisa da Plus. Vou ir jogando assim mesmo. Se quiser depois jogar com a galera, vou ser obrigado a assinar mesmo.Faz tempo que não jogo Destiny, mas precisava de plus pra jogar Crisol e Assaltos. Nem sei se já mudou essa bagaça. Campanha eu jogava de boa sem plus, inclusive via uma galera online nas missões.
Vendi minha mídia física faz uns 3 meses. Achei bom lançarem essa versão free, esses dias me deu vontade de jogar de novo. Como não sou jogador hardcore do MP, pra mim ta ótimo.
Dúvida, comprei ontem a dlc na conta BR onde comprei o jogo e as outras dlc.
Jogo na conta US porém ontem depois de uns 30 min fui ver os brindes do passe de temporada e vi que não está ativo na conta US, somente na conta BR.
Alguém com o mesmo problema? pelo que vi nessa dlc houve um lock para o passe de temporada.
Tem muita coisa no jogo, normal ficar perdido mesmo. Lembro que no começo eu tava jogando com um amigo, completamos uma missão e não aconteceu "nada", hehe.Comecei a jogar ontem também, nunca tinha jogado nenhum destiny, até então gostando bastante mas bem perdido, são muitas opções de tudo, mas curtindo..
VIxe maria achei nada então, poisé, também fiquei em dúvida quando a missão termina, porque você continua indo e fazendo outras coisas hahaha.Tem muita coisa no jogo, normal ficar perdido mesmo. Lembro que no começo eu tava jogando com um amigo, completamos uma missão e não aconteceu "nada", hehe.
Depois entendi que a missão foi concluída, o jogo não te leva de volta pro acampamento, vc fica livre pra explorar mais o mundo ou voltar.
Nessa nova versão apanhei pra achar as campanhas clássicas. Caso ainda não tenha descoberto, elas ficam com a Amanda Holliday n'A Torre, do lado direito do mapa.
