Falaram tanta coisa ruim desse driver que pela primeira vez eu nem tentei atualizar, embora seja uma RX 470 que está na máquina, não uma Navi.
Peguei uma rx 570 (vendi minha 2080 e to aguardando a 3080 )e instalei o ultimo drive da AMd mais em alguns jogos a tela fica piscando tipo cortando a imagem . Qual o drive mais estável da AMD para essa placa ? Tanto tempo com Nvidia que tinha ate esquecido dos Bugs dos drives da amd aff
Vc formatou? instale o ultimo driver recomendado WHQL que não terá problema algum.
Radeon Software Adrenalin 2020 Edition 20.11.3 Highlights
Support For
Immortals: Fenyx Rising™
Vulkan® Ray Tracing Extensions
Added Vulkan® Support
VK_KHR_fragment_shading_rate
This extension provides the ability to change the shading rate per fragment. This extension allows for multiple pixels to be shaded via a single fragment shader invocation as opposed to the normal rate of one invocation per pixel.
VK_KHR_acceleration_structure
This extension provides acceleration structures for representing geometry that is spatially sorted. Acceleration structures are the most common way for quickly identifying potential ray intersections by ray tracing techniques.
VK_KHR_ray_tracing_pipeline
This extension introduces ray tracing pipelines along with new shader domains and an indirection table to link shader groups with acceleration structures.
VK_KHR_ray_query
This extension introduces ray queries, which can be used by any shader type outside of the optional dedicated ray tracing pipeline to return traversal results to the calling shader.
VK_KHR_deferred_host_operations
This extension defines the infrastructure and usage patterns for deferrable commands, which allows dependent extensions to defer their own operations. The VK_KHR_deferred_host_operations extension itself does not specify any commands as deferrable.
VK_KHR_pipeline_library
This extension introduces pipeline libraries. A pipeline library is a new special pipeline type that defines a set of pipeline states. It cannot be bound, rather it can be linked into other pipelines.
VK_KHR_shader_terminate_invocation
This extension indicates support for the SPV_KHR_terminate_invocation SPIR-V extension. The SPIR-V extension introduces a new instruction OpTerminateInvocation that allows a shader invocation to immediately terminate, which provides the behavior required by the GLSL discard statement.
Fixed Issues
Lower than expected performance may be experienced on Radeon™ RX 6000 series graphics products in Watchdogs:® Legion and Dirt™ 5.
Lower than expected performance may be experienced on Radeon™ RX 5000/500/400 series graphics products in Godfall™.
Godfall™ is not detected or listed in Radeon Software gaming tab.
Crysis™ Remastered may experience corruption on character models on Radeon™ RX 6800 Series graphics products.
Fixed some intermittent crashes found in Total War™ Saga: Troy and World of Warcraft®: Shadowlands.
World of Warcraft®: Shadowlands may fail to launch when DirectX®12 API is selected on Windows®7 system configurations.
Fixed some intermittent crashes found in Call of Duty®: Black Ops Cold War with DirectX® Raytracing enabled.
HDR on supported Windows 10 desktops might get disabled when DOOM® Eternal™ starts rendering in HDR mode.
Fixed issues found on Adobe™ Illustrator, Adobe™ Premier and FinalWire AIDA64.
Fixed corruption issues in Red Dead Redemption 2 in 1080p resolution on Radeon™ RX 6800 Series graphics products.
Known Issues
Brightness flickering may intermittently occur in some games when Radeon™ FreeSync is enabled, and the game is set to use borderless fullscreen.
Metro Exodus™, Shadow of the Tomb Raider™, Battlefield™ V and Call of Duty®: Modern Warfare may experience intermittent application crashes with DirectX® Raytracing enabled.
Anisotropic Filtering in Radeon™ Software graphics settings is not taking effect in DirectX®9 applications on RDNA graphics products.
Some games may experience stuttering when set to borderless fullscreen and an extended display is connected running the Netflix™ windows store application on RDNA graphics products.
Radeon™ recording and streaming features may fail to enable on AMD Radeon™ HD 7800 series graphics products.
Modifying the HDMI Scaling slider may cause FPS to become locked to 30.
Performance Metrics Overlay and the Performance Tuning tab incorrectly report higher than expected idle clock speeds on Radeon™ RX 5700 series graphics products. Performance and power consumption are not impacted by this incorrect reporting.
Enhanced Sync may cause a black screen to occur when enabled on some games and system configurations. Any users who may be experiencing issues with Enhanced Sync enabled should disable it as a temporary workaround.
Oculus Link users might experience crashes on Polaris and Vega series graphics products.
Flickering might be observed if the Radeon Software Overlay is invoked while Immortals: Fenyx Rising™ is running on an extended display.
Tom Clancy’s Rainbow Six® Siege might experience corruption in Hybrid Graphics scenarios when using the Vulkan API on an extended display.
Screen flickering might be observed when using MSI Afterburner.
vou instalar esse nao formatei nao passei aquele programa de excluir drives e instalei por cima
Sim o amigo deve enviar a nova vga ate sexta feira estarei com ela por isso não to esquentando a cabeça chegando vou formatar o pc e deixar tudo zero bala novamente . Essa Rx 570 so peguei de backup mais talvez a venda ...Cara, vc usava uma 2080 e foi cair numa rx 570, pelo amor de Deus...
Já comprou a 3080? Se sim, ainda bem. Não adianta, AMD já era para vgas, depois que comprou
a ATi, virou uma p@rcari@!
Cara vc nem usa AMD como fala que a ATI virou uma porcaria sem usar ?
z
Já usei muito Amd. tinha 1 Rx 480 que só dava problemas nos drivers e hardware. É só vc ver relatos passados no fórum.
Tive muitas Ati ótimas mas depois que a Amd a comprou, caiu a qualidade.
Não queria dizer nada não, mas to com uma MSI RX 580 desde julho de 2019...
Tive problema com o driver mais recente, q era opcional e com a troca do 2019 para a versão 2020... Com a placa em si, nenhum nenhum mesmo, pau pra toda obra aqui, só alegria, e ainda tem garantia até 2022.
Às vezes a sua 480 tava zoada, Carlos... Vai saber...
eae como que ta esse drive ?driver novo no Guru3D mas nada lá no link direto da AMD... é driver só pra série 6000 com raytracing?
AMD Radeon Adrenalin Edition 20.12.1 driver download
Download: https://www.guru3d.com/files-details/amd-radeon-adrenalin-edition-20-12-1-driver-download.html
Support For
Fixed Issues
- Radeon RX 6900 Series
- Cyberpunk 2077
Known Issues
- Gaming applications can sometimes get stuck running at lower than expected graphics clocks on Radeon RX 6800 series graphics products.
- The HP Reverb G2 VR headset may fail to sync or may have a black screen when run with Radeon RX 6800 series graphics products.
- Tom Clancy’s Rainbow Six® Siege may experience corruption in Hybrid Graphics scenarios when using the Vulkan API on an extended display.
- Crossfire™ may experience issues when attempting to change the games resolution to a 16:9 ratio.
- Performance Metrics Overlay and the Performance Tuning tab incorrectly report higher than expected idle clock speeds on Radeon™ RX 5700 series graphics products.
- Brightness flickering may intermittently occur in some games when Radeon™ FreeSync is enabled, and the game is set to use borderless fullscreen.
- Some displays such as the Sceptre C series or Samsung™ Odyssey G9 series may experience an intermittent black screen on Radeon RX 6000 series graphics products.
- The Samsung™ Odyssey G9 C49G95T may experience display or corruption issues when set to 5120x1440@240hz.
- Metro Exodus™, Shadow of the Tomb Raider™, Battlefield™ V and Call of Duty®: Modern Warfare may experience intermittent application crashes with DirectX® Raytracing enabled.
- Anisotropic Filtering in Radeon™ Software graphics settings is not taking effect in DirectX®9 applications on RDNA graphics products.
- Some games may experience stuttering when set to borderless fullscreen and an extended display is connected running the Netflix™ windows store application on RDNA graphics products.
- Radeon™ recording and streaming features may fail to enable on AMD Radeon™ HD 7800 series graphics products.
- Modifying the HDMI Scaling slider may cause FPS to become locked to 30.
- Oculus Link users may experience intermittent crashes on Polaris and Vega series graphics products.
- Screen flickering might be observed when using MSI Afterburner.
- Enhanced Sync may cause a black screen to occur when enabled on some games and system configurations. Any users who may be experiencing issues with Enhanced Sync enabled should disable it as a temporary workaround.
De qq jeito vou testar aqui...
obrigado pelo seu tempo parceiro , vou baixar aqui jaja vamo jogar o cyberpunk@Marcelinho111
tá legal o driver, mas só joguei GTA online hj com ele...
Mesma coisa do 20.9 WHQL e do 20.11.3, estável e imagem bonita deixando chill 57-60 FPS aqui - uso 1440p e 1800p nos jogos
Monitor é 1080p 75hz mas prefiro 1440p 60Hz pra deixar a placa fria sem muito barulho
Support For
Fixed Issues
- Cyberpunk 2077
Known Issues
Veja com qual esta rodando melhor,,,Pra jogar Cyberpunk preciso de driver mais novo?
Tenho a versão mais antiga.
