Fala galera, boa noite!
Fiz um overzinho básica na minha 970 G1 e tá crashando em alguns jogos, no BF4 por exemplo aparece o seguinte erro:
http://i1370.photobucket.com/albums..._36_44-Greenshot capture form_zpsx3ktdx07.png
Segue as specs do over:
http://i1370.photobucket.com/albums/ag253/vctrbndr/2015-02-23 23_39_58-_zpskatlncrs.png
Alguém sabe se tem alguma forma de deixar mais estável?
Valeu!
Novo driver quentinho para a galera, direto do guru3d!
Dizem que o driver tá mítico na 980 e 970 no windows 10 e no 8.1, ainda não testei!
Link: http://www.mediafire.com/download/d8dv6rygxol22ak/349.65-desktop-win10-64bit-international-beta.exe
If this driver is the same as the planned 349.72, the release notes has following changes:
These release notes describe the NVIDIA Release 349 family of graphics drivers for
Microsoft® Windows® 10 Preview (32 and 64-bit).
DirectX 12
Single GPU only
DirectX 9, 10, 11
Single GPU and 2-way SLI
Stereoscopic 3D
NVIDIA G-SYNC
OpenGL 4.x
Single GPU and SLI (No performance scaling / SLI Mosaic support)
OpenCL 1.2
Added OpenCl 1.2
Optimus / Microsoft Hybrid Support
Render pipeline only (see Limitations section)
Shadowplay
Single GPU and SLI
Supported on Optimus systems
Gamestream
Single GPU
Limitations
Surround performance has not been verified.
You may experience sub-optimal DirectX 12 performance with Maxwell architecture GPUs.
Optimus/Microsoft Hybrid System
The following limitations exist on some Optimus systems, but should be addressed by Windows 10 RTM:
Optimus power management is not fully functional.
Monitor connections on the discrete GPU are temporarily disabled pending changes in the Windows 10 OS.
DirectX 11 Limitation
Tiled resources are not yet supported.
DirectX 12 Limitations
Default resource heaps and application-controlled resource residency are not yet supported
Root SRV and UAV descriptors are not yet supported.
Compute CBV descriptors must not be edited in a command list after a SetComputeDescriptorTable call.
Does not support NVIDIA G-Sync, 3D Vision, SLI.
você joga no low?
se sim, a voltagem do gpu cai para 1.025~1.050 junto com o clock pois o gpu não está sendo utilizado em sua totalidade, porém a memória se mantem estática no clock que você setou pelo evga precision
nessa voltagem não segura o clock da memória vindo dar esse erro!
abraço
oque mudou nele para o outro ? algum ganho de fps?
É um driver milagroso, sobe mais de 20 fps em cada game...sli de 980 segurando 4k a 60 frames
Mas esqueça no 8.1 ta bugado e dando tela azul quando você vai instalar!
de acordo com o cara de guru3d sairá o oficial em março com suporte ao dx10, wd... 2.0
puts ja ia testa no windows 8.1 sera que tento ?
Nem tenta, dá tela azul no meio da instalação!
AGORA A BATATA VAI ASSAR PARA O RABO DO NVIDIA...
... ação coletiva em um tribunal dos Estados Unidos.
http://www.techpowerup.com/210100/c...against-nvidia-over-gtx-970-memory-issue.html
Vão respeitar o consumidor por bem ou por mal.
Se a sua G1 for igual a minha, o seu over não vai além disso aí não, pois aqui só fica instável com +125 no core clock e +375 nas memos... Acima disso, da esse mesmo erro de DX... E não importa a voltagem, já tentei com bios com voltagem maior e nem assim foi mais além =/Fala galera, boa noite!
http://i1370.photobucket.com/albums/ag253/vctrbndr/2015-02-23%2023_36_44-Greenshot%20capture%20form_zpsx3ktdx07.png
Valeu!
é verdade acabei de toma tela azul mas em quando SO vai de boa ?
Como assim quando SO?
isso é problema da voltagem se estiver jogando no low
se estiver jogando no ultra e continuar o erro, ai sim é o over!
na verdade qual o sistema operação que funciona de boa?
Só no windows 10!
esse driver ta para sair em março ou antes ainda de acordo com o cara lá no guru3d
e o bagulho ta top
subiu 2000 pontos no graphics score no 3dmark 11, isso usando a gtx 970!
entaão nao vai ter suporte para o 8,1 ?
Vai sim, esse é um driver beta do windows 10 só
que dá suporte ao dx12 e WDMA 2.0
o windows 8.1 é o WDMA 1.3
vai sair em março para o 8.1 ou até antes!
então a placa vai ser 100% dx12 ?
Claro que sim, até a série 7 vai ter suporte mas não sei se será total
já as 900's terão full suporte!
entao quer dizer que agora elas iram somar as memorias ? alem dos bits?
Valeu!
DirectX 12
Single GPU only
DirectX 9, 10, 11
Stereoscopic 3D
NVIDIA G-SYNC
OpenGL 4.x
OpenCL 1.2
Added OpenCl 1.2
Shadowplay
Single GPU and SLI
Gamestream
Single GPU
Limitations
você joga no low?
abraço
Cara o ideal é testar a GPU depois a Vram ou ao contrário, para saber até onde pode subir teu OC em cada um.
Vcore e Power Target pode deixar no máximo sem problemas.
Aconselho usar o NVinspector.
Valeu!
Na 970 70C já chega a dar instabilidade.
70ºC pra uma GTX970 nem é muita coisa.
A maioria dos modelos referência ou com fan blower se aproxima dos 80ºC em full load (sem fan profile)...
Só no windows 10!
e o bagulho ta top
