Release The Kraken!
Key Features:
Completely redesigned PCB layout from the ground up, optimized for GM204
10 layer manufacturing process in HOF signature pure white color
Extended PCB width for optimized layout and cleaner signal
Advanced GALAX exclusive “Triple Force” cooler
2x 80mm fan + 1x 90mm fan
4x 8mm heat pipes + 3x 6mm heat pipes (total 7 nickel-plated heat pipes)
Copper base cooler
Integrated MOSFET heatsink
Customizable top HOF LED (control blanking frequency, brightness with GFE)
Plastic cover with premium die-cast aluminum accents
Anodized aluminum backplate protects components and reinforces PCB
Next generation IR3595 Digital PWM controller provides 2X switching frequency vs. previous generation
8 phase GPU + 2 phase memory power
IR3555 with next gen DrMOS and 60A output
Aerospace-grade GALAX Extreme Power Inductors provide ultra-long life, high endurance and low noise vs. normal power inductors
Hyper Boost technology acts like a hardware turbocharger, increasing fan speed and maximum power delivered to the GPU with the push of a button
Voltage tool (developed by enthusiasts) allows voltage beyond stock limits
Hardware dual BIOS simplifies the tweaking process by enabling risk-free firmware updates and customization
Prelim internal overclocking results: >1.5GHz on air, >2.1GHz on LN2
